Welcome to the North American Subaru Impreza Owners Club Thursday July 31, 2014
Old 08-28-2005, 11:50 PM   #1
CAPTIN INFERNO
Member#: 74324
04 GT40R/623WHP
GSXR1216, TJ runnin 40's
Impreza WRX STi 16" rims on a sti
I was wondering if 16" wheels would fit over the front brakes and rotors. I'm trying to fit some offroad tires on my 04 sti.
Thanx, Jason
CAPTIN INFERNO is offline   Reply With Quote
Old 08-29-2005, 12:18 AM   #2
Billy
Member#: 1391
1997 GF - silent ed.
12.677@107.87 untuned
No production 16" rims have been fitted successfully over the 5x100 gold STi Brembos to my knowledge. I've been tracking this daily for over 2 years now.
Let us know if you find something or get something custom done up because there are many interested people.
Billy is offline   Reply With Quote
Old 08-29-2005, 01:24 AM   #3
Carizme
Member#: 59848
2005 Impreza STi
my "stuck-on" wheel weight barely clears the caliper on my OEM STi wheels. I would seriously doubt it's possibility
Carizme is offline   Reply With Quote
Old 08-29-2005, 04:01 AM   #4
ChrisL2
Member#: 1444
Replace the brembos with something smaller and then you can fit them.
ChrisL2 is offline   Reply With Quote
Old 08-29-2005, 08:47 AM   #5
Siper2
Member#: 1134
2007 BMW 328xi wagon
Rally wheels. That's what you need. They're made in 16" to clear. Check the OZ or Speedline webpages, or contact a rally shop to see if they can source you some new/used ones.
=S2=
Siper2 is offline   Reply With Quote
Old 08-29-2005, 11:40 AM   #6
CAPTIN INFERNO
Member#: 74324
04 GT40R/623WHP
Thanx for the info, it looks like I'm going to go with a smaller rotor, maybe a wrx size and upgade the rotor with a Stoptech slotted rotor. I will just have to swop back and forth.
J.
Old 08-29-2005, 12:50 PM   #7
tora
Member#: 5851
09 Forester XT
+ NA Miata
Get the old FHI 4-pots and run 15inch rally wheels.
tora is offline   Reply With Quote
Old 08-29-2005, 02:05 PM   #8
Billy
Member#: 1391
=S2=
Custom made rally wheels?
Which 16" rims specifically have you or anyone fitted that will clear? Don't forget that there are rims out there that say they will clear large Brembo 4 pots but then quote the Brembo GT calipers (which are smaller than the OEM NADM STi gold Brembos).
They need to clear the brakes and stay clear of the fenders on GD's at road going ride heights.
Some of us have other problems like using the NADM gold STi Brembos on GC bodies so fender space is limited.
Old 08-29-2005, 05:20 PM   #9
tcrown
Member#: 20240
2005 STI
2002 wrx - sold
Billy, you mentioned you hadn't seen any fit over the 5x100 pattern. I assume this applies to 05's 5x114.3 as well?
Thanks
tcrown is offline   Reply With Quote
Old 08-31-2005, 02:37 AM   #10
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Just FYI, Subaru sells the Spec C Group N in two specifications, the Tarmac (with big brembos) and the Gravel (with the ol' 4/2 pots subaru brakes).
Arnie is offline   Reply With Quote
Old 08-31-2005, 02:55 AM   #11
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I think PatR said the Forester XT 16" wheels just clear the rear brakes on the 04 STi. Definitely not the fronts!!!!
So, 4 pots at the front and Forester XT wheels might work out... but what tires would you use?
ANZAC_1915 is offline   Reply With Quote
Old 08-31-2005, 02:59 AM   #12
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I dunno, your brake bias would most likely be out of whack with that sort of setup. Best to just go the whole hog and do the Gravel Group N setup of the Subaru 4/2 setup and use the standard 15" gravel wheels.
Otherwise, STi owners are just using 17" snow tires or an open tread M/S like the KDWS. Advantage of the KDWS is the much stiffer sidewall compared to any snowtire, which allows you to run a bit less tire pressure compared to a snowtire to prevent tire roll off.
Old 08-31-2005, 03:53 AM   #13
phoenix1112
Member#: 93309
1999 OBS
if youre up for it, ill trade you my wrx brakes and 16" wheels for your brembos and 18"ers
phoenix1112 is offline   Reply With Quote
Old 08-31-2005, 10:58 AM   #14
Siper2
Member#: 1134
I'd imagine that the Prodrive WRC Impreza's Alcons are larger than the Brembo golds, and they still have 16" gravel/snow wheels to clear....
Look up OZ or Speedline, they manufacture the wheels that Prodrive rebadges.
Volk too.
=S2=
Old 08-31-2005, 11:51 AM   #15
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
WRC gravel/snow brakes are smaller in diameter and use a more compact caliper than the STI Brembos.
Jon Bogert is offline   Reply With Quote
Old 08-31-2005, 12:33 PM   #16
Billy
Member#: 1391
Thanks
Sorry man, I've no clue.
Are the 05 NADM STi front calipers the same size, physically speaking, as the 04 NADM STi front calipers?
Are their OE rotors any different other than the bolt diameter?
16" rims on a 2007 STI Mayobeach Tire & Wheel 16 04-28-2010 10:10 PM
Pre '06 16" rims on an '06? GsxrBots Newbies & FAQs 5 09-06-2009 12:23 AM
Best Autocross Tires for 16" rims on WRX wagon RodeoBoy Motorsports 33 08-01-2006 02:19 PM
WRX OEM 16" Rims on 05' Legacy GT? andyfish Tire & Wheel 3 06-24-2005 06:17 PM
04 WRX 16" rims on 93 LS.... chris84bond Tire & Wheel 0 02-08-2005 09:52 PM
