Old 08-27-2005, 07:13 PM   #1
solo2wrx
Member#: 87982
05 Intrepid
125cc of 2 stroke fury
Default Anyone familiar with the 4WD system on a 1990 Legacy?
As the title states, I am not familiar with the system as it switches from FWD to 4WD on its own. I picked up a 1990 Legacy to use as my rallycross beater and the 4WD is not working. All the necessary parts are on the car but there is no power being sent to the rear wheels. Any suggestions on what to check to see what could be causing this problem? Thanks in advance.
solo2wrx is offline   Reply With Quote
Old 08-27-2005, 09:46 PM   #2
jake15
Member#: 36662
1990 legacy dohc 2.2
6speed w/ brembos bishes!
auto or 5speed? if its an auto, does the power light blink when you start it up? in an auto, its primarily FWD unless the front wheels start to slip then the AWD ecu sends power to the rear wheels (like if you have it in "D" on a lift, all the wheels spin) if the power light in the guage cluster blinks when you start it up, it means there is a problem with the transmission (usually the solenoid that controls the AWD in the back of the transmission is bad). 5speeds are 50/50 split, so i dont know what you got going on if its a 5 speed.
jake15 is offline   Reply With Quote
Old 08-27-2005, 09:47 PM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
We need more info:
Auto or manual
How do you know that power isnt going back?
Are you sure the center diff is in place?
ss
subysouth is offline   Reply With Quote
Old 08-27-2005, 10:00 PM   #4
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Also, if it's an auto, are you sure the FWD fuse isn't installed?
Shane
Warp3 is offline   Reply With Quote
Old 08-28-2005, 05:30 AM   #5
Koss
Member#: 93139
Warp, here here! I like to start simple and then work my way to worst case scenario. Check the "FWD" fuse holder on the passenger side, near the firewall up high. If there is a fuse there, pull it out. If there is none, then it only gets worse from there.
Koss is offline   Reply With Quote
anyone familiar with the NYC subway system? a1ex Off-Topic 27 05-11-2006 08:13 PM
Anyone familiar with the dealership in Raleigh, NC? Fixxxer Dealership Reviews 6 06-15-2004 08:51 AM
Anyone familiar with the road Exhange Place in Jersey City? Need4Boost Tri-State Area Forum 10 03-25-2003 01:30 PM
Anyone familiar with the South Oregon Coast area? StankFootZ North West Impreza Club Forum -- NWIC 5 07-06-2002 03:05 PM
anyone familiar with the Dawes boost controller? steve Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-28-2001 08:34 PM
