Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 09-30-2005, 12:31 PM   #51
InfamousDX
Member#: 25413
Originally Posted by drees
It's not that the knock sensor itself stops listening, it's that the ECU starts ignoring it after a certain RPM because of the noise level.
Ahh, sweet clarification. Thank you VERY much.
Old 09-30-2005, 01:33 PM   #52
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
I wouldn't say thats accurate. Its been said that the ECU for '02/'03 isn't fast enough to do computations required above 5k. Noise level is not an issue...
cdvma is offline   Reply With Quote
Old 09-30-2005, 02:02 PM   #53
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
You mean my ECU needs to be held back a grade? Dang
fogdor is offline   Reply With Quote
Old 09-30-2005, 05:12 PM   #54
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I just bought the UTEC TunerPro with the additional knock sensor. Where's the best place to locate it and install it? Does anyone have pictures?
Thanks,
Justin
crystalhelix is offline   Reply With Quote
Old 10-01-2005, 12:56 AM   #55
InfamousDX
Member#: 25413
Thanks,
Justin
If you know where the factory knock sensor is on the TOP of the driver's side of the block, there is a corresponding spot to put the Bosch knock sensor on the pass. side. That's where I put mine when I had the Tuner Pro.
Old 10-01-2005, 11:17 AM   #56
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Me too. It gives good results.
On topic...a friend of mine got this and its sweet. Says it works well.
Old 10-01-2005, 03:53 PM   #57
WrxRonald
Member#: 42408
1988 2JZ SUPRA w/T61
1993 1JZ RX7 w/GT35r
Default ...
question....
so if the ECU stops listening above 5k or so (2002).... do that mean this knock light will not indicate knocks above 5k??? how bout the utec? is it still indicating knocks above 5k rpms (or wherever the ECU exactly stops listening)?
i assume yes: just because the ecu isn't listening doesn't mean the UTEC isn't? dido for the knock light? or am i wrong and the utec and knock light are both being told by the ECU when to indicate knocks.....
WrxRonald is offline   Reply With Quote
Old 10-01-2005, 03:58 PM   #58
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Originally Posted by WrxRonald
question....
Your assumption is correct. The UTEC and the KnockLight work independently from the stock ECU (as well as from eachother) and have their own knock detection capabilities. They listen throughout the entire rev band.
Old 10-06-2005, 10:58 PM   #59
InfamousDX
Member#: 25413
Hopefully I can really road tune my car well now since I have another Tuner (sold the old one, just ordered one from JSC Speed) and just ordered the KnockLite from PDX!!
Old 10-07-2005, 08:06 AM   #60
WrxRonald
Member#: 42408
Default ?
what do you mean another 'tuner'?
Old 10-07-2005, 09:52 AM   #61
InfamousDX
Member#: 25413
Did you read what I had in parentheses?? I sold my old tuner Pro... I now just ordered a tuner... because I'd like to be able to road tune my car again.
Old 10-07-2005, 01:29 PM   #62
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
I woulda traded my tuner+$ for a pro! If anyone wants to let me know.
santofontana is offline   Reply With Quote
Old 10-07-2005, 02:58 PM   #63
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
chris are you saying that 04+ wrx ecus DO listen for knock up there?
Old 10-07-2005, 03:31 PM   #64
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
The range that the 04 WRX ECU listens for knock is greater than that of the 02 WRX. There is a limit, it can be changed with a reflash.
Jarrad
PDXTuning is offline   Reply With Quote
Old 10-08-2005, 02:37 AM   #65
InfamousDX
Member#: 25413
Just got mine today... FAST shipping from PDX (thanks again Jarrad and co.). Here's a pic of the contents... will update this post with more when I install it (hopefully sunday).
Old 10-09-2005, 12:53 AM   #66
shemoves
Member#: 80663
2005 STi
Yes, install pics would be great!
shemoves is offline   Reply With Quote
Old 10-10-2005, 01:03 AM   #67
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
I installed mine on my 04 Cobra this afternoon. I haven't hooked it to the knock sensor and the thing is still lighting up when I rev the engine. I set the light up according to the instructions and set it to the lowest sensitivity.
Anyone else have this issue?
The shift light works fine if that helps. The cobra doesn't have a knock sensor, so I plan on using a seperate sensor wired directly to the knocklite.
LargeOrangeFont is offline   Reply With Quote
Old 10-10-2005, 12:32 PM   #68
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
does anyone know what the knock output to Dtec wire signal is like? what tyoe of signal does it output?
Hitokiri is offline   Reply With Quote
Old 10-13-2005, 02:56 AM   #69
STIDevildog
Member#: 72889
Finished my install of the knocklite yesterday. Took a bit longer than expected because do to cable management and making it look nice. The housing needs to come in black in the future. Does not look stealthy at all. Will be expertimenting by using shrink tube around the housing tomorrow. Would just need to cut a small hole for the button.
STIDevildog is offline   Reply With Quote
Old 10-13-2005, 01:09 PM   #70
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
Mount it in the AC vent. The above isn't a TXS knocklite but you get the idea. It wouldn't be too hard to do in the WRX.
Old 10-13-2005, 09:24 PM   #71
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
i bought one from pdx tuning as well, and it was shipped very quickly! i recommend them to anyone!
now... i have t.w.e. stage II heads/cams/springs/retainers and im trying to tune my custom turbo kit on my 02 2.5rs. anyone have a similar setup? whats your light's sensitivity set at? are my heads and cams that much louder than stock? i know they are lifting farther and faster, so i would imagine they are much louder!
darioc is offline   Reply With Quote
Old 10-14-2005, 12:29 PM   #72
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
F-it. Black paint is your friend. Or maybe take it apart and have it black anodized.
bushflyr is offline   Reply With Quote
Old 10-17-2005, 09:28 PM   #73
metoo
Member#: 4764
2004 STi sold :(
forizzle
Originally Posted by Davenow
I dont see the point of this, the UTEC already flashes the CEL when there is knock
And that's exactly why I bought one. I can barely see that thing in the day time unless I'm looking directly at it....which is very rare. When it does blink when I'm looking at the road, I wonder if that is what I really saw. I don't want to have to pay attention to the little faint check engine light when I'm driving hard.
metoo is offline   Reply With Quote
Old 11-02-2005, 02:31 AM   #74
metoo
Member#: 4764
2004 STi sold :(
forizzle
Which wires do you tap into?
Old 11-08-2005, 04:54 PM   #75
Sperm
Member#: 25038
2002 PSM WRX sedan
Any new reviews, guys?
Sperm is offline   Reply With Quote
ATP stock location Turbochargers review and discussion EFI Logics Proven Power Bragging 362 01-08-2016 12:06 PM
turboxs knock light anthonyrb98 Interior/Dressup/Audio & Security 6 03-14-2007 10:11 PM
TurboXS knock light hook up in a 2006 bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-30-2006 04:06 PM
turboxs knock light? anyone runnin it? kessler89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-03-2006 01:11 AM
Installing TurboXS Knock Light?? ScoobySnacker Electrical & Lighting 4 03-09-2006 12:54 PM
