Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 09-01-2005, 08:32 AM   #26
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
I think people have a lot of the same confusion about the knock lite as they did about the DTEC when it came out.
Reality is TurboXS can't focus on JUST Subarus and Evos - they need more generic products (and not just boost controllers) to grow the business. The DTEC line and Knock Lite are part of that. Don't keep thinking "But I already have a UTEC" - yes, you do get _some_ of the functionality for free with the UTEC. But think of folks with 2.5RSs who can now go to TurboXS and get a full tuning suite - DTEC + Knock Lite + Tuner, from one company, that integrates beautifully and looks very trick hooked to a Gameboy. You can tune fuel, log and monitor EGTs + Wideband AFR, and have a nice knock and shift-lite to boot, all for under $800. Ditto for just about any other car. Even though they're still expanding what cars they make full-featured UTECs for, the DTEC gives them an in to alllll the other cars that there would never be enough volume to justify the custom development of a UTEC.
serendipity is offline   Reply With Quote
Old 09-12-2005, 10:01 PM   #27
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
if i didn't have a stock knock sensor (i am using a GM sensor) how could i hook this up?
Old 09-12-2005, 10:35 PM   #28
Jon [in CT]
Member#: 2992
02 WRX Sedan
The better question is: "Why would I bother?" What prompts anyone to believe the TurboXS knock detection algorithm for a Subaru engine is any better than the one used by the stock ECU?
Jon [in CT] is offline   Reply With Quote
Old 09-12-2005, 10:39 PM   #29
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
thanks jackass, next time hit the back button instead of the "post quick reply"
no stock sensor because i don't have a stock ecu
Old 09-13-2005, 04:21 PM   #30
x99percent
Member#: 27108
2004 STi
2004 A4
Because people have popped motors while running the stock ECU?
Because the WRX ECU stops listening for knock at high RPM?
I'm not saying the TurboXS knock detection algorithm is "better" for these reasons, but I *am* saying that the stock ECU's detection algorithm is not perfect.
x99percent is offline   Reply With Quote
Old 09-13-2005, 04:24 PM   #31
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
No way, Subaru engineers spent eleventy billion dollars in testing on everything and it is all perfect.
jblaine is offline   Reply With Quote
Old 09-13-2005, 05:00 PM   #32
shemoves
Member#: 80663
2005 STi
My question is not weather or not to get it, or even weather or not to get a seperate mic (yes, i'm gonna get a seperate Bosch one), but weather to go TXS or Link (leaning toward the TXS).
Is there anywhere else to tap into the neccessary wires away from the ECU?
shemoves is offline   Reply With Quote
Old 09-13-2005, 05:04 PM   #33
x99percent
Member#: 27108
2004 STi
2004 A4
Aww, crap... eleventy? I thought it was only oneteen.
Old 09-13-2005, 10:00 PM   #34
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Why would I bother
Some situations you fail to consider
(1)Because early 04 STI's that Subaru "engineers" so wonderfully programmed had to be reflashed to stop the pinging. Engineers are never wrong
Since I own one of those early 04 STI's and had a knock link installed at 500 miles I could add toluene till the knocking stopped at the electronic level till the UTEC came out. Knock lite works the same.
(2) Since "non engineers" are now able to reflash the stock ECU and send it to all climates of the USA etc. Could it be possible that they screw up the programming as good as the factory engineers on the early 04's only now the knock is at the electronic level and as such the owner doesn't know his cars knocking. Blissful in the knowledge he got a wonderful reflashed EMS
(3) I have heard many stories of tuners who also set the knock count on the UTEC to over 30 so that the owner thinks he has a well tuned car but its knocking and the CEL light doesn't flash. With the Knocklite's user install friendly setup it gives the owner of a badly tuned UTEC an easy double check system and hense weed out the bad tuner who blames the UTEC for the customers blown motor.
(3) Since I'm one of only a few who have Knock Link, TurboXS protuner with knock sensor, UTEC and Knocklite in my car I can say that it works very nicely. I also have Delta Dash.
(4) I'm also one of the very few who have actually toured TurboXS engineering in Australia and have met first hand with the University trained electrical engineers they employ. It ain't no Ma and Pa outfit with over 25 employees there alone not like some EM companies here.
They have managed to attract people from other Australian EM companies which I not allowed to reveal. I'm guessing Motec and Autronic are on your sub par engineering list also.
BY
Wombat North is offline   Reply With Quote
Old 09-13-2005, 10:04 PM   #35
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ok now that we have put jon on a spit and roasted him ..
how can i run this standalone w/o a stock knock sensor?
Old 09-13-2005, 11:56 PM   #36
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
All you need to do is get a stock knock sensor, bolt it to the block and plug the knock light into it, not sure if it is compatible with other knock sensors... On TurboXS's site you can pick up the Knock Light along with a Bosch knock sensor.
BTW, anyone have the pinouts used to tap into the knock sensor? Anyone have ideas on stealth mounting of the knock light which still lets you get to that button used to program it?
drees is offline   Reply With Quote
Old 09-28-2005, 03:27 PM   #37
InfamousDX
Member#: 25413
So is there a benefit to this if you have a Tuner PRO that already has the Bosch knock sensor??? Or is this just extra security if you already have the PRO?
Old 09-28-2005, 04:11 PM   #38
Sperm
Member#: 25038
2002 PSM WRX sedan
Sounds like a good product to me. It's on 'The List' now.
Sperm is offline   Reply With Quote
Old 09-28-2005, 05:05 PM   #39
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
The knock indicator lights on the TunerPro are hard to read. This will be much more capable of getting your attention if there is a problem. You can use the same knock sensor that came with your TunerPro, but the TunerPro does not really have an equivalent function to the knock light. Also the TunerPro does not have the shift light at all.
Jarrad
PDXTuning is offline   Reply With Quote
Old 09-28-2005, 05:54 PM   #40
nmyeti
Member#: 4980
http://www.turboxs.com/more_info.php?ID=212
Note the diagram. The competitor is a knock-link.
-Nathan
nmyeti is offline   Reply With Quote
Old 09-28-2005, 07:54 PM   #41
InfamousDX
Member#: 25413
Thanks Nathan and Jarrad... explains it well. Looks like I'll snatch a cheap non-pro Tuner and then the KnockLite.
Old 09-29-2005, 11:58 AM   #42
03WRXMA
Member#: 35081
2012 WRX
FWIW the knock link still has the controls to adjust the threshold, ect. why doesnt TXS incorporate that?
03WRXMA is offline   Reply With Quote
Old 09-29-2005, 12:04 PM   #43
shemoves
Member#: 80663
2005 STi
-Nathan
right on. And does the fact that it is non-volatile memory mean I won't have to reprogram it after unplugging my battery?
Old 09-29-2005, 12:34 PM   #44
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Because it's not a single level you can twiddle with a knob. The feature as presented here "listens" to your engine while you set it and hold it at 3 different RPMs and produces a noise floor "curve" across the RPM band. Much nicer than a single adjustment. BTW I'm not a Knock Lite user yet, I'm just regurgitating what Serendipity said earlier in the thread
fogdor is offline   Reply With Quote
Old 09-29-2005, 12:44 PM   #45
WrxRonald
Member#: 42408
1988 2JZ SUPRA w/T61
1993 1JZ RX7 w/GT35r
Default ..thanks..
was never really sure if this was something i should have, other than it would just have been more conspicuous than the check engine light while blinking and therefore i would better notice it while grasping the wheel for dear life as my Rexy shot down the road like a rocket
but appears from the write-up that it is certainly more than that.... a system of 'checks and balances' if you will for the UTEC tuned by a vendor (like mine).
that said. I'm SOLD.
does it come with a 'clear cut' installation of which wires to splice into on the utec/ecu?
WrxRonald is offline   Reply With Quote
Old 09-29-2005, 03:40 PM   #46
shemoves
Member#: 80663
2005 STi
If anyone has installed this, an install write-up with pics would be great
Old 09-30-2005, 11:56 AM   #47
InfamousDX
Member#: 25413
Default another question
Is there a diagram or instructions showing which wires are which coming out of the ECU (specifically the knock/coil pack wire cuz I don't know which one that is).
EDIT: Also let me ask this (if it hasn't been already covered)... what is better for monitoring knock. The knocklite wired into the factory knock sensor or a separate Bosch knock sensor bolted onto the block (same place as factory but on pass. side of the block)???? I thought the factory knock sensor stops listening after a certain RPM?
Old 09-30-2005, 12:00 PM   #48
WrxRonald
Member#: 42408
Default ...
thats where i gotta think 'no'. only because isn't this a universal product? in other words they're selling this not as a wrx or sti specific product, but useable in most vehicles.... so certainly they can't include pics or all car's ECU's....................
PDX can you help us figure out which wires to tap on the wrx and sti ecu's? would it be same across the board of model yrs and wrx vs. sti, or different wires for each.
course i do remember having an old 2002 ecu pinout diagram....... not sure what i did with it though.... assume its likely floating around nasioc somewheres. little search prolly do the trick......................
Old 09-30-2005, 12:07 PM   #49
InfamousDX
Member#: 25413
^^ True... I'm sure there's a pinout somewhere, just takes a bit of searching. I was just being lazy but it shouldn't be hard at all.
Old 09-30-2005, 12:15 PM   #50
drees
Member#: 25905
2003 Silver Wagon
It's not that the knock sensor itself stops listening, it's that the ECU starts ignoring it after a certain RPM because of the noise level.
ATP stock location Turbochargers review and discussion EFI Logics Proven Power Bragging 362 01-08-2016 12:06 PM
turboxs knock light anthonyrb98 Interior/Dressup/Audio & Security 6 03-14-2007 10:11 PM
TurboXS knock light hook up in a 2006 bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-30-2006 04:06 PM
turboxs knock light? anyone runnin it? kessler89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-03-2006 01:11 AM
Installing TurboXS Knock Light?? ScoobySnacker Electrical & Lighting 4 03-09-2006 12:54 PM
