Old 08-28-2005, 11:08 AM   #1
stevo2234
Member#: 69853
2005 WRX
gold
Default Water injection
hey i have an 05 wrx that im about to throw a VF39 on, and i was wondering 1, how to hook up a water injection system, 2. can i make one or where can i buy one, 3. where does it hook up in the intake?
thanks, steve
stevo2234 is offline   Reply With Quote
Old 08-28-2005, 12:28 PM   #2
stevo2234
Member#: 69853
2005 WRX
gold
bump
Old 08-28-2005, 01:08 PM   #3
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
SEARCH much....
tell you what though... post some results when you have it done.
Bundyboyz is offline   Reply With Quote
Old 08-28-2005, 01:55 PM   #4
scooterforever
Member#: 55011
thanks, steve
Ok, first, you have a fair amount of research to do. The application of WI is somewhat straightforward from a theoretical perspective, more complex from a tuning persective, and catastrophic for your engine (potentially) if you run into problems.
So... please search and read and read and search and then post. But in brief:
1. you can't just throw on or hook up a WI system. You need to tune for it, otherwise you'll slow your car down. The exception to that would be if you are running into det problems, but in that case I would recommend figuring out what was wrong before going for WI.
2. it's not hooked up to the intake (again, more research), you put the jet/nozzle/etc. after the intercooler before the throttle body. This can be done drilling and tapping the intercooler or purchasing a special throttle body hose with built in jets.
3. the basic WI system requires some sort of controller (ranging from advanced injection control, such as Aquamist solutions to a simple boost switch -- a pressure activated switch), a pump (e.g., Shurflo 8000, etc.), hose line to the jets, a water/alky source, and, preferably, some sort of safety mechanism (ranging from Aquamist safety features at the high end to a simple "low water" sensor to a flow meter swtich), and, must importantly: TUNING.
WI is not for everyone. But it is a blast when you have it set up correctly.
scooterforever is offline   Reply With Quote
Old 08-28-2005, 03:06 PM   #5
fat angel
Member#: 81630
scooter- you can install in the intake. i have seen it and felt it first hand. it seems to help very well with any heat soak issues. you can just throw it in but you wont feel the true benefit from it.
fat angel is offline   Reply With Quote
Old 08-28-2005, 06:15 PM   #6
scooterforever
Member#: 55011
Well, there is in fact a discussion started in the Aquamist thread on the engine management pages regarding pre-turbo post-intake injection done with a specialized collar. This would be done for specific pursposes linked (in my limited understanding) to maximizing turbo efficiency. But of course you'll want a very fine mist of water; with water hitting the turbo blades and all.
As for just throwing WI on, generally, without tuning, you are runing the risk of going way too rich and loosing power. I'm not a WI tuner, but that's what's more likely than not to happen from everything I've read. Don't believe me, well, there are dyno results to that effect out there.
FS : Meth / water injection kit NEW! defi gauges boost, egt JT's06sti Engine/Power/Exhaust 7 06-17-2010 11:45 PM
alky injection/water injection... i dont understand vipernj Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-05-2005 12:50 AM
Power difference between water injection and alky injection? scooterforever Water/Methanol Injection, Nitrous & Intercooler Cooling 10 06-21-2005 05:58 PM
I need a water can for water injection, any ideas? AntiochCali Water/Methanol Injection, Nitrous & Intercooler Cooling 3 06-02-2003 09:57 AM
BIG water tank for water injection DarthChicken Water/Methanol Injection, Nitrous & Intercooler Cooling 14 07-25-2002 03:58 AM
