Old 08-19-2005, 01:55 PM   #1
Mikey52
Member#: 69019
1995 Legacy Wagon
Default ABS pump is dead, can I trick the car into thinking it's there?
I have been living without ABS for quite some time now since my pump died last fall. Basically, I just unplugged the pump and went on my way. I actually found that the car stopped a helluva lot better in the snow without ABS.
Now I may be moving to a state that requires yearly inspections and I know that ABS light on the dash isnt going to cut it. I was thinking that if I took a resistor with the same resistance as the pump and plugged it into the plug in the engine bay, it may trick the car into thinking it's there. Anyone know if this would work?
For those wondering why i just dont get a new pump, my car isnt worth that much and I really dont want to dump that kind of money into it.
Also, I would NEVER sell the car without disclosing the lack of ABS to the prospective buyer. I dislike people who misrepresent their vehicles.
Mikey52 is offline   Reply With Quote
Old 08-19-2005, 03:13 PM   #2
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Why don't you just pull the ABS light bulb?
xcntrk75 is offline   Reply With Quote
Old 08-19-2005, 03:49 PM   #3
Dobes
Member#: 164
2008 Exige S240
fwiw, your car would pass inspection in Pa with the ABS light on.
JD
Dobes is offline   Reply With Quote
Old 08-19-2005, 04:27 PM   #4
Mikey52
Member#: 69019
1995 Legacy Wagon
Dont I have to pull most of the dash to do this?
Im moving to VA, I know they are fairly nazi-like so I guessed they wouldnt like the light.
Old 08-19-2005, 04:47 PM   #5
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Just pull the bulb if you think its going to be a problem. You do have to take apart some of the dash, but shouldn't be too bad. I can take apart everything in about 5 minutes these days. It's maybe 15 screws total to get the cluster out on 00-04.
fibuz
fibuz is offline   Reply With Quote
Old 08-19-2005, 04:54 PM   #6
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I can get the dash in my '91 out in about 10 minutes.
Most of the time is spent trying not to break anything while maneuvering out the cluster surround.......
IronMonkeyL255 is offline   Reply With Quote
Old 08-19-2005, 06:36 PM   #7
RoundtheBend
Member#: 5034
2004 Money Pit
silverish-mud
I might be able to get my hands on the ABS pump from a '96 LS or a '99 LGT. If that will fit your car, we could probably work something out.
RoundtheBend is offline   Reply With Quote
Old 08-19-2005, 07:14 PM   #8
sir_wagon
Member#: 71549
How long ago did you last change the brake fluid?
sir_wagon is offline   Reply With Quote
Old 08-22-2005, 11:26 AM   #9
Mikey52
Member#: 69019
1995 Legacy Wagon
I honestly dont know when the fluid was changed (stupid, I know). When the pump went it just continuously ran and ran after I shut off the car. I pulled the plug on it so it wouldnt kill my battery and I havent looked back.
I appreciate the offer but at this point Im more inclined to let it stay dead. Ive never locked them up and it stops better in the snow now.
Thanks for the input guys, I'll take a look at the cluster and see how to get it out.
Old 08-22-2005, 01:35 PM   #10
RoundtheBend
Member#: 5034
2004 Money Pit
silverish-mud
It's a simple removal. I can't count how many times I pulled mine out for various things. I changed my light colors several times, etc.
The difficult part (for me) was getting the cluster out (after removing all the screws).
Good luck!
Old 08-23-2005, 03:22 AM   #11
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Isn't there some sort of TSB out about ABS pumps that run all the time, even with the car off? I could have sworn I read something about it someplace.
Al_Smokemcrack is offline   Reply With Quote
thump.thump is dead...not me, but the car! thump.thump Vancouver Impreza Club Forum -- VIC 31 10-31-2008 01:15 AM
Tech gurus: Is there any way to trick an installer into thinking an OS is different? Jessie James Off-Topic 11 04-23-2008 02:58 PM
Need help, think my unit is dead... can i play with yours? blitz WRX-pilot Southern California Impreza Club Forum -- SCIC 9 04-30-2004 04:37 AM
is there a way to trick the ECU into thinking your o2 sensors are hooked up?? ammoniaman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-14-2004 12:16 AM
Took the sube off road now at 45 there is a bad shaking of the car! GregBolby General Community 16 12-12-2001 01:19 PM
