Old 08-25-2005, 12:01 AM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default 1/4 mile time with stock rims vs. heavier rims
I have replaced my summer/track setup with OEM rim/tire. What kind of improvement in 1/4 mile would I expect with lighter setup? My best time with heavier set up was [email protected] with 1.90 60' time.
My car feels noticeably lighter with OEM set up as there are about 40 lbs difference between the two (unsprung weight). If same 60' time is achieved, how much of an improvement in either time or trap speed is expected? Once car is in motion, is weight of rim/tire as crucial?
Thanks in advance,
Old 08-25-2005, 01:05 AM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
some people have reported no difference between 18 and stock, actually same time, i think the difference between 17 and stock would be hard to tell.
bren wrx is offline   Reply With Quote
Old 08-25-2005, 01:14 AM   #3
SpoolinU
Member#: 58263
2004 STI
Blue with silver
I would say negligible......maybe 13.4 around the same speed in theory due to losing 40lbs off the car.
SpoolinU is offline   Reply With Quote
Old 08-25-2005, 01:23 AM   #4
..:bigFAT:..
Member#: 68826
2004 STi
flat blue, next ??
how do you get .39 sec difference with saving only 40lbs from the rims? come on its all in your head
..:bigFAT:.. is offline   Reply With Quote
Old 08-25-2005, 02:59 AM   #5
gills
Member#: 11316
1988 E30 M3
S54
Thanks in advance,
I believe different offsets of wheels can affect how the car feels and reacts as well.
On FWD cars with very low torque, wheel weights and diameter play a much bigger role from my experience.
gills is offline   Reply With Quote
Old 08-25-2005, 04:29 AM   #6
Skully
Member#: 48990
98 Impreza RS
RBP
You have to look at how the weight is distributed on the stock rims/tires vs. aftermarkets. Even tho the new rims are bigger *weigh less* and there is less tire. More of the mass is moved outwards. Now, with stock rims/tires, the wheel/tire combo is heavier, but the weight more compact and is easier to be turned by the driveline components.
If anyone has anymore input or theories or want to add to what i said, please do. If im wrong. tell me.
-Thomas
Skully is offline   Reply With Quote
Old 08-25-2005, 08:12 AM   #7
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Stock setup is lighter.
Stocker with RE92 << P1 and RE070
Old 08-25-2005, 09:49 AM   #8
OzGC8
Member#: 93093
GC8 wrx
[email protected]
would say 13.5 @ 99/100mph
with same 60' ,shift points and traction
that is my experience out of 170passes and 3 sets of rims
which ones my car wears & loves the most???
Volks TE37 9 lbs per corner(15")
OzGC8 is offline   Reply With Quote
Old 08-25-2005, 04:49 PM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
WOW... I guess I will leave my OEM set up on and see how well my car does at the track.
Old 08-25-2005, 08:42 PM   #10
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Sport Compact Car article (Power, Grip, Weight) Januarry 2001 issue.
Car: 2000 Mitsubishi Eclipse GT
Wheels: All Enkei with BFGoodrich Comp T/A ZRs
Sizes:
225/50-16
225/45-17
225/40-18
Weights:
16" = 44.5lbs
17" = 47lbs
18" = 46lbs
Times:
16" = 15.5 at 89.4mph
17" = 15.5 at 89.0mph
18" = 15.6 at 87.9mph
A difference in size and only 3lbs per wheel can net a same time with 1.5mph of a difference in the 1/4 mile trap speed by a professional driver (Rhys Millen). This is with a 3lbs difference in wheel weight (total of 12lbs all 4 wheels). I'm sure a larger difference can be found with a larger weight difference in the wheels.
Kevin Thomas is offline   Reply With Quote
Old 08-25-2005, 08:59 PM   #11
turbokonejo
Member#: 68669
2000 Dodge Durango
Stock car rims/tires Sept 2002 [email protected] dont remember the rest.
TurboXS Tbe/intake/sti topmount July 2005 16 inch rota slips/snowtires [email protected]
turbokonejo is offline   Reply With Quote
Old 08-25-2005, 10:12 PM   #12
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
since 1.5 lbs resulted in 1.5mph of a difference, I would expect higher mph gain with 10 lbs of difference....
P1 in 17" = 20lbs
RE070 = 27lbs
Total = 47lbs
OEM rims = 16lbs
RE92 = 21lbs
Total = 37lbs
Old 08-26-2005, 11:37 AM   #13
SpoolinU
Member#: 58263
2004 STI
Blue with silver
Your right...I must have had a brain fart....should have been .039 off not .39 oops....ah well...pt was maybe he will be a tenth quicker cause shaving 40lbs of rotational mass is better then 40lbs of dead weight.
Old 08-26-2005, 03:23 PM   #14
UltimateLurker
Member#: 82488
06 Lotus Exige
Sizes:
225/50-16
225/45-17
225/40-18
Weights:
16" = 44.5lbs
17" = 47lbs
18" = 46lbs
Times:
It is impossible to recreate every factor to an exact proportion save for the wheel/tire combo. As a matter of fact, it's all but impossible to run the exact same time more than once, humans don't work that way, and perameters change after each run.
To the original poster: It is impossible to calculate, but matters not anyway, if you want to see how your car and your ability has changed, take it to the track, there is no other way.
UltimateLurker is offline   Reply With Quote
Old 08-26-2005, 07:07 PM   #15
metoo
Member#: 4764
2004 STi sold :(
forizzle
All those times are way too close to attribute them to the wheel/tire combo. Thoe only way to realy know is to make about 5 runs with each combo, going with a difference combo each run to sort of make up for environmental changes that effect the numbers.
I believe where weight really counts is in twisty races. Yes, it does count in drag too, but more so on tight tracks like auto-x. You'll get the most of wheel-weight-loss benefit when accelerating from lower speeds and braking.
metoo is offline   Reply With Quote
Old 08-26-2005, 11:56 PM   #16
Kevin Thomas
Member#: 110
1989 1989 XT6
Same article as I posted above but on a road course.
16" Lap time: 1:03.7, 96.1mph straight speed
17" Lap time: 1:03.2, 95.5mph straight speed
18" Lap time: 1:03.9, 95.0mph straight speed
The 16"ers had a higher trap speed on the long straight due to being lighter and smaller in wheel diameter but was 'squishy' around the turns. The 18"ers gave the most balanced handling but it cost lap time around the corners due to acceleration. The 17"ers had the best balance between acceleration and cornering.
Like UltimateLurker stated, you have to test on your own. Your car and setup may end up with different results for different reasons. I say this because in the article I ppsted about, wheel weights were tested on the Eclipse GT as well as a No ballast, 50-lbs ballast, 150-lbs ballast and 250-lbs ballast on the Eclipse as well. The ballasts were also tested on a 2160lbs Ford Focus (Eclipse was 3050lbs curb weight). The same ballasts had much more dramatic results on the lighter Ford Focus. I'm sure the wheel weight difference would've been more dramatic as well. Every car is different.
Old 08-27-2005, 12:06 AM   #17
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I need to direct Uncle Scotty here. I am not surprised by the near negligible results at all.
ss
subysouth is offline   Reply With Quote
sti 1/4 mile times for stock turbo and injectors with no nitrous whitesti04 Proven Power Bragging 59 05-08-2005 11:51 PM
First Time 1/4 mile time with new WRX unloadmydodads Proven Power Bragging 7 06-04-2003 01:10 AM
1/4 mile times with stage 4? b00st3d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-25-2002 10:36 AM
anyone have 1/4 mile times with ScoobySport exhaust bluperlrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-05-2001 06:52 AM
1/4 mile times for stock 2000 rs CHACHI Normally Aspirated Powertrain 5 06-19-2001 08:54 PM
