Old 08-25-2005, 11:44 AM   #1
Mike1967
Member#: 87762
Default question on repacing heads / head gasket
Does the engine have to be pulled for this job or can I get to the heads with the engine still in the car ?
Mike1967 is offline   Reply With Quote
Old 08-25-2005, 11:58 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Which engine? Some of the cars pulling the heads with the engine is isn't too difficult. Others, like the DOHC's, I wouldn't even think about it. The two hours it will take you to pull the engine will be made up on the back end with dismantling and building it out of the car. At this point, since I can pull the motor in under an hour, I pull it for any major work...
Old 08-25-2005, 12:06 PM   #3
Mike1967
Member#: 87762
I have an SOHC 2.5 in a 1999 Forester
- What all needs to be removed from the engine to pull it ? ( I have started down the path already by pulling the AC condensor, radiator, battery, air filter housing, power steering pump and alternator.
- I am assuming that I would need to invest in both a "cherry picker" and an engine stand
Your thoughts/advise is greatly appreciated.
Old 08-25-2005, 12:36 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
Next you need to pull the heater hoses, brake booster, starter, and fuel lines. It is a good idea to disconnect the fuel pump and run the car until it dies to relieve fuel pressure before removing the lines.
From there, it is just the bolts that hold the engine to the tranny, the engine mounts themselves, and the pitch rod...
Doing a SOHC Ej25 in the car is possible, but still mostly a pain. I would remove it...
Old 08-25-2005, 12:38 PM   #5
Mike1967
Member#: 87762
I will pull it.
Do I also need to remove the overhead manifold, throttle body and A/C Condensor ?
Old 08-25-2005, 12:59 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
The manifold can be removed after the engine is out of the car. But you will need to remove the intake plumbing and MAF, as well as the AC condensor. The condensor can just be bunjied into the corner where the battery went. It doesn't need to be vented.
And I also forgot the exhaust manifold...
Old 08-25-2005, 01:00 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Oh,
And get the Chilton's guide or an FSM before you remove the heads. You want to stick to the very specific torque pattern or you risk warping the heads...
Old 08-25-2005, 01:03 PM   #8
Mike1967
Member#: 87762
Oh,
I already have the Chilton.
No way I could work on cars without those wonderful books !
So do I pull the AC Condensor, overhead manifold and throttle body prior to lifting it out.
I get nervouse taking everything apart because I have to put everything back together. Tear down is easy
Old 08-25-2005, 01:52 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
Just the AC. Leave the rest intact...
Old 08-25-2005, 02:43 PM   #10
Randoramma
Member#: 60649
00RS EJ205 swap
Are you sure you have to pull the brake booster? Also I would pull the radiator for sure.
Randoramma is offline   Reply With Quote
Old 08-25-2005, 02:53 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
How would you propose to get the motor out with the booster line still attached to the back of the manifold? You just remove the line.
And he already has the radiator out. He asked what else do I need to do...
Old 08-25-2005, 03:29 PM   #12
Mike1967
Member#: 87762
I cannot get to the back passenger side bolt on the AC Condensor. It is blocked by the overhead manifold. There is not enough clearance to get a socket onto the bolt. So looks like I will have to peel a "few more layers of the onion" while the engine is still in the car.
Old 08-25-2005, 04:56 PM   #13
Randoramma
Member#: 60649
00RS EJ205 swap
Hmm, I might be confused. Are you talking about the slave cylinnder, or the brake booster which is attached to the brake petal through the firewall? For the slave cylinder, I just unbolted that but never discharged the system.
Randy
Old 08-25-2005, 05:08 PM   #14
Mike1967
Member#: 87762
Randy
Im talking about the AC Condensor on the front of the engine (drivers side). It located next to the Alternator.
(oops) I just realized you were not replying to my last post. Please ignore this.
Old 08-25-2005, 05:52 PM   #15
Matt Monson
Member#: 832
99 2.5RS, '85 911
Mike,
Are you trying to remove the bracket or the condensor itself? You should be able to get a box wrench onto that last rear bolt to remove the condensor. Don't try and remove the bracket. I guess if you get too frustrated, you could remove the manifold. It is coming off later anyways. Just plug the head ports to keep the crap out...
Randy,
If you look under your hood, there is a hose that runs right next to the master cylinder to the back of the manifold. That's the hose. You shouldn't have to unbolt or discharge anything. It's just got a spring loaded hose clamp on it...
Old 08-25-2005, 05:58 PM   #16
Mike1967
Member#: 87762
Mike,
hmmm
That is a good question. I will take a closer look tonight. I do believe that I am taking off the bracket. I thought the condensor was part of the bracket.
Old 08-25-2005, 06:01 PM   #17
Mike1967
Member#: 87762
Darn..I already vented the AC. No problem though....I have a vacuum. I will also need to spring for a new dryer.
I'm going to show my ignorance here....but what is intake plumbing and MAF ?
Old 08-25-2005, 08:35 PM   #18
chip4761
Member#: 55867
2005 Saabaru
AS
I thought the thing next to the alternator was the a/c compressor, and the thing that looks like a smaller radiator was the a/c condensor. I could be wrong though...
chip4761 is offline   Reply With Quote
Old 08-25-2005, 09:48 PM   #19
Mike1967
Member#: 87762
Nope...you are 100% correct
Questions on V7 Heads on EJ205 block. 02WRXNY Built Motor Discussion 1 10-23-2008 02:50 PM
Intake gasket matching vs. port velocity on N/A heads Patrick Olsen Built Motor Discussion 7 01-11-2008 12:59 AM
pic of 2.5 head gasket on 2.2 head JoshP Normally Aspirated Powertrain 9 06-24-2006 01:26 AM
Another Question on replacing Head Gasket Mike1967 Normally Aspirated Powertrain 26 03-19-2006 06:03 PM
Question on EJ20 cylinder head volume. ChristophWRX Factory 2.0L Turbo Powertrain 2 10-01-2003 03:37 PM
Message Board Statistics All times are GMT -4. The time now is 10:10 AM.
