Old 08-19-2005, 02:39 AM   #1
shemoves
Member#: 80663
1997 Outback
Default IS there a wheel stronger/lighter than stock bbs?
Looking to have a seperate set of track-day wheels/tires. Are their any wheels that are: actually stronger and lighter than the stock BBS, 17x8 (5x114.3,) and will clear the STi brembos. Basically, better than stock replacement wheels.
shemoves is offline   Reply With Quote
Old 08-19-2005, 11:09 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
No345
Old 08-19-2005, 03:02 PM   #3
shemoves
Member#: 80663
1997 Outback
I've heared the the Advan, is it RGII?, is very strong/light. How does it compare to the BBS?
Old 08-20-2005, 06:33 AM   #4
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
volk racing ce28n's, lighter and stronger(should be)
petawabit is offline   Reply With Quote
Old 08-20-2005, 11:34 AM   #5
2phless
Member#: 69343
2000 nothing good
slow
2 of my BBSs have slight bends. One I got fixed a bit. Couldn't make it completely perfect again. The other's bend wasn't bad enough to worry with fixing. Both of my $700-ish a set Rotas have none.
Oh and the Rota SDRs are only .5 lbs heavier each. The Slipstreams are a bit heavier, but they are a bit wider too.
Just one guys experience.
2phless is offline   Reply With Quote
Old 08-20-2005, 12:34 PM   #6
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
are they bends that can be seen visibly with out trouble?
scoobtothenoog is offline   Reply With Quote
Old 08-20-2005, 06:50 PM   #7
shemoves
Member#: 80663
1997 Outback
When you ride on the bent rims can you feel it?
Old 08-20-2005, 06:58 PM   #8
PKSJ4
Member#: 92680
2004 STI
work wheels (VSXX). love them............
PKSJ4 is offline   Reply With Quote
Old 08-21-2005, 12:14 AM   #9
2phless
Member#: 69343
2000 nothing good
slow
Seen visibly. That's a good one. Yes, but you have to "look."
No. I never knew until I pulled them to change wheels. I was planning on using my Rotas as rough winter tires with healthy treads, and the BBSs as summers with high performance tires. Changed my plan after the bends. But no, they aren't bad enough to feel. Either on the front or the back.
Old 08-21-2005, 02:03 AM   #10
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
LOL, ya i guess something has to be "visible" to be "seen" LOL.....shoot me now.
Old 08-21-2005, 12:14 PM   #11
S203
Member#: 86636
Go to Tirerack.com and look for Wedsport.
S203 is offline   Reply With Quote
Old 08-21-2005, 12:25 PM   #12
cooleyjb
Member#: 55727
#533 Spec Racer Ford
Fiske and more expensive BBS
cooleyjb is offline   Reply With Quote
Odyssey PC 680 battery- 20 lbs lighter than stock! BIGSKYWRX Engine/Power/Exhaust 6 05-19-2009 07:26 PM
Any 17" Wheels/tires lighter than stock? JonM in MN Newbies & FAQs 15 04-05-2009 01:51 PM
Lighter than stock battery for ~$20 TheMadScientist New England Impreza Club Forum -- NESIC 5 06-19-2004 11:26 PM
18" Wheel Lighter Than Stock STi Wheel chaddeus Tire & Wheel 4 04-23-2004 03:24 PM
Is there a quieter short ram than TurboXS shorty? Shaitiger Factory 2.0L Turbo Powertrain 0 11-26-2003 02:40 AM
Message Board Statistics All times are GMT -4. The time now is 03:03 AM.
