Mid Atlantic Impreza Club
Old 08-23-2005, 06:02 PM   #1
InvertedB
Member#: 82455
Chapter/Region: HIIC
2006 Saab 9-3 2.0T
SportCombi
Exclamation Rubbing Sound Making Left Turns
I just started noticing this weekend a kind of "whooshing" sound when I would make hard left turns like at signal lights or pulling into parking spaces. I tried looking to see if I could see anything when I pulled into a parking spot, but saw nothing. Thought maybe it was a branch or something and was gone, but then I heard it again later. If anyone has experience with this kind of problem in the past, please let me know, I'd like to take care of it before it turns into a real problem.
Thanks,
Jon
InvertedB is offline   Reply With Quote
Old 08-23-2005, 06:43 PM   #2
That_Azn_Guy
Member#: 92531
2002 PSM WRX
Andrewtech/ej207
i have the same problem but when i make right turns
That_Azn_Guy is offline   Reply With Quote
Old 08-23-2005, 07:37 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Is the sound coming from the front or rear?
A couple of the more common items are either drive axle shaft joints or wheel bearings. For wheel bearings, typically they’ll begin making noise whenever the load is shifted between the bearings (i.e. turning left or right is louder than rolling strait). I recently had one go which I had carelessly ignored for too long and it took the hub with it. If you see evidence of grease on the inside of wheel (from getting spun out of the damaged bearing) then act fast and get it changed.
For drive axle shafts, you can inspect the inner and outer boots for signs of damage or grease loss. These are easily inspected as a tear or the loss of grease is very evident when failing.
Good luck..
xcntrk75 is offline   Reply With Quote
Old 08-23-2005, 07:56 PM   #4
timeless
Member#: 46316
30R STI 440 whp/wtq
Prodrive gc010e 18x9.5+25
Do you have aftermarket headers?
If yes, some headers come into contact with the subframe when the car is tossed around.
During regular driving conditions, the engine can shift considerably resulting in aftermarket header/uppipe rubbing on the subframe.
The Fix.
Aftermarket engine mounts (i.e. STi Group N or Cusco).
Not sure if this can remedy your rubbing noise but just my two cents.
timeless is offline   Reply With Quote
Old 08-23-2005, 10:16 PM   #5
InvertedB
Member#: 82455
2006 Saab 9-3 2.0T
SportCombi
I don't have aftermarket headers, but I will definitely be sure to check for grease. I can't say I noticed any when I inspected it to try and determine signs of wear, though my car is really dirty right now since I was away, so I may not have noticed.
Thanks,
Jon
Old 08-24-2005, 02:35 AM   #6
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
Stock wheels and tires?
BAC5.2 is offline   Reply With Quote
Old 08-24-2005, 08:23 AM   #7
InvertedB
Member#: 82455
2006 Saab 9-3 2.0T
SportCombi
No, that's what I was checking first and going to check again. They're 18x7.5 5Zigen FN01R-C with 225/40/18 Falken's on them. Never had the problem before this weekend though and the last time the tires were off the car was in March.
Old 08-24-2005, 10:48 AM   #8
BAC5.2
Member#: 43996
The Aggressive (tm)
Check the tires for wear indication. Something could have started rubbing (fender liner come loose, or something like that.
Loud Rubbing/Scraping on Left turns LickwidS0ap Newbies & FAQs 15 09-17-2008 10:38 AM
Metal on metal sound from rear passenger wheel when making Left turns The_Triton Brakes, Steering & Suspension 2 06-09-2008 07:13 PM
Rubbing sound on right turns evil02wrx Newbies & FAQs 26 08-24-2006 06:30 PM
Rubbing Sound Making Left Turns InvertedB Brakes, Steering & Suspension 1 08-23-2005 07:03 PM
loud groan while making left turn WRXout Transmission (AT/MT) & Driveline 3 08-30-2004 03:46 PM
