Old 08-21-2005, 01:55 PM   #1
emyselfandi
Member#: 83701
Default 2.2L engine question
Just a question for you fellas.. My wife has a 95 subaru legacy and i noticed that the overflow bottle was always low over the past few weeks. I added des. water and thought it was just the heat and her long commute. Well I looked under the suby this am and it seems that there is a small drip on the back of the oil pan. I looked at the cylinder heads (flat 4) and the tops halfs look good. What I can see of the bottoms look okay as well. I changed teh oil 800 miles ago and it was clean and black. No foam or creamy look to it. What could this be from? I am leaning towards a bad cylinder head gasket but what else could i be looking at? Both the upper and lower hoses look good and don't leak. i guess it could also be the water pump but it is behind all hte timing belt covers... any insight? TIA, Tim
emyselfandi is offline   Reply With Quote
Old 08-21-2005, 06:38 PM   #2
whoosh
Member#: 40989
OT vag inspector
rb
search "head gasket recall" at nasioc.
http://forums.nasioc.com/forums/show...+gasket+recall
whoosh is offline   Reply With Quote
Old 08-21-2005, 09:04 PM   #3
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
The 2.2 Litre engines were not polled under the head gasket recall poll above.
While the 2.2 litre has an excellent reliability record, it is not immune from an occasional head gasket failure. My thoughts would be to "fix" the water pump, then do the head gaskets, if the water pump replacement doesnt do the trick.
Jonathan is offline   Reply With Quote
FS: Version 2 STi Intercooler, Subaru Water to Air Intercooler, FSB, 2.2L engine munkis Tri-State Area Private Classifieds 0 11-14-2008 10:32 AM
question about the 2.2L engines.... irishhockeypimp Normally Aspirated Powertrain 15 01-09-2006 11:10 AM
2.2l engine questions Valric New England Impreza Club Forum -- NESIC 2 03-06-2003 12:23 PM
2.2l Engine For Sale Rags North West Impreza Club Forum -- NWIC 12 11-28-2001 09:33 PM
'95 2.2L engine same as '97 2.2L? I need the part quick! chyisan Normally Aspirated Powertrain 1 12-22-2000 04:33 PM
