Old 08-24-2005, 12:06 PM   #1
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
Default injection questions..smc kit..50/50 water denatured or 50/50 water methanol...discuss
smc kit....which option is more cost effective and most beneficial power wise? Plus I have hear that methanol is very corrosive? Whats the best way to go?
mpower22 is offline   Reply With Quote
Old 08-24-2005, 12:51 PM   #2
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
Yes, it's been reported that methanol can corrode given enough time. It's also a PITA to source IMHO. From the reading I've done most have opted for a 50/50 denatured alcohol/distilled water blend. Straight denatured is flammable enough to warrant second thoughts (as you'd have a gallon +/- right next to the engine) whereas a blend will be less likely to erupt in a fireball if you developed a leak (extremely unlikely from my research, but a concern all the same). I'm 98% sure that straight methanol would give a fairly considerable gain over a denatured/water blend, but can't back that up with #'s.
I'm having the SMC kit installed as we speak, and chose 50/50 denatured/distilled. HTH.
mindchatter is offline   Reply With Quote
Old 08-24-2005, 01:01 PM   #3
powerleak
Member#: 72571
04 STI
i have the smc kit on my car and run straight ethanol (denatured alcohol). steve at smc recommends this although there is nothing wrong with running methanol or 50/50 mix. yes methanol is very corrosive and it can gel. if you do a search on the web for alcohol, methanol and water injection. you can find articles from people including hot rod enthusiasts that have been using this stuff for quite a long time. ethanol costs me about $10/gal and currently lasts me for a month or two. when i first got the kit installed, i burned up the whole gallon before my 2nd tank of gas was empty.
powerleak is offline   Reply With Quote
Old 08-24-2005, 01:05 PM   #4
mpower22
Member#: 58352
04 20G STI(SOLD)
cool but is there any information that running strait denatured leads to x while runiing a 50/50 leads to y? I'm trying to do a cost benefit and need to know these factors...is running strait denatured worth the extra cost or will it only yield an extra 5 hp and cost twice as much?
Matt
Old 08-24-2005, 01:11 PM   #5
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Matt
On your turbo and setup, run 50/50.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-24-2005, 01:16 PM   #6
mpower22
Member#: 58352
04 20G STI(SOLD)
Jorge (RiftsWRX)
www.ProjectWRX.com
yes sir....now to talk sean at exteme into buying a 55 gallon jug and doing a group sell
Old 08-24-2005, 01:23 PM   #7
powerleak
Member#: 72571
04 STI
Jorge (RiftsWRX)
www.ProjectWRX.com
what benefits have you noticed for the 50/50 mix vs straight ethanol or methanol? you have me curious since even steve at smc says he runs just straight ethanol...
Old 08-24-2005, 01:27 PM   #8
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
He just installed a kit on a customer evo. I saw a gallon can of Ace denatured there, but if he starts setting up more evos with it, there is the possibility. You should be able to find it in bulk at some other chemical stores though, and probably cheaper.
Jorge could also give you a map for 50/50 and one for 100% denatured. It's not like you have to empty the fuel tank to go from one setup to the other.
And BTW, you've got me looking at alky injection, bastid!
Frank
fmowry is offline   Reply With Quote
Old 08-24-2005, 01:32 PM   #9
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
E85 is 85% ethanol, 15% regular gas. How about a 60/40 mix of E85/distilled water for alky injection?
You can get that at a couple pumps in MD:
http://www.e85fuel.com/database/loca...ate=mdMaryland
Frank
Old 08-24-2005, 01:34 PM   #10
mpower22
Member#: 58352
04 20G STI(SOLD)
Frank
I just pm'd you..I have a favor to ask...can I get your contact info again?
Matt
Old 08-24-2005, 01:37 PM   #11
powerleak
Member#: 72571
04 STI
Frank
you might as well just fill up with e85 completely and have your car tuned for it instead. "hot rod" started a nice thread regarding it, you could find his old post on it.
Old 08-24-2005, 01:55 PM   #12
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
The only reason I do it is to avert the fireball waiting to happen in the car that carries my 11 month old son in it as well.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 08-24-2005, 01:57 PM   #13
mpower22
Member#: 58352
04 20G STI(SOLD)
Jorge (RiftsWRX)
www.ProjectWRX.com
laughs considering my car was just about a fireball on the dyno two weeks ago ..I'll take your advice Jorge.....
Old 08-24-2005, 02:52 PM   #14
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
I don't want to drive to the 3 locations that sell it in my state every time I need to fill up.
Frank
Old 08-24-2005, 03:05 PM   #15
mpower22
Member#: 58352
04 20G STI(SOLD)
Frank
well I'm trying to go halfsies with extreme on a 55 gallon....it would be pretty cheap...IF you are getting an alchy kit...... you know you want to...I'm working with stseve at SMC..trying to get him to become a vender and do a group by....I'm actually talking to him about some sponsorship stuff.....
Matt
Old 08-24-2005, 03:09 PM   #16
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
Matt
55 gallon drum of denatured alky? Just put it in your trunk and run the lines directly.
I noticed Jorge made almost the exact same comment regarding E85 and alky injection in hotrods thread.
Frank
Old 08-24-2005, 04:56 PM   #17
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
I had my kit installed, but I haven't been tuned yet because of a bad controller. I ultimately decided on a 50/50 mix for two reasons: a) the fire hazard of one gallon of pure ethanol under the hood (anyone who has ever lit grain alcohol ablaze knows what I am talking about) and b) the water is magic for bringing down combustion chamber temps (since it is not a fuel). Since water is not a fuel, I am guessing the power advantage is to straight ethanol, but with water you get the safety margin and a steam clean
Nixlimited is offline   Reply With Quote
Old 08-24-2005, 05:42 PM   #18
powerleak
Member#: 72571
04 STI
water is a product of ethanol burning... you'll get the steam clean affect regardless
if you guys are really scared about the alcohol under the hood, why don't you just convert the intercooler sprayer tank to hold it instead or get a better sealed container. if i get into an accident that causes the tank to rupture and spill in the engine bay. i'll be lucky to walkaway from it and i won't be worrying about my car burning down
nix - p.s. steve has your controller in the mail.
Old 08-24-2005, 07:31 PM   #19
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Didn't know that you knew him! He has been supremely helpful and prompt with me which makes me care less that the unit didn't work initially. He is doing a little custom work for me on the unit...pics in two weeks when I get it installed.
Also, even though water is a by-product (thus the nice cleaning), you will not get the heat absorption of evaporating liquid water in the combustion chamber (since I think the water produced by burning alcohol will already be vapor - and hot vapor at that)
Old 08-24-2005, 11:12 PM   #20
titsataki
Member#: 4402
I am working on getting a spec C water caontainer and using it for alcohol. But it has been very hard to source one. Most vendors are like I can get you one in 6 weeks.
Nick
titsataki is offline   Reply With Quote
Old 08-25-2005, 10:05 AM   #21
mpower22
Member#: 58352
04 20G STI(SOLD)
can a 50/50 mix of denatured/water freeze in the winter?
Old 08-25-2005, 10:11 AM   #22
TheMadScientist
Member#: 23717
2005 Big red
Will vodka? Same thing.
TMS
TheMadScientist is offline   Reply With Quote
Old 08-25-2005, 10:14 AM   #23
mpower22
Member#: 58352
04 20G STI(SOLD)
TMS
makes ense I guess it would have to get real cold....
I'm just confused on using a mix of water and denatured or water and meth....
Old 08-25-2005, 10:14 AM   #24
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
TMS
DING DING DING
Old 08-25-2005, 10:23 AM   #25
TheMadScientist
Member#: 23717
2005 Big red
Pure ethanol has a melting point of -144*C. I am not sure of how you would calculate the melting point for a mix. Is it a straight ratio?
Melting point and freeze point are the same thing.
TMS
Water/Methanol Injection question davidsti1 Water/Methanol Injection, Nitrous & Intercooler Cooling 3 08-19-2009 08:16 AM
Snow performance water/methanol injection stg. 2 kit zoki87 Engine/Power/Exhaust 7 09-03-2008 11:08 AM
water/methanol/alcohol injection question hock3ysniper Water/Methanol Injection, Nitrous & Intercooler Cooling 6 04-30-2008 05:39 PM
SMC kit running 100% methanol tune? djerickd Water/Methanol Injection, Nitrous & Intercooler Cooling 131 09-14-2006 05:15 AM
New Methanol Injection Trunk Mount Kit! Coolingmist Engine/Power/Exhaust 0 05-24-2006 07:35 PM
