Old 09-29-2005, 01:00 PM   #1
WrxRonald
Member#: 42408
1988 2JZ SUPRA w/T61
1993 1JZ RX7 w/GT35r
Default this tire fit this wheel?
two part question please....
please avoid the noxious critisisms if at all possible.... i know most people aren't into a wheel/tire combo of this size for the rexy....
trying to figure out though... will a 235/35/19 tire fit correctly onto a 19x9 inch wheel? i think that is pretty much just the right fitment.... the tire is right around 9inches or a little over in tread width.....
now open season: your comments on how well this will run on a lowered rexy?
for the record, i've been running 19x9's with a 225/35/19 Falken tire that was designed to resess from the wheel a bit for very low rides and clearence of the fender. i have the whiteline G4 coilovers at there lowest recommended setting, don't get any rub and all seems to run pretty well.
i 'won' a free set of Kuhmo tires and wanted a tire that looked wider and more appropriate on the 9inch wide wheel... but i'm a bit concerned that i'm gonna have huge rubbing problems with a tire that is now as wide as my wheel..........
opinions appreciated, thanks in advance
WrxRonald is offline   Reply With Quote
Old 09-29-2005, 03:03 PM   #2
2Stroke
Member#: 36712
2003 WRX Wagon
235/35-19 is generally approved for wheel widths between 8.0" & 9.5". That's the only part of your post I can respond to.
2Stroke is offline   Reply With Quote
Old 09-29-2005, 03:38 PM   #3
WrxRonald
Member#: 42408
Default thanks...
that's cool.... so then i could conceivably fit these on 19x8's as well should i ever change up wheels to something smaller... good to know, thanks.
(i've been eyeing some 19x8 SSR Comp Hybrids)
Will this tire fit? del105 Motorsports 8 10-05-2004 05:44 PM
Will this tire fit? ImprezedRS Tire & Wheel 12 01-19-2004 07:19 PM
Need to know if these tires fit 17x7 wheel Quick Time Tire & Wheel 4 08-22-2003 10:38 PM
Will this tire fit this rim? pio!pio! Brakes, Steering & Suspension 2 06-13-2002 07:13 PM
Will This Tire Fit? scoobynewbie Brakes, Steering & Suspension 2 12-04-2001 12:31 PM
