Old 08-25-2005, 02:07 PM   #1
zoomfactor
Member#: 30440
03 WRX
WR Blue
Default Inside Front Tire Wear - No Lift -- suggestions needed
I have been experiencing pretty nasty inside front tire wear - primarily as a result of wheel spin. At no time am I seeing lift, and no lift has been reported by others. This is only during auto-x. I've only got a modest power (in the STX-ESP range).
In another thread, KC indicated that it was an easy fix -- alignment and stiffening things up
I believe that the alignment is spot on-based on measured tire temps and the fact that I have "cloned" several of the settings used by the Nat'l folks. -2.5 Front (0-1/8 toe for auto-x), -1.5 to -1.7 rear. Where I differ is in spring rates (on Tein RA's) ~450 front ~400 rear. 22mm FSB/22-24mm RSB.
I favor the front biased spring rates due to the great high-speed balance it gives the car... as well as my planned schedule of increasing track duty. I am also introducing my kids to auto-x this fall - so I don't want a rotational monster - just a better balanced one.
1. Will a front diff solve my problems without requiring me to stiffen the rear spring rates?
2. Would a stiffer RSB help without stiffening the rear spring rates?
3. Or...am I just an ass? <----just put those 9-12 springs on the back and sut-up?
We've got a few test days coming up and I'd like to get some feedback before I ruin another set of tires.
zoomfactor is offline   Reply With Quote
Old 08-25-2005, 02:15 PM   #2
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Yes
Yes
Yes?
-Tom
trhoppe is offline   Reply With Quote
Old 08-25-2005, 03:24 PM   #3
zoomfactor
Member#: 30440
03 WRX
WR Blue
Man you are too much
Old 08-25-2005, 09:01 PM   #4
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I agree with Tom on #1 and #2. Oddly enough, I've seen the most inside tire spin and inner edge wear around -2.5 on the camber scale. Going to more, I've typically seen less. Haven't quite figured out why yet but so far those have been my results.
I'm going to see if I can replicate that with a different set of shocks and springrates but I have a hunch that it would come out about the same. Quite befuddled as to why really but thought I would share regardless.
-Biggly
DrBiggly is offline   Reply With Quote
Old 08-25-2005, 10:00 PM   #5
zoomfactor
Member#: 30440
03 WRX
WR Blue
I'm used to seeing a slight amount of increasing of wear as you move to the edge - but what I've got looks like the gremlins put the wheel on a router and shaved off rubber at almost a 30 degree angle at the extreme inside edge.
I'm going to tighten down the rear sway bay a notch. No front diff at this point, but if I've got to crack the case open I'll be replacing everything. ..the purchase of a new STi is now looking like a more "reasonable" outlay of cash
Old 08-25-2005, 10:38 PM   #6
solo-x
Member#: 37624
what is the loose nut behind the wheel doing? that much tire wear says to me that the car is pushing horribly and you're just cranking in steering input and throttle. not saying 100% that's the case here, but from the limited information given that would be my first guess.
btw, a local civic with a quiafe that runs in STX has the exact same tire wear patterns i have without a diff. this is with all of 125whp in my car and maybe 110whp in his. the ackerman combined with toe out, lots of camber, and aggressive launches are likely the cause of the wear. just a data point that would indicate that a front diff won't necessarily SOLVE the problem, but it may (and likely will) minimize it.
solo-x is offline   Reply With Quote
Old 08-25-2005, 10:44 PM   #7
ChrisDP
Member#: 5879
'02 WRX SDN 5MT
STS Civic, ITA Integra
I'm not really getting much of any weird inside wear patterns, can't say that I did with -2.5 camber or -3 to -3.5 like I've been playing with recently. I've got a lot of toe out right now which is putting a bit of an angle on the inside blocks, but it's nothing major. I think more rear bar will help pin the inside front down some.
ChrisDP is offline   Reply With Quote
Old 08-25-2005, 10:46 PM   #8
KC
Member#: 442
13 Crosstrek XV
00 S2000
Speaking of which.. what's your front toe?
KC is online now   Reply With Quote
Old 08-26-2005, 02:14 AM   #9
makofoto
Member#: 25243
2006 Legacy Outback
he said zero to 1/8th ...
Are you sure the wear isn't coming from the inside tires inside edge being dragged across the corners ...
Perhaps you should try your oem FSB ... so that the inside wheel can droop down to get better purchase.
makofoto is offline   Reply With Quote
Old 08-26-2005, 07:09 AM   #10
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
oem FSB == bad call.
-Tom
Old 08-26-2005, 11:36 AM   #11
zoomfactor
Member#: 30440
03 WRX
WR Blue
While I have a tendancy to overdrive a bit I don't think that is the problem. The current set-up suits my driving style and turn-in is sharp. The problem seems to be post-apex as soon as I roll on throttle I get enough spin to smell tire.
I really didn't think 50# difference in spring rates front-to-back would be that much of a problem. I think I need to try even spring rates.
Anybody got a set of Tein 8 kg/cm springs they want to get rid of
Old 08-26-2005, 01:13 PM   #12
makofoto
Member#: 25243
2006 Legacy Outback
yes ... I believe they are the 200 mm long ones ... from the rear of my Tein Flex's ... $50 including shipping. PM me your address if you're interested. I've used them on the rear and front of my Flex's. Front ones standard are 175 mm
If you have stiff enough springs ... you can go with lighter sway bars ... ioho :-)
Old 08-26-2005, 05:53 PM   #13
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
I had tire wear like that on my last set of tires. I think more caster and less toe helped the problem. I got a little better at teh driving also.
rex n effect is offline   Reply With Quote
Old 08-27-2005, 09:23 AM   #14
zoomfactor
Member#: 30440
03 WRX
WR Blue
Well Update...
Going up just one slot (23->24) on the RSB seems to have fixed the lift. Now I just need fatter rubber
Turn-in is scary fast
Mako - PM sent
2008 STI inside edge tire wear ?? ortim Brakes, Steering & Suspension 8 06-22-2009 11:04 PM
New RE730s wear inside front tires ThinkTank Brakes, Steering & Suspension 12 05-24-2002 01:54 AM
('93-'01) AWD: Front tires wear out first? codemunky Impreza Forum 8 06-13-2001 09:52 PM
Suggestions to correct inside front tire spin at auto-x? Patrick Olsen Technical Forum Archive 19 07-29-2000 12:17 AM
Suggestions to correct inside front tire spin at auto-x? Patrick Olsen Legacy Forum 3 07-26-2000 08:49 PM
