Old 08-28-2005, 11:53 PM   #1
SpoolinU
Member#: 58263
2004 STI
Blue with silver
Default Thinking about an FP Green for my 04 STI Few Q's
This would be my set up...tell me what you think and/or what I'm missing. I need suggestions for injectors (was thinking about having my stock one modded by perrin for like $200 or so). What else do I need?
04 STI
FP Green Turbo
STI stock tmic
K&N short ram intake
Stromung flat flange DP
Stromung mid pipe
Espellir cat back (3in)
Utec
Wallbro Fuel pump
Injectors (needed...which ones?)
Thanks in advance to everyone. I have searched and will continue to but this is my exact set up.
SpoolinU is offline   Reply With Quote
Old 08-29-2005, 12:31 AM   #2
KrazyCurt
Member#: 82700
04 STI
Java pearl
Cool
Call PDX tuning and ask for Jarrad,He will help with all your questions and concerns.
KrazyCurt is offline   Reply With Quote
Old 08-29-2005, 09:08 AM   #3
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
The stromung midpipe and espellir catback are redundant. The catback includes the midpipe and axelback portion of the exhaust.
Modded stock injectors are fine, just get them flow tested and cleaned.
You also don't need the intake. Some tuners say you will need a larger MAF (which you will need to tune for) but you don't. Just make sure you get a good tune.
Capt Crunch is offline   Reply With Quote
Old 08-29-2005, 09:18 AM   #4
x99percent
Member#: 27108
2004 STi
2004 A4
It's not redundant.
In the Subaru world, people refer to the second half of the downpipe as the "midpipe". Most aftermarket downpipes are complete (e.g. Perrin, Helix), but some just replace the first half of the downpipe, like the Stromung piece. The Stromung "midpipe" is needed to complete the downpipe.
x99percent is offline   Reply With Quote
Old 08-29-2005, 09:29 AM   #5
Capt Crunch
Member#: 10852
I have always referred to the midpipe as the portion between the cat and the axel. Now I feel like a dope.
Old 08-29-2005, 09:37 AM   #6
x99percent
Member#: 27108
2004 STi
2004 A4
I have always called that the midpipe, too. I think people were just naming the exhaust components as they were called out in the Subaru factory service manual...?
Old 08-29-2005, 11:44 AM   #7
titsataki
Member#: 4402
yup. Because most downpipes replace the downpipe and the "mid pipe" catalytic converters and the part remaining is the "cat back". At least this is how I understand it. If the downpipe replaces the downpipe catalyst only is called a shortie downpipe.
Cheers
Nick
titsataki is offline   Reply With Quote
Old 08-29-2005, 12:44 PM   #8
powerleak
Member#: 72571
04 STI
perrin modified injectors are fine... make sure you get a turbo inlet hose as well (samco or perrin). i had a similiar setup with the green. i liked it a lot. since it appears you're going with the internal gate, try to get the 8cm housing, if you can find one.
i had bad luck with the stock airbox so i'd stick with your k&n for now.
who will be doing your tuning?
powerleak is offline   Reply With Quote
Old 08-29-2005, 02:21 PM   #9
SpoolinU
Member#: 58263
2004 STI
Blue with silver
XX-Tuning in Hartford will be doing the work...I'm just doing some early research on what I will need. Any idea on where to find a FPG with the 8cm housing for a good price?
Old 08-29-2005, 02:43 PM   #10
fastwrx006
Member#: 38016
06 GG EVO IX
400 hp
Not sure if it matters or not but what about the SZ49 inplace of the FP green? I know that they both have 49lb wheels and all but isn't the SZ a better turbo? Plus deadbolt has free rebuilds for life. Turbo inlet hose is not on the list.
fastwrx006 is offline   Reply With Quote
Old 08-29-2005, 04:03 PM   #11
powerleak
Member#: 72571
04 STI
both fp green and deadbolt sz49 are great turbos. you'd have to call or email forced performance to see if they still offer that housing. i would look into getting a perrin ecbs to help prevent possible problems controlling boost.
http://linux.forcedperformance.net/m...t2/merchant.mv
http://boostplanet.com
Old 08-30-2005, 12:39 AM   #12
BLUE STINGER
Member#: 84206
Stainless steel oil line from fp or other vendors. Big maf for race gas use and if ur on a budget u can still use the factory turbo inlet, just got to grease it up and muscle it in.
BLUE STINGER is offline   Reply With Quote
Old 08-30-2005, 03:50 AM   #13
XoticMotorsports
Vendor
Member#: 93388
Go with a set of modded stockers, then find your nearest drag strip and go do this.
My STi
I had just about the same setup as you when I made that pass.
XoticMotorsports is offline   Reply With Quote
Old 08-30-2005, 10:10 AM   #14
titsataki
Member#: 4402
12.05 is nice. Was that on race gas or pump or something else?
Can you provide a list of mods?
cheers
Nick
Old 08-30-2005, 10:18 AM   #15
XoticMotorsports
Vendor
Member#: 93388
That was on 100 octane, other mods were:
FPgreen
Stock tmic
Turbo XS intake
mbc, 22psi
modded stock injectors
Turbo XS tubo back exhaust
GT spec II header, coated
Utec tuned by myself.
Old 08-31-2005, 11:17 PM   #16
SpoolinU
Member#: 58263
2004 STI
Blue with silver
Only problem is that my car with me in it and all the sound deading weighed in at 3600 lbs...that tends to slow you down a bit
What do you think QM times will be for my 04 STI (454 WHP and 457 WTQ)? Dak Jones Proven Power Bragging 27 08-15-2009 03:09 PM
YOUR 8cm EWG FP Green for MY IWG FP Red don kovy Engine/Power/Exhaust 46 07-21-2007 05:41 PM
Going with an FP Green on my 05 STI. Aftermarket fuel rail required? 2005wrbluesti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-17-2007 02:37 PM
Power on fp Green setup on 04 sti?? STIGSXR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 79 04-17-2006 05:40 PM
Thinking about an APS catback for your STI? Read this first. WRXIN Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-24-2004 09:36 PM
