Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-03-2006, 12:32 PM   #101
drfrink24
Member#: 36369
2004 WRX STi
Java Black
I think its often referred to as "control" wire. They often use it for wiring home control and security systems. I don't know the length. Something like this would work fine I'd imagine:
drfrink24 is offline   Reply With Quote
Old 03-03-2006, 04:17 PM   #102
shemoves
Member#: 80663
2005 STi
can i use larger wire?
shemoves is offline   Reply With Quote
Old 03-03-2006, 06:14 PM   #103
shemoves
Member#: 80663
2005 STi
Still pretty confused on what wire to use and where. I went to a few places, and the smallest I could find was 18 guage. Also, is the need for shielded wire only if you use a seperate sensor?
Old 03-04-2006, 02:23 PM   #104
shemoves
Member#: 80663
2005 STi
same questions as before...also wondering if the sheilded wire is only necessary when using seperate knock sensor
Old 03-05-2006, 12:45 AM   #105
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
18 gauge is fine. Thicker wont hurt you its just harder to work with sometimes if you need to solder into a small connector or something. I would use shielded for any type of knock sensor hookup. Ive used shielded wire for all my gauge installs. Yes it could melt but it is more durable than a regular wire because it has a jacket and shield protecting the wires inside.
santofontana is offline   Reply With Quote
Old 03-05-2006, 12:55 AM   #106
shemoves
Member#: 80663
2005 STi
any more specifics? what wire would it replace and where?
Old 03-06-2006, 10:43 AM   #107
Zumble
Member#: 34860
2005 Forester CGM
subscribe... I still have my knocklite sitting here because I'm still not clear about this shielded wire business. I opened up the back of the knocklite and it seems impossible to get the board out without removing the white goop.
Again, for the knock signal wire, do we have to unsolder the old wire from inside the knocklite? Then solder in a new shielded wire?
EDIT: To be clear, I want to use the ECU knock signal, not a separate knock sensor.
Zumble is offline   Reply With Quote
Old 03-06-2006, 11:28 AM   #108
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you could ground the shield at the block if you wanted. a shield is just held at a fixed potential to avoid electromagnetic coupling.
Old 03-06-2006, 04:46 PM   #109
Lost_Pete
Member#: 100570
The caveat on this is that there are numerous knock sensors and cable types and various interference sources in the car so some cases may require a different approach.
When connecting sensitive signals from high impedance sensors ideally you should use shielded cable. The shield reduces the amount of interference from the outside reaching the signal wires on the inside of the cable. The shield should be connected to a "solid" reference point such as the ground of the car. The shield should be connected at one end only to prevent circulating currents.
So using a easily obtainable cable such as;
http://www.radioshack.com/product/in...entPage=search
NOTE: This is not a recommendation for this cable as we would ideally use a specific type of cable depending on the job. For example a twisted pair overall shielded cable with the outer shealth specific for the environment or perhaps whatever we could find in the box!
You would connect the signal to the inner wires using one or both of the wires depending on your application. The outer shield wire would be connected to a ground. In practical terms join the shield to the 0V lead at the Knocklite.
regards
Pete
Lost_Pete is offline   Reply With Quote
Old 03-06-2006, 07:38 PM   #110
shemoves
Member#: 80663
2005 STi
Just had it installed w/o shielded cable...seems to work fine. Lost_Pete...are you an engineer?
Old 03-07-2006, 04:56 AM   #111
Lost_Pete
Member#: 100570
Good to hear it is working fine.
Yes I am an engineer..........
regards
Pete
Old 03-07-2006, 09:52 AM   #112
nmyeti
Member#: 4980
regards
Pete
Lost Pete used to be TurboXS_Pete. He knows what he is talking about.
-Nathan
nmyeti is offline   Reply With Quote
Old 03-07-2006, 09:59 AM   #113
Zumble
Member#: 34860
2005 Forester CGM
I just made up a new harness. I found some twisted pair shielded cable at radio shack. I cut the white knock wire out of the stock "harness" and I soldered in on of the wires from the shielded wire. I then used shrink tubing to join the two wires back together at the knocklite end of things. I guess I'll solder a new wire to the shield braid and attach it somewhere to the body ground. I haven't installed the knocklite yet. I only had time to put in the new wire. I still have to figure out which wires to connect for a 05 USDM FXT ECU.
EDIT: I don't think this thread should be in the UTEC section. The knocklite can be used with ANY EM or no EM at all.
Old 03-07-2006, 10:55 AM   #114
shemoves
Member#: 80663
2005 STi
I knew it! My dad is an engineer too. He also has the inability to answer questions in 'layman's terms.'
Old 03-07-2006, 11:12 AM   #115
Zumble
Member#: 34860
2005 Forester CGM
I didn't want to say it.. but yea, couldn't get a straight answer out of pete.. =P At least not a straight answer I could process and be sure about so I just did what made sense to me.
Old 03-07-2006, 11:43 AM   #116
shemoves
Member#: 80663
2005 STi
I call it "geniuos syndrome." He prolly got really frustrated with us tards. Pete, thx for continuing to try to explain it w/o calling us names.
Old 03-07-2006, 03:24 PM   #117
Lost_Pete
Member#: 100570
If "engineer speak" makes no sense then just ask me to translate to "man in the street" speak (MITS) or in KISS language.
You also have Nathan and Jermaine who really do know their "stuff".
regards
Pete
Old 03-07-2006, 03:52 PM   #118
R4ND0M_AX3
Member#: 67483
2005 WRX STi
Agreed. I just happend to see this in the summary when I was up one level. Otherwise I wouldn't have come into the UTEC thread.
<----knocklite user with AP/ST.
R4ND0M_AX3 is offline   Reply With Quote
Old 03-07-2006, 04:38 PM   #119
shemoves
Member#: 80663
2005 STi
I also have the AP/ST.
As far as 'fine tuning' goes...what sensitivity level to most of you use?
Old 03-08-2006, 08:13 PM   #120
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
As always, "helpful_Pete"
Great to see you back.
S.
n2xlr8n is offline   Reply With Quote
Old 03-09-2006, 11:17 AM   #121
R4ND0M_AX3
Member#: 67483
2005 WRX STi
I'm on 6 now.
Old 03-09-2006, 04:06 PM   #122
Lost_Pete
Member#: 100570
S.
Thanks...........
regards
Pete
Old 04-20-2006, 03:55 PM   #123
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
It would be great if the KnockLite directions were available on TurboXSs website...
Nixlimited is offline   Reply With Quote
Old 04-20-2006, 04:00 PM   #124
shemoves
Member#: 80663
2005 STi
I had mine installed by a shop, and they even had to spend quite a while trying to figure out where to put what cause the instructions provided are pretty lame.
Old 04-20-2006, 06:17 PM   #125
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Do you know how to set the sensitivity level and how to do the initial calibration using RPM points?
ATP stock location Turbochargers review and discussion EFI Logics Proven Power Bragging 361 01-04-2015 04:48 PM
turboxs knock light anthonyrb98 Interior/Dressup/Audio & Security 6 03-14-2007 10:11 PM
TurboXS knock light hook up in a 2006 bcarleton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-30-2006 04:06 PM
turboxs knock light? anyone runnin it? kessler89 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 05-03-2006 01:11 AM
Installing TurboXS Knock Light?? ScoobySnacker Electrical & Lighting 4 03-09-2006 12:54 PM
