Old 08-26-2005, 11:55 AM   #1
suby53
Member#: 59648
97' Legacy Outback
Default fuel system mod?
I have a tdo4 on my 1.8 impreza and was reading about a fuel system mod on northursalia.com ( series to parallel ). Has anyone tried this with aftermarket forced induction? if so, how did it work out for you? Worth it?
[url=http://www.northursalia.com/modifications/drivetrain/fuelrail/fuelrail.html]
suby53 is offline   Reply With Quote
Old 08-26-2005, 08:07 PM   #2
Unsung Boxer
Member#: 37196
I am going to give the same answer i give everyone. This mod is BS.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 08-26-2005, 10:52 PM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Agreed.
Drac9 is offline   Reply With Quote
Old 08-26-2005, 11:02 PM   #4
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
i had a td04 on the 1.8, but i switched to turbo legacy rail and injectors. But this required an safc to control as i felt. Unless you plan to get a better rising rate fuel pressure regulator, doing a parallel will not raise your fuel pressure through the regulator... correct me if error
STi-Nismo Dood is offline   Reply With Quote
Old 08-27-2005, 10:36 AM   #5
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
I believe the mod is just to try and balance the fuel delivery to all the cylinders. It has nothing to do with increasing fuel pressures, in fact, I believe that it may lower the fuel line pressures, if only a little bit and a for short period of time.
John2.5RS is offline   Reply With Quote
Old 08-28-2005, 02:00 PM   #6
Unsung Boxer
Member#: 37196
NO NO NO NO, and NO.
The mod is meant to to distribute fuel evenly to all 4 injectors. The thought was that the injectors are fed inline, so the 4th injector doesnt recieve enough fuel because the other 3 are somehow using the fuel pressure before it gets to the last one. The parallel fuel rail mod, would run the fuel parallel instead of inline, thus fuel pressure would be even to all injectors. However, this idea is fundamentally flawed.
___________________________________
Consider this:
A garden hose. The faucet is turned on, and the nozzle at the end is shut off. There is pressure in the hose that is not moving, correct?
Now, Poke 4 holes in the hose. Water starts spraying out, assuming the 4 holes are the same size, equal amounts of water will flow from each one, no matter how far away from the faucet the hole is.
If pressure in the hose drops, it will drop evenly to each hole.
This principle is the same in the fuel system, therefor the is no problem with the 4th injector being starve, this is a myth. Im amazed at how many people CONTINUE TO FALL FOR THIS.
-Jake
I really think a moderator should sticky this.
Old 08-28-2005, 02:22 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
also there should be no point in getting fuel rails too
people get them thinking theyre going to do miracles
truth is though if youre feeding a 1" dia. hole with fuel through a .25" dia line...youre only gonna get .25" of flow
Old 08-28-2005, 06:46 PM   #8
Unsung Boxer
Member#: 37196
w3rd!
Old 08-29-2005, 08:41 AM   #9
suby53
Member#: 59648
97' Legacy Outback
Thanks for all your help guys. I had the turbo legacy injectors and fuel rails on my last set up. It was worlds better than this set up with the blox fmu and stock injectors an the same 9 psi.
Old 08-29-2005, 02:36 PM   #10
Drac9
Member#: 9861
Not to mention the potential danger of rubber lines on top of a hot block- there's a reason the factory ones are metal. It is more likely the intake manifold design or the design of the coolant passages that causes the $4 to run hotter.
Old 08-29-2005, 02:41 PM   #11
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
a little side track again but what about the rumors of disconnecting the hose that connects to your egr port on the intake manifold? Has anyone actually gotten lower temperature results on their aftermarket system?
Old 08-30-2005, 10:00 AM   #12
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Originally Posted by Unsung Boxer
Consider this:
-Jake
OK. So, let me ask this. And this is nothing more than a question.
I understand your analogy but, why then are there apparently so many people having the 3rd and/or 4th piston burnt, supposedly due to a starved piston, supposedly due to the failure of the stock Suabru fuel rails to properly supply fuel to all 4 cylinders.
Presuming that the fuel rail/starved piston is nothing more than a myth, the issue of the burnt piston supposedly lends credence to the fact that it is not a myth.
Couldn't there be something is the way the fuel flows through the rails, something to due to the internal rail design, that causes some type of restriction? I've never cut open the fuel rail.
Samurai Jack is offline   Reply With Quote
Old 08-30-2005, 01:11 PM   #13
Unsung Boxer
Member#: 37196
First of all, im a Subaru Technician, and I really dont know where this "common knowledge" that 3rd and 4th pistons become burnt often.
EJ25 engines do have have a problem w/ #4 cylinder going out of round, and causing piston slap primarily due to its skirtless pistons. Yet, that is the only trend Ive really noticed. I think someone got their facts crossed somewhere along the way.
Furthermore, the fuel rails seem to have a solid design, If this was a real problem, dont you think that Subaru would have re-engineered them for such a simple fix?
Lastly, no one has shown any of this evidence:
1. The injectors flow unevenly.
2. The Rails are the culprit
3. The Fuel Rail mod causes the injectors to flow evenly.
Neither the problem, the action, or the solution can be verified, so until proven otherwise, this is all just Theory, and a pretty BS one at that!.
-Jake
Old 08-30-2005, 07:18 PM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
someone needs to steal the CAD file for the intake manifold..put it in Flow Works...and see what happens
Old 08-30-2005, 07:37 PM   #15
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Unsung Boxer
I don't either. But, from time to time there are threads here, and on other WRX forms, that the issue of a burnt 3rd and/or 4th piston has happened. From there, the issue turns into one of the starved piston thing. And then, there is some poll on here about the number of WRX people who have had a burnt piston, w/ the #4 piston being the largest number.
Unsung Boxer:
Could be where it started from.
Unsung Boxer:
One would think so, unless it only shows up under specific circumstances, which are hard to repeat. Of the 10s of thousands of WRXs/STis Subaru sells, it may be such a small thing that it doesn't seem worth the effort, if it's true.
Unsung Boxer:
Well, I would throw out #1 and stick w/2 & 3 since the issue is directed at the rails.
Unsung Boxer:
And you can't argue with that
Old 08-30-2005, 07:57 PM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold intake manifold
Old 08-30-2005, 08:45 PM   #17
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Good thing I never went through with this mod - I was thinking about it but it was quite involved plus I would be having the shop doing this work and they had no experience other than what was documented. I guess as long as I have good fuel pressure and no clogged injectors I should be fine
kgb is offline   Reply With Quote
Old 08-30-2005, 10:28 PM   #18
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Unsung Boxer:
LOL.
If the fuel rails dropped in pressure the injectors would flow unevenly as a result of it...
/boggle
Kotir is offline   Reply With Quote
Old 08-31-2005, 10:40 AM   #19
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Perhaps, but not according to Unsung Boxer's analogy, which I am taking at face value for the purpose of the discussion.
Consider this:
Which brings it back to the fuel rails, which is the subject being discussed.
Or, maybe the intake, right White 2.5rs?
Old 08-31-2005, 11:44 AM   #20
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
has anyone disconnected their egr port hose from the intake manifold, capped it (aftermarket turbo car) and noticed results?
Old 08-31-2005, 01:16 PM   #21
Resbum
Member#: 13935
1999 Forester S
Green
Playing Devil's Advocate.
Using stock fuel pump and regulator. After market turbo on a normally aspirated engine.
As we all know, when you increase boost you must also increase fuel. This is done by increasing the duty cycle of the injectors.
Imagine a river that flows at a constant rate, with four gated channels off of it's left side. Normally, the gates are open a modest amount. As more water is needed in each channel (under boost)the gates are opened farther and farther (duty cycle). Eventually the open gates will have more demand than the river can keep up with and the river will start to dry up before it gets to the fourth channel. Hence it starts to starve for water.
The purpose of this mod is to put one channel on the left and one directly across from it on the right. With another set of channels down stream. If the demand on the river starts getting too great the second set might start getting less water BUT they're sharing the loss equally. The fourth channel comes out ahead.
I don't even begin to have a clue if you can boost to the point of leaning out the #3 cylinder using the stock fuel pump and regulator.
However, as with any mod, you have to mod everything. Many people just slap on a turbo and call it good. By putting in a high flow fuel pump and a rising rate regulator you increase the ability of the fuel system to keep up with the demand. In other words, you give the river the ability to increase it's flow as the four channels demand more water.
I don't see a need for this mod if you upgrade your fuel system along with the turbo. On the other hand, I don't see how it can hurt other then it's work that probably doesn't need to be done and the very good point made earlier in this thread about rubber hoses on a hot block.
For what it's worth, my two cents.
Resbum
Resbum is offline   Reply With Quote
Old 08-31-2005, 03:08 PM   #22
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
rrfpr/fpr solves lack of flw probs assuming the pump can keep up
Old 08-31-2005, 09:28 PM   #23
Samurai Jack
Member#: 21145
2002 Enemy of Aku
For WIW, I like the Devil's Advocate approach
Old 08-31-2005, 10:23 PM   #24
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
-snip-
Resbum
Ah, but doesn't your river analogy involve a system with flow, but virtually no pressure (at least at the surface)? For something like this to happen in the fuel rail, fuel pressure would first have to drop essentially to zero. I can't recall seeing any threads where someone with an adequately-large fuel pump managed to pull down their pressure enough to burn a piston.
...just playing Devil's Advocate to your Devil's Advocate.
FWIW, I DID do the fuel rail mod. I really doubt I'll do it again if I work on another manifold.
_Jeff
Portly is offline   Reply With Quote
Old 09-01-2005, 02:23 AM   #25
Resbum
Member#: 13935
1999 Forester S
Green
Thanks Portly,
The river analogy was just an attempt to explain the purpose and thinking behind this mod.
At the end of my post I stated that if you put in a larger fuel pump and rising rate regulator with the turbo, this mod wasn't needed.
A point my river analogy and the garden hose analogy didn't take into account is that only one of the gates/holes will ever be open at a time. Just like the injectors on your engine. That throws a whole new twist on the subject.
Resbum
PS - I bought my 99RS with this mod already done on it.
WRX fuel system, what mods to handle vf-39? StiPete Newbies & FAQs 14 08-28-2006 03:24 PM
What mods does it take to max out stock fuel system? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-10-2004 01:19 PM
any fuel system upgrades necessary for stage 2 N/A mods? wistful Normally Aspirated Powertrain 2 04-16-2002 04:36 AM
mods to fuel system bad for NA? Impreza25RS Normally Aspirated Powertrain 1 02-25-2002 01:02 PM
fuel system managment system jeffsnyder Normally Aspirated Powertrain 2 09-23-2001 01:13 PM
