Old 08-20-2005, 07:26 PM   #1
shemoves
Member#: 80663
2005 STi
Default 2.2T motor fail-closed thermostat?
I ask this question in order to diagnose an overheating problem. Everything was working great, but I decided to flush the coolant anyway (bought the car off a friend, did not know how old the coolant was...I know, if it ain't broke, don't fix it ). I bought one of the Prestone hose-flush kits. Everything went really smoothly, but, as I was refilling the coolant I ran into a glich.
While it was filling, water suddenly started spewing out of the hose connection. My guess was that the thermostat failed from the water pressure, and it is a fail-close, preventing any flow.
Here are some other related questions that may help me. Can the overflow tank get boilover if the coolant system is not full or close to full? Where is the thermostat?
shemoves is offline   Reply With Quote
Old 08-20-2005, 10:42 PM   #2
jsaunders
Member#: 40059
10 CTS--V
thunder grey
It's fail safe, not fail close. The fail safe- if there are any problems it will be stuck open to prevent overheating. It sounds like you do have to change the thermo. as you might not have a fail safe thermo.
jsaunders is offline   Reply With Quote
Old 08-21-2005, 01:08 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Where did you hook up the hose kit? where is the water leaving the cooling system?
Legacy777 is offline   Reply With Quote
Old 08-21-2005, 05:59 AM   #4
shemoves
Member#: 80663
2005 STi
May have had a simple fix, thank God. As it turns out it was about a quart+ low on water. I was trying to finish the refill using the overflow tank...yah that does not work. I used the pressure cap opening, and ran it for a bit before I went out. I did not think such a small amount of water could make such a big difference.
Fail safe (fail-open), really good to know, and a relief.
The hose kit it installed on the engine 'in' tube. The tube runs from the firewall to the engine (non water pump). I used the radiator drain plug hole.
If this all ends up working out, I am definitely going to put it on my STi.
Old 08-22-2005, 02:36 PM   #5
Legacy777
Member#: 4800
The drain plug on the radiator isn't really going to flow enough out of it compared to what the garden hose is putting in. I'd personally want another outlet for the water....but that's me.
Old 08-23-2005, 12:55 AM   #6
shemoves
Member#: 80663
2005 STi
after doing it...agreed
Old 08-24-2005, 09:56 AM   #7
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
When filling mine up, I just dumped it into the upper radiator hose until it was full and finished it the rest of the way woth the remote reservoir.
IronMonkeyL255 is offline   Reply With Quote
FS: EJ22-T or 2.2t closed deck Long Block 700 BoostLeeK Engine/Power/Exhaust 0 08-13-2008 11:13 PM
2.2t or 2.5 STI Motor SLO_02WRX Built Motor Discussion 2 03-29-2007 03:06 PM
CT 02 Aspen White wrx/ w/axis 2.2t motor SBW Private Vehicle 'For Sale' Classifieds 50 11-19-2005 02:51 PM
1995 impreza with 2.2T motor swap james_gt Private Vehicle 'For Sale' Classifieds 94 09-21-2004 09:32 PM
Open deck 2.5 and closed deck 2.2t blcok pics inside bill harvey New England Impreza Club Forum -- NESIC 21 04-29-2001 05:11 PM
