Old 08-25-2005, 11:46 AM   #1
subynube
Member#: 63442
Default Where is the coolant leak coming from?
I have 2002 WRX, no mods, 60K miles. After long drives, I smell a strong smell of coolant. I had the dealership check the coolant system and found no leaks, but I am sure it is there. Where are common areas that leak?
i have not had coolant flush in 30K miles, and I just added some coolant to the reservoir. Could this have anything to do with it?
Thanks
Josh
subynube is offline   Reply With Quote
Old 08-25-2005, 11:57 AM   #2
Student Driver
Member#: 65161
2002 2.5RS, AW
I can taste teh suck
You might not have a leak, but rather just have the smell. I have this issue to varying degress with both my RS and WRX. The RS was worse because I overfilled the resevior and it would slowly seep out as it heated up.
Student Driver is offline   Reply With Quote
Old 08-25-2005, 05:19 PM   #3
subarwho?
Member#: 94229
2002 wrx
psm
I had this problem, the harder I drove the car the more I could notice it, yet I could never find the leak.
It got worse and worse until one day(after a bout of particularly spirited driving) I noticed big gray plume of smoke coming our from behind the car. I pulled over and smoke started pooring out of the hood scoop.
I thought I had blown the engine so I brought it straight to subaru and it turns out the problem was a spring clip on a coolant hose located in the vacinity of the turbo. When I really got the engine wound up it would spray/drip onto the turbo heat sheild and burn off before i could find the leak.
I replaced the spring clip with new one and no problems since then. Pretty scary though.
subarwho? is offline   Reply With Quote
Old 08-25-2005, 05:50 PM   #4
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
I'm in the process of fixing this problem right now. Check the coolant line going into the turbo (from the reservoir there is a little almost z/s-shaped line). Mine leaks from there....not enough to see smoke, but I started smelling it one day and noticed a little coolant on my turbo (heatshield is currently off). It may just be the clamp, but if not, you will need to get the tube/line from the dealer. I tried using some regular fuel line, but it kinked up because the way the line needs to run.
YourMother'sLover is offline   Reply With Quote
Old 08-25-2005, 06:08 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
if you have the stock cap, the spring may get weak after a while.
Or thats what happened to me. Coolant would come past the spring and spill over around the top of the coolant header tank and evaporate off.
caution putting on a 1.3bar cap on a 02wrx, the plastic end tanks on your rad might break because of the pressure exerted.
fastnoypi is offline   Reply With Quote
Where is the lateral slop coming from? chimchimm5 Brakes, Steering & Suspension 18 10-06-2009 06:07 PM
Where is the coolant drain plug? phantasm Service & Maintenance 2 12-23-2003 08:26 PM
Where is the WRX weight coming from? jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 04-22-2002 02:49 AM
need help! where is the coolant sensor (EJ25 SOHC) ColinL Service & Maintenance 2 12-20-2001 05:56 PM
