Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 08-28-2005, 11:13 PM   #1
jdb2300
Member#: 94418
1998 Subaru 2.5GT
Green
Default Heads on a ej25
Does anyone know anything about which heads you can put on the ej25 dual overhead. And what would the pro's and con's of doing it?
jdb2300 is offline   Reply With Quote
Old 08-28-2005, 11:18 PM   #2
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Say what?
which heads can you put on a ej25 dual overhead?
Patrick L is offline   Reply With Quote
Old 08-29-2005, 12:29 AM   #3
The Stig
Member#: 91322
2005 WRX
I believe he wants to know which heads will work on the DOHC version of the EJ25 and what would be the pros and cons of each head. Off the top of my head (no pun intended), the SOHC ej25 head should work, the ej20 wrx head should work, and the STi head. The latter two will probably cost you a pretty penny. I remember seeing a thread somewhere measuring the different CRs on a EJ25 using different heads. Using the EJ20 or the STi head should improve air flow, but likely you'll need other mods to take advantage of it.
The Stig is offline   Reply With Quote
Old 08-29-2005, 01:22 AM   #4
poormansporsche
Member#: 79798
Your heads flow pretty well. Pretty much every 2.5RS has pretty good heads. I think switching to WRX or STI heads might be advantagous in that they have AVCS but really would be more of a pain than anything else. I dunno who you're going to find to tune a mutha like that.
cheers
garrett
poormansporsche is offline   Reply With Quote
Old 08-29-2005, 09:28 PM   #5
jdb2300
Member#: 94418
1998 Subaru 2.5GT
Green
I think I read recently that the 2.2 heads would work. Is this true?
Old 08-30-2005, 11:52 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
BZZZZT! Wrong answer. Both the Ej25 heads in SOHC and DOHC versions outflow the USDM Ej205 heads. And you cannot put Ej257 STi heads in without coverting absolutely everything. How do you plan on making the AVCS work on a stock ECU?
kbd2300,
Yes, you can put your Ej22 heads on an EJ25 bottom end, and get a nice compression and displacement bump. Do a search in this forum. Use "frankenstein" as your key word and search titles. You'll get the info you are looking for...
Old 08-30-2005, 07:19 PM   #7
jdb2300
Member#: 94418
1998 Subaru 2.5GT
Green
Thank you i was hoping that the 2.2 heads on the 2.5 engine would create more power.
What would it take to run EJ20 heads on the EJ25 block? Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 12 12-31-2008 11:28 AM
Help please!!!.. Ej22 heads on a Ej25??? felixwankel88 Built Motor Discussion 2 08-16-2006 02:04 AM
WRX heads on an EJ25 block... vipernj Subaru Conversions 1 12-20-2005 08:53 PM
EJ22 heads on a EJ25 ??? huck369 Normally Aspirated Powertrain 3 01-20-2005 10:05 AM
DOHC heads on 99+ EJ25? trojan9x Normally Aspirated Powertrain 8 05-12-2003 07:08 PM
