Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 08-28-2005, 12:38 AM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Default TurboXS knock light, review and discussion
One of PDXTuning's main goals is to post information that is beneficial to the community. In a passing conversation last year we spoke with TurboXS about some products that would benefit the community, a knock light is one of the ones we discussed. Recently as part of their DTEC fuel computer they released a knock light. PDXTuning immediately asked for the KnockLite as a stand alone product so we can help people in the community with other forms of EM understand the state of their tune.
The two most common forms of engine management for the Subaru's right now are reflashes and piggybacks. I will hold this discussion to the UTEC and to reflashes. Since PDXTuning tunes AP Protuner, EcuTek, and UTECs commonly it is easy for us to give detailed information about how they all work. Since the AP and EcuTek both rely on the stock ECU to run the car this discussion will treat them as equals.
What is a TurboXS KnockLite?
The TurboXS KnockLite is a simple stand alone unit that can be added to any electronic ignition car to monitor for detonation, and indicate a given RPM to shift. Since it has built in tach drivers it works on cars like the Legacy GT that do not have a engine speed signal to tap.
Discussion:
One of the most important aspects of a tune is the safety margin. If you push a setup to the point of regular detonation it will eventually fail. Detonation results in spikes of cylinder pressure that will either mechanically fail some engine component, or cause the motor to absorb additional heat that will melt the piston top. Keeping detonation at bay is absolutely essential, and ultimately it limits the amount of power a car will make on pump gas. This limitation is the reason why race fuel makes more power than pump gas. Race fuel has a greater resistance to detonation, which allows the tuner to achieve the optimum timing, fuel, and boost combination for your particular car's setup.
One benefit the UTEC has over reflashes is it notifies the operator when detonation is detected. Unfortunately the UTEC does not have a learning system like the reflash to deal with detonation. The UTEC relies on the tuner to set up the map so that it does not regularly detonate. It does react to detonation by pulling timing, just like a reflash, but it currently does not have the ability to adapt to a problem spot. In order to make up for this the UTEC notifies the operator by flashing the CEL after a detonation event is detected.
The stock ECU has a learning system in it, which over time adapts to the octane limitations of your car and fuel. While many people prefer the learning ability of the stock ECU, they are relying solely on the hardware to detect and adapt. While this is normally adequate, there are motors out there that fail due to detonation with reflashes so the system must not be perfect.
Each model ECU is different, so I will have to make some general statements next. The 02 WRX ECU was particularly bad about reacting to detonation at times. Subaru decided to stop listening for detonation after about 5700 rpm due to a limitation in the hardware. After the cutoff RPM the ECU would run the maximum allowed timing, without regard to occurrence of detonation. Provided the map was setup properly you could still tune safely. However in order to get the maximum out of the car on 93 octane you had to be absolutely sure that the car was never operated at it's maximum with lesser fuel in it. While it is easy to say you will never put in 89 or 87 octane fuel, there is nothing you can do about a gas station having old or otherwise bad fuel in their 93 tanks.
Subaru figured out the design flaw in that system and improved the system in future cars. Now the hardware is better so it is able to listen to higher RPMs, and after the point they choose to stop listening they do not add max timing. This has to have improved motor longevity, and allows the tuner to tune your car to a higher power level more confidently.
The question still remains, how often is my car knocking? One common statement made by car owners is I never hear detonation so it must not happen. We have come across people who should know what detonation sounds like, but are not hearing it. Part of the problem is detonation becomes damaging before it becomes audible. This means you may never be able to hear it while it is taking it's toll on your motor.
If you get in a bone stock car and romp on it you may well hear detonation. The problem is there are so many variables that contribute to lowering the detonation threshold. For example if you sit at a light for 45 seconds and then take off in a spirited manner your intercooler is not as cool as it was when the car was on the dyno, getting custom tuned. In this situation the map your tuner made may no longer be appropriate. 20-30 seconds later when the intercooler cools off everything is back to normal, but what happened as you rowed through the gears?
Everyone always wants to put a boost gauge in their car. Others ask what are the three most important gauges to add to the car. Typically the response is some combination of boost, EGT, oil temp, and oil pressure. If you think about it a knock detection system is as important as any one of those, if not more. None of the systems in there will kill a motor as fast as detonation. In fact one of the main reasons why you want to know what you are boosting at is to determine if you may be detonating. If you are boosting beyond the capability of the fuel you will detonate, if you are boosting beyond the level tuned for you may be detonating.
What about fuel and timing? They have as great of an effect on causing detonation as boost does. Rarely do people add wide band O2 sensors, and even fewer people monitor the timing they are running at any given moment. This is where a knock indication system is so valuable. If you rely on the engine management to do it's job you do not have to know what AFR, timing, or boost you are running. What may be more important that the exact AFR, boost, or timing you are running is if you are detonating. The TurboXS KnockLite is an inexpensive tool to help you understand more of what is going on in your motor. It is easy and clean to install, and perhaps best of all it only cost $129 MSRP.
Yes, it also is a shift light, so anyone out there wanting the extra little coolness of knowing when to shift you have that built right in. I can say personally that the shift light helps me out a lot, since I seem to have the habit of driving down the freeway in third gear cause I can not hear my motor with the stock CBE installed.
Jarrad
PDXTuning is offline   Reply With Quote
Old 08-28-2005, 12:39 AM   #2
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Now for the installation into my Legacy.
Installation is very easy, there are only 4 wired to hook up: power, ground, tach, and knock signal. We just tapped the signals at the stock ECU to keep wire routing to a minimum. I will put up the pinout for anyone who wants to install this as soon as I have a chance to make it all pretty.
As I said above the electronics inside will convert a coilpack signal into a a tach signal, so on our cars all you do is pick up one of the 4 coil pack signals off the ECU and you are set.
If you want you can install a separate knock sensor, but most people will want to just use the factory one, since it is optimally placed on the motor.
Hope that helps,
Jarrad
971-221-7825
sales@pdxtuning.com
Old 08-28-2005, 02:08 AM   #3
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
Cool! Thanks for the review Jarrad.
coolcougar is offline   Reply With Quote
Old 08-30-2005, 06:38 PM   #4
shemoves
Member#: 80663
2005 STi
Would a high quality bosch knock sensor working independently be better than the stock one? From what I here, the block is already tapped for it and it is a simple install. I am def. gonna get a knock sensor. I just want to make sure it is accurate and will work at the very least up to 7k rpm.
Note: I will not be using the tach signal as I don't want to confuse 'shift' and 'knock' (and the STi has a shift light )
shemoves is offline   Reply With Quote
Old 08-30-2005, 06:51 PM   #5
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Cool tool!
How do you set the rpm for the shift light feature?
How can you tell the difference between the shift light and a knock event?
fogdor is offline   Reply With Quote
Old 08-30-2005, 07:16 PM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I'd use a sepereate sensor if possible unless TurboXS put in circuitry to prevent loading the stock knock sensor circuit. You can do it yourself with a capacitor but its just good to not mess with it.
cdvma is offline   Reply With Quote
Old 08-30-2005, 10:13 PM   #7
hondaeater69
Member#: 60324
is there anyway to calibrate the sensor?
Old 08-30-2005, 10:31 PM   #8
Jon [in CT]
Member#: 2992
02 WRX Sedan
This device appears to be a simple engine noise meter, a far cry from a knock meter. No method to adjust gain. No method to specify frequency. No method to specify "knock window."
Jon [in CT] is offline   Reply With Quote
Old 08-30-2005, 11:44 PM   #9
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
I was fortunate enough to pick up one while at TurboXS Australia back in april for testing on the QT.
I also have knock link. The knock lite works better/consistent and very easy to setup and calibrate.
IMHO
Going to be some fun with reflashes now that people will know if their car is knocking or not and not just putting blind faith in some tuners reflash ability.
If ya can't see/hear it knocking it ain't.
Wombat North is offline   Reply With Quote
Old 08-31-2005, 01:06 AM   #10
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Have you taken a look at one or are you just guessing?
Old 08-31-2005, 01:09 AM   #11
cronic
Member#: 9749
Does it matter? He will rain on any parade he can. I think we should start a nasioc pay-pal donation to get Jon laid so he can stop being so uptight.
cronic is offline   Reply With Quote
Old 08-31-2005, 01:13 AM   #12
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Oh my let's try to keep this thread on track. With my shadetree mechanic skills, my 02 is in constant fear of its life already.
Old 08-31-2005, 12:17 PM   #13
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
You can set the shift point by holding the button down till the light comes on green, then revving to 1/2 the desired shift point, and pushing the button again.
Shift is indicated with a Green light. Moderate knock with Amber (Red + Green together), and Heavy knock with Red.
It's not possible to hook it up without the tach signal - it needs to know the RPM so that it can "filter" background engine noise. Otherwise it would just be lighting up constantly at higher RPMs like a KnockLink. The light is calibrated by letting it record engine noise by reving to idle, half of redline, and near redline in turn - the sensor then interpolates the points to come up with an engine noise "curve" that it uses to distinguish between background noise and knock events (a knock sensor is just a microphone, after all). The sensitivity can then be adjusted up or down from there.
It's a pretty trick unit. If you have a DTEC, it'll supply Tach and Knock level inputs to be logged or displayed as well.
serendipity is offline   Reply With Quote
Old 08-31-2005, 12:38 PM   #14
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
*golf clap*
Yes, it also "appears" to be just an empty shiny container with some wires and a blinky light. When you buy one, crack it open, and reverse engineer it, be sure to let us know what it actually is and what its logic is.
That said, I'll wait until the incredible price gouging subsides to the point where this product is available for a reasonable price with reasonable profits still plentiful for TurboXS and distributors.
jblaine is offline   Reply With Quote
Old 08-31-2005, 02:09 PM   #15
shemoves
Member#: 80663
2005 STi
Is there any other place to intercept the signal that in not near the ECU?
Old 08-31-2005, 02:15 PM   #16
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
+1 to serendipity for the details!
Wow, that's quite a feature set
Old 08-31-2005, 09:09 PM   #17
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
It's still a bit cheaper than a KnockLink and the MSD knock light, isn't it? I would like to see it drop below the $100 mark.
drees is offline   Reply With Quote
Old 08-31-2005, 11:52 PM   #18
SuperSubie81
Member#: 22965
2008 BMW 135i
SGM
So if this unit just goes off the stock knock sensor, how is this better then the flashing CEL that the UTEC provides off the stock knock sensor
SuperSubie81 is offline   Reply With Quote
Old 09-01-2005, 12:02 AM   #19
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Sprry for the delay in response, and thanks Serendipity for getting good information out there.
You can use a separate knock sensor if you want, although it does not pull the signal down going to the stock ECU so you do not have to.
I thought $129 shipped was pretty reasonable. jblaine if you think that is unreasonable call me and we can talk about it.
Jarrad
971-221-7825
Old 09-01-2005, 12:49 AM   #20
Davenow
Member#: 23676
I dont see the point of this, the UTEC already flashes the CEL when there is knock
Is this able to be used as a standalone thing without a utec? Is that the point?
Old 09-01-2005, 01:23 AM   #21
drees
Member#: 25905
2003 Silver Wagon
Yep, you can use it with any EM, no UTEC required.
Old 09-01-2005, 03:00 AM   #22
jstbstn
Member#: 35020
02 WRX - Stage WTF
04 WRB WRX Wagon - Stg 2+
I would think this would be more reliable than the utec for knock detection as it reads directly off the knock sensor and would hopefully be faster reacting. I think it would also be a good safety measure for those adjusting the utec knock sensitivity settings as it should help tune a good sensitivity level in the utec settings.... I'm running a utec and I definately want to get one of these to add to my arsenal of tuning safety measures. Jarrad you may be hearing from me very soon!
jstbstn is offline   Reply With Quote
Old 09-01-2005, 04:56 AM   #23
shemoves
Member#: 80663
2005 STi
a big, flashing, dedicated light will get my attention much better than a CEL.
Old 09-01-2005, 06:44 AM   #24
ilivas
Member#: 56056
2004 wrx
T04R Turbo / 8k rpm 257
interesting product
ilivas is offline   Reply With Quote
Old 09-01-2005, 09:24 AM   #25
Davenow
Member#: 23676
ok after reading the thread more in depth I can definately see a point in this (speaking as if you already have a UTEC, if you dont have a UTEC I would say this is a GREAT idea.)
Seems like basically a knocklink BUT also a shift light. In a much nicer, more compact package...
Its def not something I would use as my cel flash is plenty for me but I guess its not a bad idea...
ATP stock location Turbochargers review and discussion EFI Logics Proven Power Bragging 362 01-08-2016 01:06 PM
turboxs knock light anthonyrb98 Interior/Dressup/Audio & Security 6 03-14-2007 11:11 PM
TurboXS knock light hook up in a 2006 bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-30-2006 05:06 PM
turboxs knock light? anyone runnin it? kessler89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-03-2006 02:11 AM
Installing TurboXS Knock Light?? ScoobySnacker Electrical & Lighting 4 03-09-2006 01:54 PM
