Old 08-25-2005, 01:11 AM   #1
Phy6
Member#: 2219
2007 Exige S
Smile FYI: Cleaned MAF, car runs smoother
[I also took out the cat and put the straight pipe back in, cat was not clogged]
Symptoms i was having:
~300 miles after putting NGK one step colder plugs...
hesitation when lightly or moderately accelerating in 3rd and/or 4th
Stumbling at idle, (can see it on the vaccuum/boost gauge, but very little on the rpm gauge)
I did what someone else suggested...took the MAF off and put it in a zip lock with about 1/3 cup of rubbing alcohol...and shook it vigerously. I did notice some particles in the alcohol afterwards.
Then i carefully took a Q tip dipped in alcohol and cleaned the sensor wire on the front side. Also cleaned up in the hole leading to it. It was pretty grimey!
After this, the car ran really well and was very smooth!!
The car does smell richer than before though...
Mods:
04 STi
UTEC
TXS TBE
FP Green
APS 650 FMIC
Worx BOV
Perrin Modifieds
TXS Shortram with K&N cone
godspeed radiator
Phy6 is offline   Reply With Quote
Old 08-25-2005, 11:29 PM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
so...what happened to the 57b?
sorry a little OT
Ben
Old 08-26-2005, 12:43 PM   #3
Phy6
Member#: 2219
2007 Exige S
It's still in the works. =) ETA unknown
MY97 Impreza 2.2L -- Cleaned MAF, now car won't stay running Nihilator Normally Aspirated Powertrain 29 09-06-2015 04:12 PM
Car running terribly - really REALLY low MAF numbers 0db Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-07-2010 12:53 PM
car runs horrible with maf plugged in but fine when not SethV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 06-15-2009 09:21 PM
How an EM can make my car run smoother?? BBBsti LTD Engine Management & Tuning 2 07-05-2005 10:44 AM
Makes the engine runs smoother? au112 Newbies & FAQs 1 03-05-2001 10:19 PM
