Old 08-27-2005, 02:04 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default how much boost does your JDM EJ20 make stock
trying to figure out if i have a up pipe leak or not, im holding about .8 kg/cm right now, but i have some funny fluttering noise going on
supermoose is offline   Reply With Quote
Old 08-27-2005, 05:28 PM   #2
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
This is tapped at the center of the intake manifold.
powerlabs is offline   Reply With Quote
Old 08-27-2005, 05:42 PM   #3
kingsubi
Member#: 19239
2011 WRX
0.8 is just over the wastegate pressure - maybe check thats its not gone...
kingsubi is offline   Reply With Quote
Old 08-27-2005, 06:22 PM   #4
supermoose
Member#: 9093
swap starr
how do i check my wastegate condition? powelabs- i have teh exact same boost guage!! but mine shows about a .8 at max. NEED MORE BOOST I DO....
what should i check?
Old 08-27-2005, 06:27 PM   #5
supermoose
Member#: 9093
swap starr
Old 08-27-2005, 09:09 PM   #6
powerlabs
Member#: 45790
SUPERCHARGED
Do you have an AFR gauge?? That would make a boost leak very easy to spot because the MAF would be monitoring all that air you were leaking out and you'd see your engine running pig rich. If not, then I would check all your vaccum lines and air lines for leaks, then check again with the engine running. Assuming all lines are fine your boost solenoid or your atmospheric pressure sensor could be to fault.
Note: The boost I am registering on that gauge is with the vaccum line that goes into the atm press sensor disconnected. With that line connected to the boost solenoid it will peak at 1.1 and hold at 1ATM...
Old 08-27-2005, 10:25 PM   #7
supermoose
Member#: 9093
swap starr
hmm. im tapped into one of the intake manifold lines, it actually goes up untill .95 kg/cm and then hangs out there untill i shift. the funny flutter noise still happens though, i wonder what it is. is .95 a proper amount of boost?
Old 08-28-2005, 11:22 PM   #8
supermoose
Member#: 9093
swap starr
my wastegate appears to be working properly, on safe mode it holds at .5 kg/cm constant, on normal it holds .95 till redline (slightly les than .9 in first gear)
Old 08-29-2005, 03:00 AM   #9
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
yes moose, you are at your stock boost level.
the V1-2s had less boost.
you are fine.
V1: 600mmHg
V2: 700mmHg
V3+: 800mmHg
that seems right in both cases with and without the ATM pressure sensor. (you both go up about the same)
Hurley 2.5 WRS is offline   Reply With Quote
How much boost does stock 2003 diverter valve hold nothingclub Newbies & FAQs 1 06-20-2008 02:47 AM
what does your JDM EJ20 rev to? supermoose Subaru Conversions 63 08-15-2005 04:03 AM
how much boost does a stock jdm ver 7 motor push? Capt Crunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-26-2004 05:33 PM
How much boost is your STi making?...no mods Ringboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 10-23-2003 05:00 PM
How much boost does the STI run in stock trim? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-21-2003 02:20 PM
