Old 08-26-2005, 08:41 AM   #1
XenoWolf
Member#: 64029
1999 Impreza L Wagon
Sun Bleach Red
Default Max tire size (14x6 wheel)?
I have a set of American Racing Estrellas (Alloy) - 14x6", and I'm curious as to the maximum tire size I can stuff into them. On Tire Rack the largest section width I could find using my wheel size was 215mm. Would tires of this width be safe to run on a 6" wheel? Also I'm curious as to how much the section height of the tire will affect dry performance. I'm running generic 195/70R14's right now and the tires (even when properly inflated) will 'roll' onto thier sidewall under hard cornering, which concerns me. What range should I be looking in as far as section height?
I'm new to all this, as this is the first set of tires I've ever had to buy. Any tips and/or advice would be appreciated.
XenoWolf is offline   Reply With Quote
Old 08-26-2005, 09:28 AM   #2
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
For a given wheel, if you want to maintain the same overall diameter, the sidewall height will stay the same no matter what tire you put on.
Go here to see how various size tires will compare with stock: http://www.powerdog.com/tiresize.cgi
Also, squeezing 215/60s onto your stock wheels will result in poorly supported sidewalls, which means you'll still have that sidewall-rolling feeling when cornering hard.
The best advice is to get a set of junkyard 15x6 Subaru alloys. They'll be very cheap. Then you can run a decent performance tire in 205/60-15 or even 205/55-15, which will absolutely transform your handling.
Jon Bogert is offline   Reply With Quote
Max tire size for stock tires? kylelikewhoa Tire & Wheel 4 09-21-2007 02:20 AM
Max tire size on 02 sedan w/o rubbing jblaine Tire & Wheel 3 07-17-2003 09:18 AM
18" P1s -- weights, max tire size for wagon wrxdriver Brakes, Steering & Suspension 5 06-07-2001 12:58 AM
Max Tire Size for the WRX? GTBGUY Brakes, Steering & Suspension 7 03-26-2001 03:40 PM
Max Tires Size for '01 RS ColinL Brakes, Steering & Suspension 4 11-29-2000 04:49 AM
