Old 08-25-2005, 10:13 PM   #1
Genner
Member#: 18372
Default Tires for a newbie
Hello all,
I got a new set of tires about 4k miles ago. Never did a rotation myself with the old set of tires but I plan to with these new ones.
I got the Kuhmo Estas ASX. They are not unidirectional tires. Which is the best method to rotate these tires?
According to Tirerack, they say you can do a diagonal criss cross rotation.
In the WRX manual it says to rotate the left side front and rear on the same side and the right front and rear on the same side.
Genner is offline   Reply With Quote
Old 08-25-2005, 10:17 PM   #2
maxpower45
Member#: 84445
2002 WRX Wagon
SRP
When in doubt, go with the manual.
maxpower45 is offline   Reply With Quote
Old 08-25-2005, 10:17 PM   #3
ludecrous
Member#: 19376
2003 03 WRX Wagon
Move the rears in line with the car to the front, ie rear right goes to front right, rear left goes to front left. Then cross the front tires and put on the back, ie front left to rear right and front right to rear left. Then always follow this pattern when you rotate and you will have even wear.
ludecrous is offline   Reply With Quote
Old 08-25-2005, 10:20 PM   #4
ludecrous
Member#: 19376
2003 03 WRX Wagon
the manuals way is good if you only drive in a straight line ha ha
the manuals way sucks if you have "fun" right or left everyday into work
Old 08-25-2005, 10:36 PM   #5
Genner
Member#: 18372
like what ludecrous said in post #3, does it have any advantages doing it that way vs. criss cross?
Old 08-25-2005, 11:56 PM   #6
ludecrous
Member#: 19376
2003 03 WRX Wagon
oops, also
the manuals way is good if you have directional tires, so in Genners case it don't matter.
The difference between criss cross and the way I described in post #3 is that in a criss cross each tire only sees 2 corners of the car after 4 rotations, in the way i describe after 4 rotations each tire has been on every corner of the car, the assumption is that the way I describe would give better long term wear.
Old 08-26-2005, 12:52 AM   #7
Genner
Member#: 18372
sounds good to me...will do it that way!
Thanks!
tire fitment for a newbie ShushUpNancy Newbies & FAQs 9 04-27-2010 02:38 PM
Tire suggestions for a newbie jkhnc Tire & Wheel 3 06-13-2006 11:40 AM
rain tires for newbies? meebs Motorsports 0 12-17-2002 11:21 PM
Tire Guru Alert- Newbie Question GLOATLIP Brakes, Steering & Suspension 8 04-06-2002 07:13 PM
('93-'01) GREATEST Sighting for a Newbie ScoobyBoy Impreza Forum 1 06-03-2001 03:51 PM
