Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 08-29-2005, 02:31 AM   #1
BAMA RS
Member#: 877
1998 2.5RS
BDP
Default IAC location?
I've been reading some threads about cleaning the IAC but am unsure where it is located on the RS. I'm chasing a hunting idle/stalling problem and figured that would be a good place to start. I'm guessing it is just below the TPS(?) on the TB. Is that correct? Any tips on how to clean it? Thanks
Cameron
BAMA RS is offline   Reply With Quote
Old 08-29-2005, 03:43 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
On the 98 RS it's seperate from the throttle body- It's located to the side of the tb, near the crankcase pcv vent.
Drac9 is offline   Reply With Quote
Old 08-29-2005, 03:18 PM   #3
BAMA RS
Member#: 877
1998 2.5RS
BDP
Thanks. Would the IAC cause the car to die stall while driving? I've had it stall while i was doing 50mph last night and a few times today while driving slower. Thanks
Old 08-29-2005, 03:41 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
No, that sounds like an air leak after the MAF sensor...
Old 08-29-2005, 05:43 PM   #5
BAMA RS
Member#: 877
1998 2.5RS
BDP
I have a hose from the BOV to the intake and a hose from the IAC to the intake. Neither of those appear to be leaking. If they did, wouldn't the car constantly stall as opposed to occasionally stalling? I drove about an hour nonstop last night before the car stalled while i was doing 50. After i restarted the car, it never stalled the rest of the night. When it stalled, i was able to downshift into fourth and bring the revs up but the car wouldn't accelerate.
Old 08-29-2005, 07:20 PM   #6
Master2192
Member#: 83254
98 2.5 RS
04 WRX
That instead, sounds more like a fuel issue. Bad pump or a plugged line. But i think it would go really lean and throw a CEL...
Old 08-30-2005, 05:36 PM   #7
BAMA RS
Member#: 877
1998 2.5RS
BDP
Me too. No CE light so far. It happens so randomly that it's hard to pinpoint one thing. I changed the fuel filter today and it ran without issue when i accidently left my gas cap off ( ). When i put the gas cap back on, it stalled a time or two during idle when going out for a drive.
Old 08-30-2005, 06:13 PM   #8
Master2192
Member#: 83254
98 2.5 RS
04 WRX
In the N/A forums there was another thread about a stall issue. Was because of the O2 sensor. Kinda hard to pinpoint when its intermittent and your not getting a CEL
Old 09-01-2005, 01:02 AM   #9
BAMA RS
Member#: 877
1998 2.5RS
BDP
I hooked up my wideband O2 tonight. While i was cruising my AFRs were in the 11s and then all of a sudden the wideband read "lean". That's when the car stalled. What would cause me to go from AFRs in the 11s to suddenly lean like that?
Old 09-01-2005, 10:07 AM   #10
Master2192
Member#: 83254
98 2.5 RS
04 WRX
Want me to make a list??
TPS, Fuel pump, intermittent clogged filter on the fuel pump or the fuel filter, bad O2 sensor, bad MAF sensor
Anything that has to do with the control of the fuel. Most of those should throw a CEL. If i were you, i'd probably pull out the fuel pump and check inside the tank and see if you've got anything in there that could be getting sucked to the filter on the pump. You could also have a wire that rubbed through and is grounding out. Pretty much, your going to have to check one thing at a time to find the problem.
IAC for 02 wrx graphicsman Private 'Wanted' Classifieds 1 06-03-2010 08:58 PM
IAC inlet hose location. Victor1620 Engine Management & Tuning 0 03-31-2009 12:31 PM
Location IAC on 2002 RS imprezkid Normally Aspirated Powertrain 2 12-19-2006 10:13 PM
can't locate the IAC valve for the life of me... discounteggroll Service & Maintenance 1 06-08-2006 08:15 PM
98 ECU, open iac and closed iac (need help wiring a link) Keith Subaru Conversions 5 09-02-2005 08:49 PM
