Old 08-21-2005, 06:17 AM   #1
95turbocoupe
Member#: 57218
Default which motor
i am trying to decided on what motor to use. Either of these motors will be new short blocks.First a new usdm sti short block.Second a new ej22t short block.Or third a rebuilt phase 1 2.5 with forged rods and pistons. i'm looking for the best bang for the buck. most reliable and strongest motor. planning on running 12psi on the street & 15-20 with C16 race gas at the track.someone please help me decided. thanks for any help
95turbocoupe is offline   Reply With Quote
Old 08-21-2005, 10:03 AM   #2
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
what heads will you be using? if your car is a 95, and it's a coupe... then it most likely had the EJ22E to start with right? With those heads, you will *want* the EJ22T shortblock. Going with the EJ25 (any) will result in high(er) compression.
an EJ257 block with EJ22 (N/A or Turbo heads, they are virtually the same) will net you ~9:1 CR, i could get you the exact CR if I had the numbers on the cc of the pistons, piston deck measurement, (which I'd need the wrist pin information.... ect.) but to know it's close to 9:1 give or take a little, I think is what matters.
But hey, you may think 9:1 is just perfect for you. I think for my next turbo setup I will want closer to 7.5:1.
JonofScio is offline   Reply With Quote
Old 08-22-2005, 03:03 AM   #3
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
i would go with the ej22t block with a sti crank and forged pistons and rods to give you 2.5 liters and 99 rs sohc heads. you'd have a 2.5 bullet proof motor. do the work yourself and some some dough. but if you dont want to spend that much just go with a sti sb and forged pistons. still good but not as good as the ej22t. - IC
IdenityCrisis is offline   Reply With Quote
Old 08-22-2005, 03:33 AM   #4
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Not quite- you must use a phase 1 crank with a ej22t block unless you want to do a lot of machining. You can use a crank from any phase 1 2.5 engine an sti crank will not work.
Drac9 is offline   Reply With Quote
Old 08-22-2005, 07:31 AM   #5
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
Old 08-22-2005, 11:51 AM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
It's not really about how much PSI you want, it's how much power you want. 15psi on some turbos is A LOT compared to some turbos...
How much power? OR what are you trying to build? daily driver weekend race/track?
FuJi K is offline   Reply With Quote
Old 08-22-2005, 01:36 PM   #7
95turbocoupe
Member#: 57218
i have a stock ported out grand national turbo looking to make 350 horses if this will help the heads are ported and polished ej2.2 heads 540cc injectors and a 550cc fith injector that comes on at 10psi also a afc and a fmic. the first motor was a phase 1 with je pistons but i bust some thing. and didn't like that motor because of the piston slap. looking for a stronger motor
Old 08-22-2005, 02:33 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I'm not too sure on the specs of that turbo, but....the STi shortblock is good enough to make you relieble 350whp if you're lookin at that.
my setup is a bit different from yours.
built EJ22T w/ DOHC 2.5L heads w/ JUN stuff, 840cc injectors, FMIC, GT30R garrett turbo. But I'm looking for 400whp though....that's like...470crank hp
Old 08-22-2005, 05:46 PM   #9
Aphex
Member#: 146
'16 WRX Limited
could always buy my shortblock and JE pistons block is split and ready to be machined even!
http://forums.nasioc.com/forums/showthread.php?t=818766
Aphex is offline   Reply With Quote
Old 08-22-2005, 09:36 PM   #10
02 wrx sti JDM
Member#: 94251
+1 for that
02 wrx sti JDM is offline   Reply With Quote
Old 08-23-2005, 06:04 AM   #11
95turbocoupe
Member#: 57218
what phase is the motor
Turbo motor into Porsche 914. Which motor to use and where to get it? pktzygt Subaru Conversions 18 11-08-2008 04:52 PM
914 with subie motor and tranny which motor combo? charliew Subaru Conversions 6 05-02-2008 06:21 PM
Which motor plan? 2000wrx General Community 4 02-13-2005 12:08 PM
which motor should i get? sideways slut Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-13-2003 06:03 PM
