Old 08-17-2001, 07:25 PM   #1
jclick
Member#: 4525
2002 WRX Wagon
Default Those with the MRT Turbo back exhaust
I just recieved my exhaust and I remember reading somewhere that you had to cut the stock heatshield to fit the downpipe. Was there some sort of instructions or template that came with the exhaust? I may have thrown it away accidently when I unpacked my exhaust and I can't find it.
Thanks in advance
jclick is offline   Reply With Quote
Old 08-17-2001, 09:36 PM   #2
WRX216
Member#: 8027
2002 WRX sedan
Midnight Black
Default MRT
My MRT turbo back came with a 4 page instruction sheet, which had a couple of "dim" pictures of how to trim the upper and lower heatshields. I'm running an uppipe, so I don't have a lower shield to trim. Its hard to make out where they want you to trim it in the pic. The upper shield needs to be trimmed on the right side. Basicly you start trimming at the top where the down pipe comes out of the shield, and then go striaght down the right side, eliminating the rear mount point which the MRT does'nt have. I think you're going to have to do a little trial and error fitment here. Good luck - Chris
WRX216 is offline   Reply With Quote
Old 08-17-2001, 10:52 PM   #3
jclick
Member#: 4525
2002 WRX Wagon
Did you use all the stock hardware to install the exhuast? Or did you need special gaskets and bolts?
Old 08-18-2001, 09:13 PM   #4
jclick
Member#: 4525
2002 WRX Wagon
Can some one tell me if the stock gaskets and bolts work on the MRT system? I want to go collect everthing before the install.
Old 08-18-2001, 11:23 PM   #5
WRX216
Member#: 8027
2002 WRX sedan
Midnight Black
Default MRT hardware & gaskets
My MRT system came with gaskets and hardware for the downpipe to mid, and mid to rear section. The stock gasket for the turbo to down pipe is a steel gasket, and with care is reusable. The stock downpipe to turbo nuts are reused, as are the mount bolts from downpipe to tranny, and from mid to middle body mount. Hope this helps - Chris
P.S. use hi temp antiseize on alll bolts and studs if you ever want to take this apart again... Also soak all bolts and studs(turbo) with wd-40 or some such penetrating lube for about 30 mins before trying to dissassemble!
Old 08-19-2001, 11:11 AM   #6
jclick
Member#: 4525
2002 WRX Wagon
I got my exhaust and I did not got any gaskets so I will have to figure out what I need in order to get this installed.
Thanks for the info. It will help.
Old 08-20-2001, 11:41 AM   #7
jclick
Member#: 4525
2002 WRX Wagon
Yes, I got mine from Dan at Vivid as well.
MRT turbo back exhaust, Buschur catback exhaust (PA) 69subaru360 Engine/Power/Exhaust 7 10-13-2009 08:16 PM
FS: MRT Turbo Back Exhaust System Chris N New England Impreza Club Forum -- NESIC 10 08-01-2002 10:26 PM
mrt turbo back exhaust Eyes0cket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-28-2002 11:34 PM
MRT turbo-back exhausts konsl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-10-2002 11:48 AM
MRT Turbo back exhaust install & impressions MikeWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-13-2001 01:53 PM
