Old 08-27-2005, 12:53 AM   #1
Hokie-wrx wagon
Member#: 87194
Default I just installed a boost gauge and I have a boost question...
I installed a factory boost gauge on my steering column (lamco) and had some questions.
It looks like my max boost is .08-.09 bar. Is this correct for a stock wrx?
After it hits .08-.09 bar, it stays there for a second then drops to .06-.07 bar above 4000 rpm. Is this normal?
I tightened and zip tied the vacuum lines as good as I could to the T fitting near the fuel pressure regulator. They lines weren't an extremely tight fit over the T fitting, but were somewhat snug...
Thanks,
Mike
Hokie-wrx wagon is offline   Reply With Quote
Old 08-27-2005, 12:33 PM   #2
Hayes
Member#: 11808
Why the bleep Subaru does'nt offer a gauge that reads in PSIG for the American market is a joke. I suppose it make for a good discussion at the coffee table. Their own manuals talk about boost in psi so what's with thir guages. Dumb Dumb Dumb.
Hayes is offline   Reply With Quote
Old 08-27-2005, 12:50 PM   #3
Thingfish
Member#: 91451
03 WRX
The stock gauge reads in MPa,Mega Pascals. .05Mpa = 7.25psi , .1 = 14.5 psi. Stock boost should max at 13.5psi, just under .1 Mpa.
Yes it is normal for a stock turbo car to taper boost at higher rpm.
Thingfish is offline   Reply With Quote
Old 08-27-2005, 12:51 PM   #4
fireball_jones
Member#: 67536
00 AW GM6
And a bunch of parts
.8-.9 would be about right, I usually see 14 psi at WOT, which is .96. But I usually don't see the boost drop that much until much higher RPMs.
fireball_jones is offline   Reply With Quote
Old 08-27-2005, 05:17 PM   #5
jjasper14
Member#: 78724
Mine won't get above .05. Even when it's to the floor. I don't know why. I'm hoping that it's something with the gauge, because the car feels like it's got plenty of power. If anybody's got any suggestions, let me know.
Jonathan
jjasper14 is offline   Reply With Quote
Old 08-27-2005, 06:27 PM   #6
Hokie-wrx wagon
Member#: 87194
Thanks for the info... exactly what I needed to know!
Old 08-27-2005, 09:57 PM   #7
mrjasey
Member#: 90939
i find that my boost guage gives me skills in magic
mrjasey is offline   Reply With Quote
Old 08-27-2005, 10:05 PM   #8
r0nzar
Member#: 78957
'06 Evo IX RS
White on white on salt
Mine hits about .08 to .09 mpa like yours, all is well. If you google search a conversion table you can find some useful mpa to psi to bar to whatever tables
r0nzar is offline   Reply With Quote
Old 08-28-2005, 12:06 PM   #9
pir800
Member#: 40603
2002 wrx turbo
it looks right
pir800 is offline   Reply With Quote
Old 08-28-2005, 12:16 PM   #10
mblank
Member#: 35287
2003 WRX Sedan
I think the oem ecu won't allow full boost on wot in the lower gears. Can someone else confirm this too...
mblank is offline   Reply With Quote
Old 08-28-2005, 12:27 PM   #11
attitude
Member#: 52043
04 sti
not enough load on the motor to boost in lower gears. go drive up a steep hill in lower gears, and watch your gauge
attitude is offline   Reply With Quote
Old 08-28-2005, 12:33 PM   #12
supermarkus
Member#: 6971
2008 WRX STi
SSM
supermarkus is offline   Reply With Quote
Old 08-28-2005, 01:58 PM   #13
OrlandoSTi
Member#: 70566
2005 Impreza STi
Team Rptr
Well, because the Impreza is a true Japanese car and it comes from Japan, where the Japanese read their gauges in MPa.... Actually, most everyone, but America...... It takes all of one minute to figure out how to read the gauge, ya know.....
OrlandoSTi is offline   Reply With Quote
Just installed boost gauge and EGT have some questions 04bluedubRex North West Impreza Club Forum -- NWIC 21 02-06-2009 11:07 AM
Just Installed the OEM Lamco Boost Gauge and Now I Have an Issue with the STi... Red Rexx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 07-28-2008 10:04 PM
know anyone around Rowland Height that can install factory boost gauge and have them? RoC_Pooh Southern California Impreza Club Forum -- SCIC 6 08-03-2004 06:33 PM
Just installed my boost gauge and it says my stock wrx is running [email protected] !? daybreak Newbies & FAQs 3 10-07-2002 01:20 AM
New to Turbos and I just put in a boost gauge, now I have a question gotsol Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-09-2002 08:33 AM
