Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 08-23-2005, 02:32 PM   #1
AK'S REX
Member#: 12163
Default STI axle seal replacement?'s
I just ordered what I hope to be the right axle seals for my new 6 speed, as it didn't want to hold fluid w/o them I will hopefully be picking these up from the dealer tomorrow. I'm using WRX axles w/ the necessary axle stubs and circlips for installation, and I believe that the 6 speed is an 04' USDM.
My question is if I have to remove the differential retainer plates to get to the front axle seals? It looks like this is the case. If so, what is the best way to go about doing this? As I now have to measure for preload and set this thing up properly.
Any help would be greatly appreciated.
-Adam
AK'S REX is offline   Reply With Quote
Old 08-26-2005, 12:16 PM   #2
AK'S REX
Member#: 12163
Finally going to dealer today to get seals. Anybody ever change these? I'm sure im not the first.
Any help would be appreciated.
Thanks,
-Adam
Old 08-26-2005, 01:43 PM   #3
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Yes, I have replaced them and you must remove the retainer/backlash plates to install them and they are also directional, so make sure you check that the arrow is showing the correct direction on the seals.
Kev
Crazykev is offline   Reply With Quote
Old 08-26-2005, 01:48 PM   #4
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Sorry, forgot to tell you that all you must do is mark them and count the spins out and reinstall them. Put plenty of lithium grease on the stub shafts and seals to they don't get caught up on anything. Do one at a time!
I am assuming you have the tranny in the car, correct?
Kev
Old 08-26-2005, 04:57 PM   #5
AK'S REX
Member#: 12163
yep it in alright. Whats the best way to remove these things? Hammer and some sort of punch that wont damage them, or do I really need this special tool?
Thanks,
-Adam
Old 09-12-2006, 01:26 PM   #6
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
this is the only thread i've read where anyone talks of having to take out the retainer/backlash plates... sure this is necessary for just replacing a seal? just dont want to mess with it if i dont have to...
thanks,
bryan
Wrinkleboi is offline   Reply With Quote
Old 09-12-2006, 02:02 PM   #7
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
subscribed..also intrested
fastnoypi is offline   Reply With Quote
Old 09-20-2006, 11:25 PM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
bump..anyone come up with a more safer method to remove the retainer/backlash plates than the caveman method with a hammer?
FYI the service tools are around $260 for R/L side
Old 09-21-2006, 10:43 AM   #9
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I use a spanner wrench that I had laying around. Like the ones used to adjust coilover shocks.
Old 09-21-2006, 05:26 PM   #10
Rickyh
Member#: 40453
I just changed an axle seal in my 5mt. I used a punch and a mallet. Tapped it a little at a time and it came right off.
Rickyh is offline   Reply With Quote
Old 09-22-2006, 09:56 PM   #11
Wrinkleboi
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
a punch? dont you have to pull? i'm in the process of doing mine now... i got a 'seal puller' from autozone for $7, and it did the trick, i scoured the tranny a bit but on recommendation from a tech i cleaned it up and used permatex gasket sealant in there so i think it should be fine. just be careful to only hook the lip of the seal slightly and try not to push outward and scour the metal insert of the tranny housing as you pull the seal out.
as for popping the axle out of the 6MT a 25" prybar between the tranny housing and green cv boot case did the trick. i believe its different for the 5MTs though becaue the circlip has to be removed from the inside.
How To: Axle Seal Replacement (on an STi) Wrinkleboi Transmission (AT/MT) & Driveline 56 02-23-2015 11:28 AM
05 sti axle seal keeps leaking replaced 2 times moorebl Transmission (AT/MT) & Driveline 13 06-19-2011 06:56 PM
02 WRX axle seal replacement info needed spdfrk77 Transmission (AT/MT) & Driveline 1 07-08-2007 03:54 PM
Axle Seal Replacement Info Needed Cavadini Transmission (AT/MT) & Driveline 7 09-22-2006 04:04 PM
How many have had rear diff axle seals replaced under warranty?? donjuan Normally Aspirated Powertrain 2 07-18-2001 09:33 PM
