Old 08-19-2005, 07:19 PM   #1
calib17a
Member#: 64150
Default repost: My Twin Walbro 255 Fuel Pump Set up. Pictures and Info
Originally posted in 2.0 powertrain by STEALTH-WRX , but it's important enough to post in 2.5 forum.
Link to original post: http://forums.nasioc.com/forums/show...0#post10785850
I was thinking about doing this since I'll be installing my gt35r. Anyone have any updates or tips?
Here are pics from the origional post:
calib17a is offline   Reply With Quote
Old 08-19-2005, 07:23 PM   #2
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Got fuel? Jeez!
At what point do you need that much fuel? 500/600hp?
djerickd is offline   Reply With Quote
Old 08-19-2005, 07:26 PM   #3
calib17a
Member#: 64150
I had talked to Clark @ Kingpin a while ago and he had told me gt35r setups with a single walbro 255lph ran out of steam when reaching the upper limits of 500+ hp range, so they recommended running twin 255 lph walbros to compensate for the needed fuel delivery. You don't want take chances with fuel starvation at those power levels.
Old 08-19-2005, 09:24 PM   #4
mavrick
Member#: 78477
04 Element block
Hydra pwrd t67
dumb question they both feed one fuel line??
Dustin
mavrick is offline   Reply With Quote
Old 08-19-2005, 09:57 PM   #5
import111
Member#: 24447
2010 Evo GSR
GG
Isn't there a single fuel pump that flows more than 255lph so you would only need 1 pump instead of 2?
Ryan
import111 is offline   Reply With Quote
Old 08-19-2005, 09:59 PM   #6
calib17a
Member#: 64150
I believe Walbro has a 310 lph fp, but two 255 lph fps flow more.
Old 08-19-2005, 10:53 PM   #7
949
Member#: 58906
so i guess fuel prices isnt a factor here.
wouldnt you run out of gas at about 120 miles/per tank? our tanks are not that big. i do about 240 miles with almost stock and conservative driving.
949 is offline   Reply With Quote
Old 08-19-2005, 11:09 PM   #8
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I'm guessing that gas prices is not one of your concerns when building a 500+ hp car.
StiDreams is offline   Reply With Quote
Old 08-20-2005, 01:15 AM   #9
mpj_becks
Member#: 6265
You'll need to sort the voltage supply out before you'll need dual pumps but your right you'll need more fuel than a single Walbro will provide on a solid GT35 tune.
mpj_becks is offline   Reply With Quote
Old 08-20-2005, 01:17 AM   #10
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I am also guessing that you don't plan on using any sort of WI/AI?
offset
offset is offline   Reply With Quote
Old 08-20-2005, 03:06 AM   #11
calib17a
Member#: 64150
I'm injecting propane.
Old 08-20-2005, 01:12 PM   #12
x99percent
Member#: 27108
2004 STi
2004 A4
The number of fuel pumps has little to do with how much fuel is actually used.
x99percent is offline   Reply With Quote
Old 08-20-2005, 02:47 PM   #13
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Mike, tuner at Gruppe-s did this recently.
I think it is post #68
i-club.com/forums/showthread.php?t=70100&page=4&pp=20
AntiochCali is offline   Reply With Quote
Old 08-20-2005, 09:44 PM   #14
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
How are you tying in the propane? I would think with that you could get away with a lot less fuel than what two pumps could push. What injectors are you going with also?
offset
Old 08-21-2005, 12:24 AM   #15
calib17a
Member#: 64150
I'm using Utec's auxilary solenoid control. I have it set at 2300 rpms @ -4 psi of boost to turn on propane solenoid. I'm using Perrin 816cc modified sti injectors. I might as well do it before the tune.
Old 08-21-2005, 10:54 AM   #16
awilson529
RIP
Member#: 38867
11 Mazda
Why not just do an H2O or meth setup and run leaner EGT & have more power?
awilson529 is offline   Reply With Quote
Old 08-24-2005, 05:46 PM   #17
SLPRSTI
Member#: 94355
2004 STI
JAVABLACK
i just went through the same question in my mind. yes you will have to refuel all the time with the stock tank. the 255 pump as a twin will work but its kinda hokie. what i did was put a summit 22gallon foam cell and a sx 1200 to 1000 hp inline pump in with dash 12 hard lines to the perrin rails. hey awilson529 you are rite meth2water injection is worth every penny. when you dont want to pay for C16 fuel or even the cheaper epa legal 100 at 76 station you can make the methanol compisate for the loss of octain. thats what i do on ecutek. i post pics soon since the car is apart.
SLPRSTI is offline   Reply With Quote
Old 08-24-2005, 06:00 PM   #18
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Why not do the intelligent thing and run a single external pump that CAN flow enough for your setup?
BTW, interested in hearing more about the propane setup. I've loved the idea for a while now.
Old 08-24-2005, 07:30 PM   #19
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I'm going to go out on a limb here and guess that an SX1200, 20 gallon foam fuel cell and -12 hard lines plus fittings are not in the same cost arena as putting in a walmart pump, slapping together a couple of fittings and some lines or better yet just swapping the return and supply line. Cheap is not always right but sometimes itís good enough. But for this hobby right is almost never cheap.
Old 08-24-2005, 07:41 PM   #20
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
OK, I am stupid, what are the pillow looking things at the bottom of the pumps. My guess is some sort of sponge to keep sloshing from starving the fuel lines, but I have no idea.
Nixlimited is offline   Reply With Quote
Old 08-25-2005, 12:07 AM   #21
metoo
Member#: 4764
2004 STi sold :(
forizzle
Filters. These are not the main fuel filter.
When I changed my pump, I saw lots of metal flakes built-up on the filter. It really worried me until I figured where the flakes came from......fuel pumps nozzles at the gas station.
metoo is offline   Reply With Quote
Old 08-25-2005, 01:09 AM   #22
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Hey guys. Yes.. we run Dual pumps. The main reason is simple. I dont need Double the flow of twin walbros. What I need is more fuel at high boost pressures. I need more fuel at 60-80 psi of fuel pump pressure. Most intake pumps really die off up here. In this situation you can do several things..
Larger injector ... Not an option for us with Utec
Larger fuel lines... Do not believe in doing this on a street car
Larger pump... Have not been able to find one that bolts in.
The HKS 310 pulls ALOT and if you search the net you find that it really does not fit our needs. I do not believe in running external SS lines all the way up on a customers street car. I believe the stock lines are safer and built and run in a manner to not break in a sever crash. You might be ok with this but I am not. Its just like I dont believe in running R compound tires on a car without a roll cage and I dont believe if driving in a car with a roll cage without a helmet. I guess I am a scaredy cat. The solution I came up with was simple and cheap.. Add a second walbro. A walbro pulls 7 amps. A supra pump or HKS pump pulls 14 amps or twice a walbro. Add two, problem solved, you spent a little cash and your car is safe.
Clark
AZScoobie is offline   Reply With Quote
Old 08-25-2005, 04:13 AM   #23
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by djerickd
Got fuel? Jeez!
At about 440whp on our dyno.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 09-18-2005, 09:54 PM   #24
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
subscribe
silver arrow is offline   Reply With Quote
Old 09-18-2005, 10:07 PM   #25
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Clark was wondering will the increase in amps cos a fuse to blow? Have u found any problems with overheating of the pumps over long bursts?
Have u seen any pumps fail? Wot would be needed to remedy this?
I was wanting to go down this path but im a lil unsure now
tino is offline   Reply With Quote
565cc blue injectors and Walbro 255 fuel pump for my 02 WRX 02wrxroger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-09-2010 05:33 PM
For Sale RC Engineering Injectores 440cc and Walbro 255 fuel pump blaznc Engine/Power/Exhaust 4 02-10-2007 11:45 PM
My Twin Walbro 255 Fuel Pump Set up. Pictures and Info STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 02-09-2006 03:22 PM
FS: STI pink injectors and Walbro 255 fuel pump nimaxpro Private 'For Sale' Classifieds 9 10-19-2005 11:05 PM
Walbro 255 fuel pump and a header for a STI bottlediger Private 'Wanted' Classifieds 0 03-26-2005 10:51 PM
