Old 08-28-2005, 02:35 PM   #1
lostsoulmusic
Member#: 44717
1997 Impreza l sport
black
Unhappy My car sags and I hate it!!!!!
My '97 Impreza L Sedan sags in the rear at least 2" or more and it drives me nuts.I had my local Subaru dealer replaced the rear springs and still the car sags.I dont have much of anything of weight in the trunk area besides a small tool kit,but nothing heavy. The other local Subies don't seem to have this problem???Please help
lostsoulmusic is offline   Reply With Quote
Old 08-28-2005, 02:43 PM   #2
horrorbiz
Member#: 77290
16 WRX Limited
You might want to post in the suspension section. Anyway, the GC imprezas usually lower a bit more in the back for better weight balance, but it should definetly not be 2in! Do you have aftermarket suspension? You could look into getting the SPT springs which only lower your car about an inch, and that should make them a bit more even.
horrorbiz is offline   Reply With Quote
Old 08-28-2005, 02:50 PM   #3
lostsoulmusic
Member#: 44717
black
Unhappy saggin subie
I am using the stock rear.the only change is when I had the dealer replace the rear springs, but it did't help either.
Old 08-28-2005, 04:08 PM   #4
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
same thing with my 99 L. the gap in the wheel well is much smaller in the rear than the front. get sti pinks, prodrive, or spt springs that should be ok. might also want to look into new struts.
svek is offline   Reply With Quote
Old 08-28-2005, 07:04 PM   #5
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Default check your struts
I would be replacing your struts. They are probably blown or worn out.
John2.5RS is offline   Reply With Quote
Old 08-28-2005, 11:45 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Pics?
Old 08-29-2005, 12:18 AM   #7
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
i too had this issue, but after doing three spring swaps, first had intrex, then eibach, then i got the Perrin's, with every spring except the perrins i had sagging issues, with the perrins the problem was fixed and had no issues, i am also running KYB AGX struts too if that helps any,
Allsubaru83
allsubaru83 is offline   Reply With Quote
Old 08-29-2005, 01:23 AM   #8
Lethargic1
Member#: 20998
I've heard pretty much nothing but good things about the Perrins as well. Good luck.
Lethargic1 is offline   Reply With Quote
Old 08-29-2005, 04:32 PM   #9
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I'd check the suspension forum, but this seems as this might be normal.
AO
m750 is offline   Reply With Quote
Finally got my car painted. Green. Either love it or hate it STEALTH-WRX Member's Car Gallery 210 02-17-2006 04:56 AM
My car sags and I hate it!!!!! lostsoulmusic Brakes, Steering & Suspension 2 08-28-2005 05:40 PM
Got my car back and it look great.. cgerald1 New England Impreza Club Forum -- NESIC 8 04-27-2004 12:06 PM
Guys I am trading my car in and selling it stock. Wheels Tri-State Area Forum 0 04-02-2003 08:09 PM
WRX: UKers and AUssies hate it and Japanese love it Imprezer WRX Forum Archive 8 02-15-2001 11:21 AM
