Old 08-17-2001, 07:18 PM   #1
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Abnormally Aspirated
Thumbs up LEDA Suspension
You hear a lot about STi, P1, DMS, Tein, etc. on the board, but not a lot about LEDA.
I have nothing against those other suspension setups. In fact, I've never driven any of them, with the exception of the P1, so I really can't compare them.
All I can say is that I'm very happy with my LEDA setup (with 20mm rear anti-roll bar; Toyo RA-1 on stock wheels; Mintex pads; no other suspension mods). Notice that this is the straight Mike Shields advice -- worked for me!
I use my car for track days, and I've caught Integra Type R's, M3's, various pony cars, NSX's, and even a 500hp Cobra replica, and I'm not that good a driver! My engine is BONE stock, by the way, so it's definitely the suspension (and the AWD, of course).
Anyways, I credit the LEDA suspension with a lot of whatever success I have at the track.
the Dabbler is offline   Reply With Quote
Old 08-19-2001, 12:41 AM   #2
DuBYARX
Member#: 6549
2002 SRP-WRX
92 Ice Blue Legacy Wagon
Is your car an RS or the WRX I've done some research on the Leda and I think it's the way I want to go too.
DuBYARX is offline   Reply With Quote
Old 08-19-2001, 03:36 AM   #3
kaos200
Member Sales Rating: (64)
Member#: 2692
hey where in Aliso Viejo are you? haven't seen many scoobies around there.
kaos200 is offline   Reply With Quote
Old 08-20-2001, 09:52 PM   #4
ToddStratton
Member Sales Rating: (1)
Member#: 8351
2002 WRX Wagon
How was the adjustability? Take much to get it dialed in? Considering this setup myself...
Thanks,
TRS
ToddStratton is offline   Reply With Quote
Old 08-23-2001, 09:16 PM   #5
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
I have an MY00 RS. Not sure what the situation is for the WRX.
Re adjustability, I started out with what Mike Shields suggested, 5 front, 7 rear (off full soft). This seems to match my 300/225 springs pretty well. With my RA1's and 20mm rear bar, the car is neutral for the most part, with oversteer induceable at will. Through sweepers, it's easy to throttle steer with confidence.
I picked up a bit of oversteer under trail-braking when I went to the Mintex rear brake pads (previously I only had them on the front). Dialing back one click on the rear damper setting seemed to help quite a bit. In the end, I put the setting back where it was, but reduced my rear tire pressure instead. So the bottom line -- I haven't deviated much from the initial settings. Once at Buttonwillow I cranked up both F/R arbitrarily by four notches, just to see what would happen. Seemed to make the overall grip level much lower. Went back to 5/7 immediately afterward, and have been pretty happy since.
No shock dyno charts or anything (as you can probably tell, I'm no suspension setup guru), so all I can really say is, it works for me.
Old 09-05-2001, 07:37 PM   #6
subyguy2
Member#: 8718
2005 STi, SpecMiata
05 NASA SM - Most Wins
Do you drive this setup on the street. How is the ride quality with the 300/225 setup.
subyguy2 is offline   Reply With Quote
Old 09-05-2001, 08:42 PM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Decent setup, but not nearly the bulletproof chunks of steel the DMS units are. As long as you don't hit anything, they should hold up great
Ben
bsquare is offline   Reply With Quote
Old 09-07-2001, 03:02 PM   #8
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
I run this on the street as well as track days. Ride quality is surprisingly good for me, but YMMV with different bushings, tires, etc.
? We're talking a road race setup here, not rally, if that's what you mean. Not to knock DMS. Never tried them. I'm sure they're fine.
Old 09-07-2001, 06:10 PM   #9
subyguy2
Member#: 8718
2005 STi, SpecMiata
Thanks, here I come Leda!
Old 09-07-2001, 06:13 PM   #10
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Hope you're as happy with it as I am.
Old 02-26-2002, 07:17 PM   #11
relayer66
Member#: 14614
Platinum Silver
I've heard the Ledas were very good but I also heard that they require rebuilding more often than, say, DMS. Like once a year.
relayer66 is offline   Reply With Quote
Old 02-28-2002, 12:53 PM   #12
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Never heard that. Could be. I suppose it depends on usage.
What I'm talking about specifically is street use, plus (road race) track weekends once a month. Given that sort of usage, I'd be surprised if any strut would need rebuilding annually.
If you're talking about rally, again, that's another matter. I would think in a full rally application, you'd want to rebuild your struts after each season anyway, regardless of manufacturer. I don't know. I don't rally. :shrug:
Leda suspension in real world ginowrx Bay Area Impreza Club Forum -- BAIC 9 06-12-2002 11:56 AM
leda suspension question enyce4u Brakes, Steering & Suspension 0 10-16-2001 11:48 AM
LEDA suspension WRX Power Brakes, Steering & Suspension 2 07-18-2001 01:56 PM
Leda Suspension? JRS Brakes, Steering & Suspension 3 06-20-2001 06:08 PM
TE-37 rims and Leda Suspension for sale! tach Bay Area Impreza Club Forum -- BAIC 11 03-10-2001 10:44 AM
Message Board Statistics All times are GMT -4. The time now is 09:05 AM.
