Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 11-08-2005, 10:02 PM   #76
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
it is def a good idea to tune with something else as well as the knocklite, so you can see if you are indeed knocking when the light flashes. i am having a tough time calibrating the lite. find someone with a J&S like i did!
darioc is offline   Reply With Quote
Old 11-08-2005, 10:27 PM   #77
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Having just sold my TurboXS TunerPro kit, I no longer have any visual notification of engine knock so I'm looking at the KnockLite.
I am curious what is involved with the hookup? So far, details in this thread seem sparse.
Specifically:
-need an rpm pickup? If so, how do you obtain this on an 05STi? Is it the same as mentioned by PDX with the LegGT install?
-what is the wiring like using an auxilliary knock sensor?
-anything else to be aware of?
nhluhr is offline   Reply With Quote
Old 11-09-2005, 12:04 AM   #78
shemoves
Member#: 80663
2005 STi
Specifically:
Four wires...ignition, ground, rpm (splice into wire from ecu), and the knock sensor (microphone).
shemoves is offline   Reply With Quote
Old 11-09-2005, 12:22 AM   #79
shemoves
Member#: 80663
2005 STi
Alright, so I've been looking around...where can i get a bosch knock sensor (already have the lite)? Perhaps I was not looking in the right spots, but I looked for just the sensor via google, jscspeed, turboxs, pdx, and some others and couldn't find it (by itself).
Old 11-09-2005, 05:34 PM   #80
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
Ebay.
LargeOrangeFont is offline   Reply With Quote
Old 11-11-2005, 01:06 PM   #81
John at J&S
Member#: 2036
2000 Intrepid
Try tapping into the factory knock sensor wire at the ECU, like we do with the J&S unit. Be sure to use a shielded cable, to avoid introducing electrical interference.
Here's how we make the cable that's included in the kit:
We use 22 gauge, twisted pair, with foil shield and drain wire. There are lots of different part numbers and cable brands that will work, but we like Belden 9461, because it's easy to strip.
At the J&S end of the cable, we connect the black and the drain wires to the system ground pin, then we connect the white wire to the knock input pin on the unit.
At the other end of the cable, we cut off the black and the shield wires, as they are not used. The white wire is then spliced into the knock signal wire, near the ECU. Make sure that you don't cut into the factory shield, as this will short out the knock signal.
darioc: Did you do a temp install of the knocklite on a J&S equipped car? Might be ok if both cars have similar noise levels.
John at J&S is offline   Reply With Quote
Old 11-12-2005, 08:36 PM   #82
metoo
Member#: 4764
2004 STi sold :(
forizzle
Which Ecu wire is that?
metoo is offline   Reply With Quote
Old 11-13-2005, 12:49 AM   #83
Jon [in CT]
Member#: 2992
02 WRX Sedan
Depends on model year and model. Consult appropriate wiring diagram.
Jon [in CT] is offline   Reply With Quote
Old 11-27-2005, 12:49 AM   #84
CBoldman
Member#: 11411
I have an 04 STi and I cant seem to locate an appropriate wiring diagram. Anyone care to help? I would love to install my knocklite but I cant seem to be able to find the knock wire.
CBoldman is offline   Reply With Quote
Old 11-27-2005, 07:00 PM   #85
pdxsilverwrx
Member#: 54935
Just added this to my Christmas list!
pdxsilverwrx is offline   Reply With Quote
Old 11-27-2005, 11:53 PM   #86
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Have turboXS email you the ECM wireing diagram for the 04 in PDF.
I have 04 STI and pinout #25 located on connector B136 is the knock signal used for the knocklite.
Wombat North is offline   Reply With Quote
Old 02-24-2006, 06:33 PM   #87
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Green w rust coloration
subscribe
wrxsubaruwrx is offline   Reply With Quote
Old 02-27-2006, 03:14 PM   #88
Zumble
Member#: 34860
2005 Forester CGM
I'm curious what people who tap in to the stock knock signal at the ECU are using for the wire. It was recommended to use a shielded wire. I just ordered a KnockLite last week so I may be getting it soon. The knock signal wire for the unit isn't shielded right?
Have people been successfully running the knocklite with the unshielded wire? Any "experts" want to chime in on this?
Zumble is offline   Reply With Quote
Old 02-27-2006, 03:50 PM   #89
Lost_Pete
Member#: 100570
The wire should be shielded.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 02-28-2006, 05:20 PM   #90
Zumble
Member#: 34860
2005 Forester CGM
Does that mean one should open up the knocklite and replace the knock wire with a shielded wire?
regards
Pete
Old 02-28-2006, 09:35 PM   #91
shemoves
Member#: 80663
2005 STi
hmm, i'm having mine installed real soon...would like to know about anything I should do so I can do it right the first time (will be using stock knock sensor).
Old 03-01-2006, 12:37 AM   #92
Zumble
Member#: 34860
2005 Forester CGM
If you're using the stock knock sensor I think my previous question will be your biggest concern before doing the install. Otherwise, it seems pretty straight forward. Mine should be coming in the mail.
Old 03-01-2006, 06:31 AM   #93
Lost_Pete
Member#: 100570
Use a shielded wire. Use the signal wire(s) to connect the knock sensor to the Knocklite. The shield is connected at one end only to a ground such as at the Knocklite ground.
regards
Pete
Old 03-01-2006, 02:15 PM   #94
shemoves
Member#: 80663
2005 STi
Alright, I gotta go get that wire...what should I look for specifically? Is it a specialty item or could I just get it at a hardware store?
Old 03-01-2006, 05:12 PM   #95
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
You can use some audio or mic cable. They are usually somewhere around 22/2 w/ shield.
santofontana is offline   Reply With Quote
Old 03-01-2006, 06:05 PM   #96
Zumble
Member#: 34860
2005 Forester CGM
It's still not clear to me if I want to unsolder the knock signal cable from the knocklite or not.
Old 03-02-2006, 01:03 AM   #97
shemoves
Member#: 80663
2005 STi
What is 22/2? Also, wouldn't audio cable melt in the engine bay?
Old 03-02-2006, 10:42 AM   #98
drfrink24
Member#: 36369
2004 WRX STi
Java Black
22 = AWG, the wire gauge.
2 = number of wires
The cable will melt if its directly sitting on something hot. You realize you have lots of "normal" wires under your hood from the factory, right?
drfrink24 is offline   Reply With Quote
Old 03-03-2006, 11:20 AM   #99
shemoves
Member#: 80663
2005 STi
2 = number of wires
It makes sense, but I did not know if they would've used a higher quality sleave. I'll go to a local hardware store and ask for "shielded 22 guage wire." How much length would I need...a few feet each? Also, any issues going with a lower guage (larger wire)?
Old 03-03-2006, 12:27 PM   #100
ScoobySnacker
Member#: 105303
2003 WRX
So are there any specific instructions for hooking it up?? The instructions given were a little vaugue.
ScoobySnacker is offline   Reply With Quote
ATP stock location Turbochargers review and discussion EFI Logics Proven Power Bragging 362 01-08-2016 12:06 PM
turboxs knock light anthonyrb98 Interior/Dressup/Audio & Security 6 03-14-2007 10:11 PM
TurboXS knock light hook up in a 2006 bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-30-2006 04:06 PM
turboxs knock light? anyone runnin it? kessler89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-03-2006 01:11 AM
Installing TurboXS Knock Light?? ScoobySnacker Electrical & Lighting 4 03-09-2006 12:54 PM
