Old 08-28-2005, 11:23 PM   #1
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Question Taillight replacement tips? ('97 sedan)
So I picked up some JDM taillights for my '97 sedan and they showed up in the mail yesterday. I figured it would be a quick, easy swap (as it is on my Mustang, which I just swapped out yesterday) - unbolt, remove old light, bolt on new light. Unfortunately, it's not so simple, because the taillights are actually sealed to the rear of the car.
For those of you who have replaced their taillights, is there any trick to getting the sealant stuff off so I can pull off the OEM lights? Or am I just going to have to make a mess?
Thanks,
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-29-2005, 12:04 AM   #2
sha_zapple
Member#: 41012
1998 Legacy L
you could use a hairdryer to heat it up, or just pull. Maybe use a knife to cut it as you pull. Make sure to add more sealant or else youll get trunk leaks!
sha_zapple is offline   Reply With Quote
Old 08-29-2005, 03:18 AM   #3
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Once you get it started, it's really easy to pull off. Getting a grip on it, and getting it started is the hard part. By the time you've gotten it pulled off enough to get a knife in there, you're almost all of the way off anyways. The sealer they use isn't too messy unless you get brake cleaner on it... then it turns to black goo that never comes out of clothes you get it on... lol
Just grab it where you can, and steadily pull it off... You might need a prybar to get it started just be careful of the paint. After you've got the lights off, I always clean the old sealant off the car with a rag and some brake cleaner... Just makes me feel better knowing that the surface is clean and dry. The sealant stuff you need to use to replace the old stuff is made by 3M... It's called Ribbon Sealer. I'll get the exact part number for you tomorrow, if you want.
Mike
wrx_driver_2002 is offline   Reply With Quote
Old 08-29-2005, 10:45 AM   #4
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
This works well but will take a few extra minutes. Get the hottest hair dryer you own, or better yet, find someone who has a high output one and borrow it.
Open your trunk and apply high heat to the metal area around your rear lamps. The goal is to transfer heat through the metal into the sealant. Do this for about five minutes or to the point where it's hot to the touch. Can't recall if there are bolts (w/nuts) or screws into the lamp but, if there are nuts, then back the nuts out until they are flush with the head of the bolts and push/tap on these after you've heated the metal surround. If screws, then back them out a bit and use them to push on (don't recommend tapping the screws)
From the outside, pull, while you're tapping/pushing from the inside. Once the sealant reaches its release temp (hot to the touch), it should come apart easily. If it doesn't reapply heat and keep up the pressure from the inside/outside.
When you reassemble your lamps, heat up the sealant on your JDM lamps (should be there) and/or reapply some new silicon sealant before you reassemble. Heat up the new stuff too to make it really tacky and better able to conform to the seal point.
Good luck.
Dale
Subietonic is offline   Reply With Quote
Old 08-29-2005, 11:42 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Thanks, guys, sounds like a lot of fun.
Pat
Old 08-29-2005, 04:26 PM   #6
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
It doesn't help any, but I gotta get the dig in... My wagon doesn't have the goo. Just two studs each hold the tails to the car.
LetItSnow is offline   Reply With Quote
Old 08-29-2005, 05:19 PM   #7
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
Legacy's up until the new body style in 2000, used the goo.
Old 08-29-2005, 07:54 PM   #8
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
My 2001 Forester S has the goo/sealant on the tail lights.
Dale
Old 08-29-2005, 08:02 PM   #9
Bud Brown
Member#: 90248
Bud Brown is offline   Reply With Quote
Old 08-30-2005, 07:21 PM   #10
lag
Member#: 34631
to live in fear
Are you the one that won the lights off ebay a few days ago?
lag is offline   Reply With Quote
Old 08-30-2005, 11:15 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I won them about 2 weeks ago. At the time there was at least 1 other set on Ebay.
Pat
Old 09-01-2005, 02:35 AM   #12
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Any progress to report, Pat ?
Pictures ?
Jonathan is offline   Reply With Quote
Old 09-01-2005, 03:12 AM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Not yet, I won't get to it until this weekend. I'll definitely have some pics up when it's all done.
Pat
My Coolant replacement tips skydes Service & Maintenance 0 01-13-2008 05:35 PM
oxygen sensor (O2) replacement tips bigpaulo Service & Maintenance 8 04-14-2005 07:53 PM
Need jdm taillight replacement co2cool926 Private 'Wanted' Classifieds 1 09-22-2004 02:07 PM
front axle replacement tips? subliminal Transmission (AT/MT) & Driveline 3 12-15-2003 06:09 AM
taillight replacement BrsrkOrangutan Interior & Exterior Modification 2 12-18-2002 06:23 PM
