Old 08-28-2005, 05:38 PM   #1
chevelle100
Member#: 94521
Default Engine swapping?
Is engine swapping a common thing in these cars? Can you drop an ej20tt into a car with a 1.8? Thanks.
chevelle100 is offline   Reply With Quote
Old 08-28-2005, 05:40 PM   #2
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Run a search on the conversions forum. Yes, what you mentioned is possible and has been done before. This is the wrong forum for this question.
DrBoy01 is offline   Reply With Quote
Old 08-28-2005, 05:42 PM   #3
chevelle100
Member#: 94521
Sorry, figured that was for other things. My mistake.
Old 08-28-2005, 05:56 PM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
That particular swap is a bad idea, the twin turbo setup will take a lot of work to fit in a LHD car, but if you check out the stickies in the conversion forums you can learn a lot about the number swaps available for your car. Lots of options with any Impreza/Subaru.
jamesfacts is offline   Reply With Quote
Old 08-28-2005, 06:58 PM   #5
rabbitnutz
Member#: 51940
what he said ^^ wrx swap is "easiest" and best bang for the relative buck in th elong run
rabbitnutz is offline   Reply With Quote
Old 08-28-2005, 08:00 PM   #6
chevelle100
Member#: 94521
What all does it take? Do you mean ej25 or the sti?
Old 08-28-2005, 08:18 PM   #7
rabbitnutz
Member#: 51940
you can basically swap any EJ series engine into an RS....so it all depends on time and $
you got lots of $ and a bit of time? go for the entire USDM STi drivetrain.....a decent amount of $ and some time ? version 7 drivetrain....and so forth all the way down to a 2.2 swap
Old 08-28-2005, 10:30 PM   #8
chevelle100
Member#: 94521
Does the impreza have to be an rs? Most of the ones ive seen say l or ls.
Old 08-29-2005, 03:41 AM   #9
blueslsti
Member#: 54862
2005 LGT Wagon 5mt
Regal Blue
No it doesn't have to be a RS...
Another good option if you don't have huge funds is the EJ22T motor with 2.5 heads and a different turbo. That should get you going for awhile...
blueslsti is offline   Reply With Quote
02 5mt swap with ej205 engine swap Gamble_WRX Drivetrain 11 04-01-2010 04:40 PM
Engine swap, '06 2.5i into '00 2.5RS--Direct swap? singincanary Subaru Conversions 13 10-01-2007 09:47 PM
Engine swap or car swap? AcquaCow Subaru Conversions 21 07-18-2003 12:10 AM
Engine availability/engine swap in Calgary SeanLiew Canada Region Forum 1 05-31-2002 09:42 AM
