Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 08-25-2005, 03:07 PM   #1
spdracr00
Member#: 65823
1996 Impreza L
Red
Default spark plug wires 2.5 legacy outback
ok, so i was pulling a #3 cyl misfire CEL and i thought it could be from an exhaust leak, no dice.. so moving on to plugs and wires. i did a search and found all these folks saying $30/40 from the dealer.. so i called Carr and they said $60. so where are the cheap oem wires at? I was hopign to order them though work but cant get them. so please help ma out!
spdracr00 is offline   Reply With Quote
Old 08-25-2005, 06:34 PM   #2
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
First thing I'd check on a #3 misfire is the coilpack. See it all the time and at least twice on my 98 BDs and once on my 99 BG/K. Check the coilpack-side connector both the coilpack connector and the wire-side connector for arcing/carbon blacking. If you got it you've got one of three things going on:
1) bad plug
2) bad plug wire
3) bad coil pack
4) fuel starvation on # 3 cylinder fuel rail - a search should yield some help here.
Plugs here: http://www.ngksparkplugs.com/apps/ca...uv/results.asp
Plug wires here...https://www.1stsubaruparts.com/partscat.html @ $10.79 each
Coilpack check here...http://endwrench.com/images/pdfs/IgnitionCoil.pdf
Coilpack replacement here...https://www.1stsubaruparts.com/partscat.html
Good luck
Dale
Subietonic is offline   Reply With Quote
Old 08-25-2005, 06:43 PM   #3
spdracr00
Member#: 65823
1996 Impreza L
Red
Thank you so much. i'll check all that stuff out. or i'll be lazy and take it to my mechanic and let him check it all out. haha...
-ben
FS: Aurora spark plug wires 96-99 Legacy GT Splinter VIC Private Classifieds 0 03-03-2010 11:32 PM
FS/MN: NGK Iridium Spark Plugs (LFR7AIX) 2.5 STi/WRX - One Step Colder WRXEcho Engine/Power/Exhaust 4 09-01-2008 02:42 AM
[B]NGK IRIDIUM Spark Plugs for 2.5 STi - $19 SHIPPED!!![/B] Mr. Quick Engine/Power/Exhaust 1 11-28-2007 04:51 PM
STOCK NGK IR Spark Plugs for 2.5 STi - $19 SHIPPED!!! Mr. Quick Engine/Power/Exhaust 0 11-28-2007 04:50 PM
2.5 Legacy Outback conversion to H6 3.3 snowkatslim Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 06-07-2007 09:26 AM
