Old 08-29-2005, 01:19 AM   #1
Evil Dr. Scoob
Member#: 19193
2005 LGT
Regal Blue
Default Starter problem?
Ok, I know I've been dedicated to the NA forums for a while now, L-power and all that, but I broke down and got a '05 LGT on July 1.
So now the 98 L can be "played with" more extensively, but this means it sits for a few days between starts. And if it is longer than a few days, the first key turn does nothing at all. Turning the key again gets a little crank, then more and more until it starts at the 3rd turn. My concern is that my starter is worn out and that it should be replaced. Seems like there should be some bushings or something in it that are worn out.
Is this a problem or am I just fishing for things to work on?
Chris
Evil Dr. Scoob is offline   Reply With Quote
Old 08-29-2005, 05:21 AM   #2
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
sounds like a starter to me...do you hear a "whirring" or any other noise when you turn the key?
//marcus
marcus12 is offline   Reply With Quote
Old 08-29-2005, 02:30 PM   #3
Evil Dr. Scoob
Member#: 19193
2005 LGT
Regal Blue
I should check again, but I seem to recall a clicking noise.
C
Starter problems turns into locked up engine problem Minnesota1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-05-2007 07:03 PM
starter problems aschnell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-25-2003 10:33 PM
('93-'01) '98 obs starter problem geepondy Impreza Forum 2 07-01-2003 06:51 PM
Starter problem 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2002 11:30 AM
Starter Problem darkangelgrafix Warranty Issues & SOA Problems 3 09-18-2002 10:28 AM
