Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 09-01-2005, 12:40 PM   #1
chevelle100
Member#: 94521
Default How long will they last?
How much does a turbo really decrease reliability? Lets say a 100000 mile car with a 2.2 turbo running 5 psi. I've seen subarus go 200000 miles easy with no problems. Can you still do this?
chevelle100 is offline   Reply With Quote
Old 09-01-2005, 01:38 PM   #2
kheff46
Member#: 66739
2002 WRX wagon
i ran for about 30k on my turbo setup. i had 124k when i got the car, and just rolled 155k. i was at 5psi. and it felt good. no engine management of any sort, stock fuel pump, stock injectors with a stock 2002 wrx turbo an tmic. i just pulled it off a month ago, and no CEL or anything before or afterwards. car sound the same as before, except a new exhaust rattle! that happens though!
kheff46 is offline   Reply With Quote
Old 09-01-2005, 01:50 PM   #3
shemoves
Member#: 80663
2005 STi
A big determiner would be how much boost you run. Keep in mind though, that the 2.2 turbo motor is one of the strongest production 4 cylinders ever built.
shemoves is offline   Reply With Quote
Old 09-01-2005, 02:03 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
If you can install it and not get more power hungry, it'll last just as long as without the forced induction. As long as you do regular oil changes and don't hammer on the transmission.
Master2192 is offline   Reply With Quote
Old 09-01-2005, 02:21 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Well,
Let's clarify here. Are you talking about an NA Ej22 that you add 5psi of boost to? Or an Ej22T factory turbo block. I am guessing the former, right? 5psi can be run for a good long time on an NA Ej22. It is when you hit 8-10psi that reliability drops substantially.
Old 09-01-2005, 02:32 PM   #6
shemoves
Member#: 80663
2005 STi
Originally Posted by Matt Monson
Well,
To add to that, factory setting on the 2.2T motor, I beleive is around 7-8 PSI. From what I understand, people run the 2.2T motor in the low teens without issue.
Old 09-01-2005, 10:02 PM   #7
chevelle100
Member#: 94521
Yeah, I meant teh 2.2 na, I would only put about five psi.
Old 09-02-2005, 03:13 AM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
5psi, intercooled, with premium gas, shouldnt be a problem. Evertime you lack one of the above you may or may not experience knock. You WILL experience knock above 5 psi without any of the above. And then even with them. Unless you have engine management.
reddevil is offline   Reply With Quote
Old 09-02-2005, 07:02 AM   #9
Migo
Member#: 81352
2003 '03 EJ257 wagon
Green
So I'm under the impression that the same would hold for a EJ25 on 5 psi?
Migo is offline   Reply With Quote
Old 09-02-2005, 08:35 AM   #10
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
i have a 2.5 turbo, 7psi and a 75 shot of nitrous. been running for about 15k miles and 9 months. no problems. no engine management,
farrell is offline   Reply With Quote
Old 09-02-2005, 09:02 AM   #11
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Turbos don't decrease reliability on any engine. Poor engine management does more than anything else. My last 81zxturbo had over 249,000 miles on it and I ran 10psi on it all day long. Stock was 6-7psi. I had of course swapped the afm to mas and swapped the computer to a newer 300zxt.
Old 09-02-2005, 12:52 PM   #12
chevelle100
Member#: 94521
The fat kit comes with engine management.
Old 09-02-2005, 01:28 PM   #13
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Well, sort of. Here's a quote from their website
"RRFPR, a voltage clamp (for speed density equipped cars) and a piggy back computer system to control ignition timing."
Really thats all whats needed. the AVO kit comes with a much better system that the stock ecu won't fight.
Old 09-02-2005, 07:04 PM   #14
chevelle100
Member#: 94521
Yeah for a grand more, but I guess you get what you pay for.
Stock Potenza, How long do they last? RAPTR Tire & Wheel 20 04-27-2006 04:53 PM
Tread wear of 140. How long do they last? txl146 Tire & Wheel 35 04-10-2005 02:40 PM
How long will they last... SuBart General Community 5 09-20-2004 06:48 PM
Hoosier R3S03s - how long will they last? jmott Motorsports 17 03-16-2003 08:37 PM
OEM Struts - How long do they last? macrac Technical Forum Archive 7 07-12-2000 06:51 PM
