Old 08-19-2005, 10:41 PM   #1
shemoves
Member#: 80663
2005 STi
Default '94 Legacy boost guage install same as GDA?
I've done boost guage installs on an '04 WRX and an '05 STi (used vac line on the stock recirc. valve). Could someone direct me as to which line to splice into on the '94 Legacy turbo?
shemoves is offline   Reply With Quote
Old 08-19-2005, 11:46 PM   #2
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
I just spliced into the vacuum line leading from the manifold to the BOV or recirc valve. That puts it right near the firewall for easy routing, and slightly faster response (I'm making that up).
IronMonkeyL255 is offline   Reply With Quote
Old 08-20-2005, 06:05 AM   #3
shemoves
Member#: 80663
2005 STi
would you be able to give me more specifics as to where the vac line is on the SS? (Is it the hose that comes out of the passenger side of the manifold, goes into a small, black, circular plastic thing, then seperates into about three lines from the plastic cylinder?)
Old 08-20-2005, 11:44 AM   #4
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
Nope. That's the charcoal canister, an emissions device.
The line I am talking about come out of the back of the driver's side of the manifold, around where the vacuum line for the brake booster is, and goes to the bypass valve, which is just below the little intake elbow thingy right before the throttle body.
I can get some pics if you need them.
Old 08-20-2005, 12:37 PM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
The brake booster line is larger and has a threaded end on it. The line for the bov just slides onto a brass fitting and has a quick clamp on it. You wont be able to see the brass fitting until you pull the hose back.
subiekid is offline   Reply With Quote
BD Legacy grilles :L grille same as GT? eta_Legacy Legacy Forum 14 04-16-2010 05:01 PM
OEM steering wheel mount Boost Gauge - WRX same as STi? STiMUL8 Newbies & FAQs 6 05-21-2005 05:34 PM
GDA RS Springs the same as GDA WRX? BrysImpreza Brakes, Steering & Suspension 1 08-11-2003 12:32 AM
Turbo Timer/Boost contoller/Boost Guage installs... FastandFurious Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 02-12-2002 10:25 AM
('93-'01) Is a 98 legacy 2.5 engine same as a 99 RS Jimmy Impreza Forum 4 05-21-2001 11:10 AM
