Old 08-23-2005, 09:50 PM   #1
Irishman
Member#: 29933
2004 STI
Silver/Silver
Default Who's running a 20G with aftermarket TMIC?
I was wondering if this is possible or if I will have to run a FMIC? I am trying to make it as stealth as possible. What kind of numbers are you seeing?
Irishman is offline   Reply With Quote
Old 08-23-2005, 10:42 PM   #2
teh sash
Member#: 79329
PM powerleak, hes running a green similiar to a 20g with a TMIC. now hes running a sz55! theres many aftermarket turbos producing good #'s with a tmic. Like the gruppe-s GT30 kit & the atp kit. good luck...
teh sash is offline   Reply With Quote
Old 08-23-2005, 11:26 PM   #3
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
I'm currenty running a 20g with a tmic. Soon I'll be running a SZ49 on my spearco tmic. From what I have been told the 20g should be fine with a tmic(stock or aftermarket).
fastwrx006 is offline   Reply With Quote
Old 08-23-2005, 11:42 PM   #4
funktrain
Member#: 65145
2005 STi
World Rally Blue
Interested in hearing more about this also.
funktrain is offline   Reply With Quote
Old 08-24-2005, 02:31 AM   #5
kettsupp
Member#: 68891
he's actually running the sz60 not the sz55
kettsupp is offline   Reply With Quote
Old 08-24-2005, 09:32 AM   #6
titsataki
Member#: 4402
I think he running it with the stock TMIC due to fitment issues.
Clarification: due to TMIC bracket fitment issues.
I personally have had a SZilla with a Spearco TMIC and it was close but it fit fine.
Cheers
Nick
titsataki is offline   Reply With Quote
Old 08-24-2005, 09:58 AM   #7
burnin4
Member#: 59764
10 sec STi
10 sec Z06
i had a hyperflow tmic with my 20g. i ended up going to a fmic within 3 months. a tmic will do the job, but you will be leaving a lot of hp on the table. here's an old picture of the setup...
http://img.photobucket.com/albums/v7...4/DSC02142.jpg
http://img.photobucket.com/albums/v7.../DSC022331.jpg
burnin4 is offline   Reply With Quote
Old 08-24-2005, 10:09 AM   #8
pux888
Member#: 8356
02 STi swap
12 WRX limited
how much power did you pick up by going w/ the fmic?
pux888 is offline   Reply With Quote
Old 08-24-2005, 10:14 AM   #9
ESEMES
Member#: 67128
2001 996TT
seal
BURN-
how'd the splitter skirt mate up to the hyperflow tmic?
-ese
ESEMES is offline   Reply With Quote
Old 08-24-2005, 11:41 AM   #10
T3RMIN4L
Member#: 37434
sr55 with a spearco here. on the dyno it proved to be VERY hard to tune but once on the street we were able to add a couple degrees of timing and a couple pounds of boost. I will most likely go fmic or air/water sooner than later but its doable and spoolup is quite nice.
T3RMIN4L is offline   Reply With Quote
Old 08-24-2005, 12:16 PM   #11
wrex03
Member#: 29963
04 sti
Green and txs tmic here. As stated above your only draw back is really on the dyno. On the street it shines..
wrex03 is offline   Reply With Quote
Old 08-24-2005, 12:29 PM   #12
T3RMIN4L
Member#: 37434
One other thing worth mentioning is that you really need to be aware of heatsoak on the street with a tmic. If you jsut got done a couple 1-4 pulls and you roll up to a light you might want to be thinking in the back of your head that your intercooelr is prolly a skillet until you start getting airflow back over it again.
Old 08-24-2005, 12:49 PM   #13
powerleak
Member#: 72571
04 STI
nice to see my buddies posting for me hi AJ & Sashin!!
i'm running an sz60 with the stock sti tmic so a 20g, sz49 or green(ol faithful) will work just fine for a daily driven setup.
with my setup though, the stock tmic needs to be replaced with either an fmic or a larger bar/plate since flow restriction seems to be an issue.
powerleak is offline   Reply With Quote
Old 08-24-2005, 03:18 PM   #14
STi Hunter
Member#: 58131
05 STi 6,879 miles
04 Forester XT
Impreza WRX STi Could you elaborate?
T3RMIN4L
Would you elaborate a bit on where the difficulty comes from when tuning this combo on the dyno? The more detail the better, as tuning is one of my favorite topics of discussion.
I'm just curious...
STi Hunter is offline   Reply With Quote
Old 08-24-2005, 03:30 PM   #15
T3RMIN4L
Member#: 37434
Well, we didnt have a fan that we could position over the top mount so were either holding one off to the side or directing as best as possible which provided little to no airflow through the tmic. It was so bad that from cold at idle it would be too hot to touch by about 6K on ONE pull. We couldnt advance timing over 19 degrees up top nor could we run more than 19psi. On the street we pulled a couple tenths of fuel added 2-3 degrees and added 2-3 psi and it felt noticably better and knock was MUCH quieter.
Old 08-24-2005, 03:34 PM   #16
T3RMIN4L
Member#: 37434
My setup is as follows jsut for reference:
SR55 ported polished and coated gate welded shut
Stock header ported polished and coated
Stock intake manni and tgv deletes ported and polished
UR 2" uppipe ported polished and coated
Spearco tmic
PE 850's flowtested within 2%
HYDRA tuned by Phil of Element
44mm tial gate venting to atmosphere
Old 08-24-2005, 04:04 PM   #17
cpasti
Member#: 50582
What radiator is that? I've been thinking a radiator and maybe oil cooler upgrade for track days might be first before a new turbo.
cpasti is offline   Reply With Quote
Old 08-24-2005, 05:14 PM   #18
burnin4
Member#: 59764
10 sec STi
10 sec Z06
when I went with the fmic I also upgraded to the sz49, so it's hard to say. jgheels has a 20g, went from a tmic to a fmic and increased about 15whp, he can correct me if I'm wrong.
Old 08-24-2005, 05:17 PM   #19
burnin4
Member#: 59764
10 sec STi
10 sec Z06
Originally Posted by ESEMES
BURN-
-ese
the splitter skirt was completely removed, wouldnt fit. the hyperflow tmic also rubbed the hood, made some nice scratches on the ic and on the underside of the hood. the hyperflow tmic does look pretty
Old 08-24-2005, 05:23 PM   #20
burnin4
Member#: 59764
10 sec STi
10 sec Z06
pwr aluminum radiator, $400 shipped. havent really noticed any cooler temps, but added it for security when i installed the fmic.
Old 08-24-2005, 05:28 PM   #21
burnin4
Member#: 59764
10 sec STi
10 sec Z06
one other thing worth mentioning is heat soak at the dragstrip. everytime I drove to the dragstrip, my tmic would soak up heat the entire time I was there, and would never cool down, even if I let it sit for 1-2 hours. Stagging lines are a pita, cause your tmic is going to absord all the heat while inching forward to the line. Of course once you got moving it would cool down, but that wont performance in 1-2gear.
Old 08-24-2005, 05:32 PM   #22
pux888
Member#: 8356
02 STi swap
12 WRX limited
not to take things off the topic here but which setup do you like better? i love the way a 20g spools but another 30whp or so up top would be nice as well.
Old 08-24-2005, 06:12 PM   #23
burnin4
Member#: 59764
10 sec STi
10 sec Z06
oh boy....checkout this thread I wrote on the 2 turbos...
http://www.iwsti.com/forums/showthread.php?t=31211
Old 08-24-2005, 08:23 PM   #24
pux888
Member#: 8356
02 STi swap
12 WRX limited
nice.
20G with SSAC TMIC or STI TMIC Liam Newbies & FAQs 4 10-11-2007 11:36 AM
Who's running a 20g with stock intake? Calitri-Boost Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-04-2007 08:34 AM
For those with aftermarket TMIC derck_mullin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-03-2004 11:05 PM
Who's running 22mm front with 20mm rear bars? JGard Brakes, Steering & Suspension 4 03-23-2001 08:39 PM
who's running 12's and with what mods imprezive General Forum Archive 1 07-23-2000 09:44 PM
