Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 08-24-2005, 12:10 PM   #1
vadim
Member#: 31981
2003 WRX Sedan
Default Should utec show any values in dashboard when not connected to the car?
I bought a used utec and I don't have the time to put it into the car but when connected to it via serial port it shows some values in dashboard,
like 73-74% TPS, 6-10% boost and etc, why?
is it supposed to do that or something is wrong?
vadim is offline   Reply With Quote
Old 08-24-2005, 01:49 PM   #2
vadim
Member#: 31981
2003 WRX Sedan
bump.............
Old 08-24-2005, 02:14 PM   #3
Timdog1650
Member#: 45516
MY04 STi
does it really matter? Don't worry about it until you put it in your car and doesn't work properly. It's a 5 minute install, it's not the end of the world if you throw it in and something's wrong. Try it out before getting upset....
Timdog1650 is offline   Reply With Quote
Old 08-25-2005, 09:24 AM   #4
2phless
Member#: 69343
1998 TransAm cnvrtbl
It shows values because you have open inputs on several integrated circuits. Several of which are very sensitive and very inconsistant in production accuracy (thus the need for several user settings instead of them auto-adjusting.) Things will happen to those inputs dues to micro-volt fluctuations, and with open inputs it's seeing that from ambient RF off monitors, lights, the sun, static. It could display any number of odd readings.
Just be carefull that you are grounded and don't static the box to death. Best way... just put it in. If nothing else you can set everything to ECU until you learn all the in and outs.
2phless is offline   Reply With Quote
New member, not new to the car Gnome18 North West Impreza Club Forum -- NWIC 13 02-10-2010 01:31 AM
Will utec log knock events in log when not in control? MAP 0 NITROS UTEC 1 08-21-2007 11:55 AM
Should this not connect to anything Jdex Newbies & FAQs 11 12-04-2006 02:43 PM
Any value in Grp B car? CosmoTheCat North West Impreza Club Forum -- NWIC 10 04-05-2003 10:46 AM
In a forum, NOT devoted to the STi... SubEd New England Impreza Club Forum -- NESIC 14 01-10-2003 08:51 AM
