Old 08-28-2005, 07:12 PM   #1
hampster
Member#: 15766
torq steer=something
cattlemen do after work.
Lightbulb Wider than 225 and rubbing...what are you running?
I've found numerous threads on people running wider than 225's on WRX sedans, but I've read conflicting information on what rubs and what will clear.
So, if you can help me (and many others, I'm sure) out and let us know what your are running and whether or not you have rubbing issues:
1. Tire make/model:
2. Tire size (nominal):
3. Wheel make/model:
4. Wheel size:
5. Fenders (rolled/stock):
6. Spring/shock/coilover setup:
7. Alignment (mainly camber, F/R):
8. Does it rub? (where, what conditions):
hampster is offline   Reply With Quote
Old 08-28-2005, 11:07 PM   #2
HomerJay
Member#: 1135
2005 WRX WAGON
You'll be fine as long as you start w/ 235's or less. Any wider and you'll have to start thinking about rolling your fenders. Especially your rear fenders. Some searches would yield all the info you need.
HomerJay is offline   Reply With Quote
Old 08-29-2005, 02:30 PM   #3
hampster
Member#: 15766
I'm causing all my own grief by trying to run that ragged edge...245's. My specific situation is I am looking at 245/35-18 Toyo T1-R's on 18x8 SSR Competitions (+51 offset) with an Eibach Pro Kit (springs, -1.3" front, -1.1" rear).
I have searched extensively for people using the same/similar configurations and found the closest to be: +51mm offset wheel (18x8"), 245/35-18 Toyo T1-S (same actual dimensions as newer T1-R), running STi pinks and struts on a 2002 WRX sedan. This individual went 9+ months without rubbing, then rubbed one day with the car loaded down (5 people) while turning a corner.
Others have used Toyo T1-S in 235/35-18 with +51mm offset wheels and Tein lowering springs and said their next tire will be 245/35-18's (ie: they think they will have the clearance).
Yet others have used Bridgestone Pole Position S0-3's in 225/40-18 on +51mm offset wheels and Prodrive or other lowering springs and had plenty (ie: over 0.75") of clearance (225/40-18 S0-3 is only 0.4" narrower than 245/35-18 T1-R/S).
The point here (aside from my own struggle on functional tire sizes) is that some people have no rubbing whereas others running similar (or even more conservative) configurations experiene rubbing.
I personally have PM'd over a dozen people on this board to get additional information on their setups to see why this is happening (ie: PM one guy to get his alignment specs, another for his wheel offset, another for his strut models, etc).
This is a tedious way to gather data, so my intent was to gather all pertinent data from people more efficienty (and publicly) so other's could benefit from this *complete* data and not have to do what I've been doing for the last week.
Cliff's Notes: This thread is for the benefit of all ScoobyKind.
Old 08-29-2005, 09:53 PM   #4
boxerboy
Member#: 80976
Hampster . I am encountering similar problems for different reasons. Mine are brake size. It may be a couple of weeks be for I can get tires on my car (02 WRX). I will try to run 235. I will post pics and spec when it all works out. PM me if you want.
boxerboy is offline   Reply With Quote
Old 08-29-2005, 09:54 PM   #5
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
1. Falken Azenis RT-615
2. 245/45-17
3. Rota Boost
4. 17x8, +48
5. Stock
6. Stock
7. Stock
8. Yes. Mainly between 10 o'clock and 2 o'clock only at full suspension load in the rear.
They'll fit just fine once i roll the fenders, and once i lower it it'll clear thanks to the added camber.
i think that the +51 offset is going to kill ya.
shane86 is offline   Reply With Quote
Old 08-30-2005, 03:56 PM   #6
slickvic
Member#: 29727
2003 Impreza WRX
I have some 245/40/17 michelin pilot sports that I will be putting on my car this week (have to get them mounted and balanced) on a 17x8 +48 wheel. The car is lowered about an inch on tein flexs with 1 degree rear camber and 2 degrees front. I will post back once I get them on about rubbing. I have heard that this will fit, might need a little more camber, without rolling the fender. I have 225 on the same 17x8 inch wheel and it seems that I have just enough clearance to the fender and to the strut, but it will certainly be close. Worst comes to worst I will simply have to roll the fender.
slickvic is offline   Reply With Quote
Old 09-03-2005, 10:40 PM   #7
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
This is what I am running, ZERO rubbing
JDM addict is offline   Reply With Quote
Old 09-03-2005, 10:57 PM   #8
slickvic
Member#: 29727
2003 Impreza WRX
^ you're cheating though with the sti
Old 09-04-2005, 01:13 AM   #9
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
chassis is the same between WRX and STi
Old 09-04-2005, 04:39 PM   #10
slickvic
Member#: 29727
2003 Impreza WRX
It's a bigger fender flare though isn't it? Maybe I'm wrong just always thought it was. If not I'm going to stop dicking around with 245's and step up to some 265 asap.
Anyway put the 245/4017 Michelin Pilot Sports on today and took it for a test drive. No rubbing during normal driving, but when I pushed it real hard in a turn that has a couple mid-corner bumps it rubbed in the rear on the rubber liner that hooks onto the fender lip. It just barely rubbed the outside edge of the rumber strip so you would probably be fine if you just took that off since it adds about another 1/4 inch to the fender lip. I went ahead and rolled the fender ( did this with a baseball bat and a hair dryer and it turned out fine) anyway just cause I dont want to risk cutting my pilot sports. So basically if you are going to run 245 or more I would say plan on rolling the fender on a wrx sedan.
Again as posted above I'm running 1 degree rear camber on a 17x8 +48 wheel and I'm running about an inch lower (13.5" from hub center to fender edge in the rear and 14" front) on tein flex coilovers 10k/8k.
Hope this helps some
Old 09-05-2005, 04:56 AM   #11
slvrwrx04
Member#: 58058
2014 STI Sedan
Satin White Pearl
I believe JDM Addict has a 2004 STI, so he does not have the fender flares on the rear of his car.
slvrwrx04 is offline   Reply With Quote
Old 09-05-2005, 03:13 PM   #12
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
The fenders are identical, stop dicking around
Old 09-05-2005, 04:12 PM   #13
slickvic
Member#: 29727
2003 Impreza WRX
What wheel size and offset is this on. Definately going to have to go something bigger now. I dont get how you fit that though and I rubbed the rubber stripping on a 245. How much camber are you running and what ride height is this. Thanks for any info you can provide.
Old 09-05-2005, 04:30 PM   #14
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
18x8.5 +45
yes you do
My fender lip are rolled with no rubber strip.
-1.75
I don't know how to define ride height, but my car is on 04' TEIN S-tech springs.
Old 09-05-2005, 04:32 PM   #15
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
My advice to you is, stop listening to other people and carefully think about it yourself, it is a very simple measurement. If you can see and use a ruler, anyone can do it. People are just lazy and afraid to try it.
Old 09-05-2005, 04:40 PM   #16
slickvic
Member#: 29727
2003 Impreza WRX
Hey thanks alot, great info there. I think running only 1 degree rear camber is making things tighter for me than need be. A little more camber and I think i could get another 20 mm of tire in there or at least a 255 depending of the tire design.
Old 09-05-2005, 05:34 PM   #17
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
yup, you starting to see it
It is not rocket science
Old 09-06-2005, 03:21 PM   #18
slickvic
Member#: 29727
2003 Impreza WRX
True, it's just that it would suck to spend $800 on tires and then they end up not fitting. I think thats why people are reluctant to go big until they see others do it first.
Old 09-30-2005, 11:38 PM   #19
JohnW
Member#: 14583
2002 WRX Wagon
Addict.. long time no see.
I'm thinking of putting rt-615 255/40/17 on my wagon. Unfortunately I can't wait for the 235/40/17s that are coming out next year. I'm going to try to measure tomorrow. If it doesn't fit, I'll have to go with 245/40/17 Kumho MXs.
Good to see you still around and driving your STI.
JohnW is offline   Reply With Quote
Old 10-01-2005, 08:42 AM   #20
boxerboy
Member#: 80976
5Zigen GN+ 18x8.5 48 G-force 245/35/18 Had to roll the rear fender. That was the only issue.
Old 10-02-2005, 01:13 AM   #21
SubiePilot
Member#: 85245
V7 STi wanna be
On a 02 WRX sedan 245/40 SO2 pole positions on 17x8 rota torque all suspension is stock(for now). I have lots of room, no rubbing at all. Till my prodrives springs get here then we will see.
SubiePilot is offline   Reply With Quote
Old 10-03-2005, 04:13 PM   #22
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Hi John, yeah is been a while since I seen you, thanks for saying hi! I hope everything is going well with you
Man, 255 is HUGE for a wagon, my 265 BARELY fit inside my wide fender, but you got 9k springs though, that helps a lot!
Yeah I am still around, I'll live here forever if I can, and yes I am loving my STi, in my opinion it is the perfect car in the price range for me. The only other cars I would own in the future would be an Infiniti GTR and Porsche 911 Turbo, that is if I am doing A LOT better in life. I have to have 4WD, high power sports car
17 or 18 on my wrx what are you running drkelly Tire & Wheel 10 11-18-2011 01:00 AM
Intake Setups for Rallycars, What are you running? rallykeith Motorsports 5 08-03-2004 01:59 PM
Auto-x Suspension set-up? What are you running? joshmeduri Brakes, Steering & Suspension 2 01-07-2004 06:58 PM
Plugs for RS-T? What are you running? jeff22 Normally Aspirated with bolt-on Forced Induction Powertrain 1 06-10-2003 03:18 AM
Turbo Poll: What Are You Running? MagicMT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-06-2001 01:12 AM
