Old 08-25-2005, 05:06 PM   #1
turboed22
Member#: 93364
1998 '98 Impreza RST
'14 BRZ
Default EJ257 Short-block Swap
I have searched and searched and can't find an exact answer to my question.
Can you keep a factory computer/fuel system when you swap a ej257 short-block into a MY98 rs.
I put the short block in and after days of troubleshooting I have narrowed it down to my ignition timing. When each cylinder was at TDC there was alway a nipple under the crank sensor on my factory phase 1 ej25. On the new one the nipples are not under the crank sensor when it needs to fire.
Does anyone know someone who does NOT run a standalone on a EJ257 hybrid swap?
turboed22 is offline   Reply With Quote
Old 08-25-2005, 05:13 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
hmm, that doesn't sound right. The timing ring should fit on just like it did before...
Old 08-25-2005, 05:45 PM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Wait- did you use the crank timing gear off the the rs block? If not you need to. Otherwise it should work fine without a standalone.
Drac9 is offline   Reply With Quote
Old 08-25-2005, 06:28 PM   #4
turboed22
Member#: 93364
'14 BRZ
This was with my factory crank sprocket. I tried the sti but the nipples are everywhere on it. Do you know anyone that has done this swap before?
Old 08-25-2005, 06:48 PM   #5
Drac9
Member#: 9861
I know several people who have done this swap with no issues.
Old 08-25-2005, 11:02 PM   #6
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
did you use the that timing gear thing that goes off the crank from your RS? I don't have that block, but I do have an ej20G running off a 1.8 ECU. The crank gear thing (sorry I'm not a mechanic) is different.
Chad
subachad is offline   Reply With Quote
Old 08-26-2005, 12:05 PM   #7
jdchmiel
Member#: 926
hmm maybe this is a dohc only issue as I didnt have any probs with sohc '01 swap related to timing.
jdchmiel is offline   Reply With Quote
Old 08-26-2005, 12:41 PM   #8
Drac9
Member#: 9861
I don't think so because I know a few people who have done this with DOHC cars as well. The motor turns fine by hand- with a ratchet, right? You didn't put the timing belt on backwards or anything did you?
Old 08-26-2005, 01:22 PM   #9
turboed22
Member#: 93364
'14 BRZ
I have done the timing with my new belt and old belt ten times and hand cranked it over and it was perfect. Does anyone know if the phase 1 and the phase 2 ej25 has a different crank sprocket?
Thanks for your suggestions
Scott
Old 08-26-2005, 01:27 PM   #10
Drac9
Member#: 9861
As far as I know the sprockets are the same? How many teeth are on your sprocket? and these are RS heads, not legacy heads, right?
Old 08-26-2005, 02:26 PM   #11
turboed22
Member#: 93364
'14 BRZ
Phase 1 RS Heads and there are six teeth total on my sprocket.
Old 08-26-2005, 03:15 PM   #12
Drac9
Member#: 9861
Ok- so you're sure there is no spark? have you verified by pulling the plug wire off and grounding it? Any CEL's? All sensors hooked up? Do you have access to a scope?
Old 08-26-2005, 05:31 PM   #13
turboed22
Member#: 93364
'14 BRZ
I get spark on all four cylinders it just at the wrong time. Do you know what crank sprocket they use?
Old 08-26-2005, 06:06 PM   #14
Drac9
Member#: 9861
The RS crank sprocket. And it's keyed- so there's no way it should be off.
Old 08-26-2005, 06:13 PM   #15
turboed22
Member#: 93364
'14 BRZ
It has to be the crank. It must be different than my stock one. I have found TDC on each cylinder and it lines up perfect on my old block. On the new one, at each cylinder the teeth dont line up. When I showed a couple of Subaru Guys with 22t swaps they didn't know why it doesn't line up. I am going to have to put a ej22t short-block instead.
Old 08-26-2005, 08:48 PM   #16
Tats
Member#: 5692
WTF? YES! I am
better than you!
Same here.
Tats is offline   Reply With Quote
Old 08-26-2005, 10:48 PM   #17
Drac9
Member#: 9861
I have sohc heads for sale if you're interested.
Adam
Old 08-28-2005, 02:20 PM   #18
turboed22
Member#: 93364
'14 BRZ
Drac9
Do you know of anyone that has done the swap into a phase1 motor has had any problems like mine? I think there is someting wrong with my crank on my new short block. I know the chances are slim to none but I will have to slit the block and swap the sti crank with my factory crank.
Old 08-28-2005, 02:30 PM   #19
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
I am about to perform this exact swap. I have both short blocks on my bench right now. Give me a little bit and I will post what I observe.
This is an interesting thread and it would have a quite a few implications for me as intend to run the factory ECU with a piggyback. I must pass OBD-II inpection. Better yet, we need to ensure it will run huh?
Be back with another observation.
Joncas2 is offline   Reply With Quote
Old 08-28-2005, 03:34 PM   #20
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Guys-
I'll take anyone's input, but I am not seeing a physical or mechanical timing problem using the 98's Cam Timing Gear on an EJ257 Shortblock. Here's a link to all the photos I just took: http://community.webshots.com/user/djoncas14
Everything ends up in the same location mechanically.
Turboed22, are you certain you installed your Crank Position Sensor correctly? And I know you said you were sure, but are you 100% certain you installed the timing belt perfectly. These engines are a real bear. Did you replace your belt tensioner too? Go to www.endwrench.com and search for the old articles about changing timing belts on the Phase I DOHC's. A real eye opener for me.
Let me know. I do not see the problem you diagnosed in your first post.
Old 08-28-2005, 05:21 PM   #21
turboed22
Member#: 93364
'14 BRZ
Yes I had two Subaru Mechanics over to do the timing to make sure. There has to be something wrong with my crankshaft key because mine does not line up like yours does. Thanks for the pictures and I will post any new updates to help you for your swap.
Thanks
Scott
Old 08-28-2005, 10:10 PM   #22
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Thanks and please do keep us updated. A problem like this would be devastating to my swap plans. I would probably rethink the whole swap if I was convinced I needed to abandon the EJ257/98 ECU plans.
Cheers.
Old 08-28-2005, 10:21 PM   #23
Drac9
Member#: 9861
Swapped cranks wont work. The phase1 crank is center thrust- the phase 2 crank is rear throust. Plus the big end fournals are 52mm on the phase 2 crank and 48mm in the phase 1 crank.
Old 08-28-2005, 10:28 PM   #24
Joncas2
Member#: 39889
1998 2.5 RST GT30R
Red
Drac9 - Although I would never swap the crank, thanks for the info. I don't think I will have a problem as the pics demonstrate.
Old 08-28-2005, 10:34 PM   #25
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
I know that there is something being missed here. I have 1 local customer, and at least 2 mail order customers who have been running the phase 1, 2.5 heads on an EJ257 shortblock for over a year now. You have to use all of the cam and crank gears from the Phase 1 engine, but it should work.
Templar is offline   Reply With Quote
Socal : ej257 short block scoobyimpreza Private 'For Sale' Classifieds 55 06-22-2006 02:24 PM
fs: BRAND NEW IN BOX MY06 ej257 short block legacy2003 Private 'For Sale' Classifieds 25 02-22-2006 08:54 PM
Another EJ257 Short Block Install dunk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 10-18-2005 07:27 AM
EJ257 short block new IA Performance Private 'Wanted' Classifieds 1 02-15-2004 11:19 AM
Thinking about getting a EJ257 short block have a few questions. roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-29-2003 01:29 PM
