Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-20-2005, 03:18 PM   #1
BlackoutWRX
Member#: 74589
2000 94 Infiniti G20
90 S13 Coupe
Default weird idle problem. long, but i really need help.
ill try to explain what happens, then describe the problems in detail.
1. when car is started (while still warmed up from driving) car starts, then idle drops to around 100 rpms, isits there for about a second, then moves up to the normal 750 rpms. (its happens VERY often)
2. when car is started for the first time in the morning, the idle its high like it should, then slowly moves down a few houndred rpms, then moves back up, then moves back down (slowly)
about 4 weeks number 1. happened to me once. then it idled fine after that. about a week ago i drove in a VERY heavy rain storm, passing cars splashing tons of water at my car, etc. i pullled over, went into a store, and thats when number 1 started happening again. the next morning i started it up and number 2 happened. number one continued. right now number one is happing and number 2 still happens but it only jumps a little bit. i thought it might be water on the air filter but im running a stock air box and i changed the filter and it still happens. sometimes then i turn it on it setteles right at 750 but most of the time it does whats described above. only mod is an exhaust. what could possibly be wrong? it has to be something with the water because thats when it really started. please help.
BlackoutWRX is offline   Reply With Quote
Old 08-20-2005, 03:32 PM   #2
scooterforever
Member#: 55011
Many of our cars get dirty IACV's as they age, and this can show up as irregular idle, either too high or too low. For me, the car idled low, and started stalling. Check out the sticky at the top of the Service and Maintenance Forum. The pic links are broken, but that should be fixed soon. It could be other issues, but cleaning the IACV isn't that hard and could resolve it (just don't open it until you have a replacement gasket).
scooterforever is offline   Reply With Quote
Old 08-21-2005, 06:57 PM   #3
BlackoutWRX
Member#: 74589
90 S13 Coupe
ok thanks for the help. anyone else? im trying to get as many opinions as possible.
Old 08-21-2005, 08:24 PM   #4
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
100 % correct
tekfoc is offline   Reply With Quote
Old 08-22-2005, 09:52 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
clean your maf sensor as well.
Old 08-22-2005, 10:51 AM   #6
timmah
Member#: 54203
2011 WRX
my car does this when cold, idles up and down within a small range. I've checked for vacuum leaks and the maf is new along with the front 02 sensor. as soon as I drive it for a minute it stops, so I don't worry about it.
timmah is offline   Reply With Quote
Weird idling problem - Very high idle Oodles-of-Noodles Mid Atlantic Impreza Club -- MAIC 21 02-04-2010 11:25 PM
Yet another Tire Q, but i really need some help! ebrake_n Tire & Wheel 3 05-02-2007 07:41 PM
weird idle becasue of new BOV i need help!!!! WRX_Mike Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-16-2005 04:15 AM
Weird Idle problem? Stiguy247 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-16-2005 02:20 PM
weird idle problem I can't figure out! wewu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 03-11-2004 09:12 PM
