Old 08-29-2005, 04:05 AM   #1
Dead Man Sliding
Member#: 94617
Default Question about adjustable cam gears.
Are cam how many measurements are there to a cam gear?
For example, if I want an adjustable cam gearset for an ej22, do I have to find a set specifically made for the ej22, or a set that just has X teeth, Y thickness, Z radius, etc?
Dead Man Sliding is offline   Reply With Quote
Old 08-29-2005, 10:06 AM   #2
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
a set that is made for the ej22. I wouldn't mess wiht timing on a subaru. they are electonically timed mechanically advancing or retartding the timing can really do some damage.
Russell Rogers is offline   Reply With Quote
Old 08-29-2005, 12:33 PM   #3
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Yeah, there isn't much you can do with timing. I think there is only about 20 degrees of adjustment before the ECU throws a CEL. Most aftermarket cams just adjust lift and duration, but not timing, for that reason.
HondaH8er is offline   Reply With Quote
Old 08-29-2005, 01:43 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yep.
For about the cost of a set of gears (which I don't know a single company that makes them for the EJ22) you can get a set of cams from Delta for your car. Less than $150 when ground on your cores...
Old 08-29-2005, 05:01 PM   #5
John*G
Member#: 19562
95 coupe
red
Since your other post is about thin head gaskets I'm guessing that you maybe wanting to correct your cam timing back to stock after moving your heads closer together.
There other ways to do it other than cam shaft gears, it is not as easy but cheaper. Off set keys, moving idler pullys for example.
Regards John
John*G is offline   Reply With Quote
Adjustable Cam gears for SOHC Jaxx Normally Aspirated Powertrain 12 09-15-2001 05:01 PM
Anyone use adjustable cam gears? Gerry Normally Aspirated Powertrain 7 10-25-2000 03:07 PM
Adjustable Cam Gears survey WRXGirl General Forum Archive 4 09-12-2000 07:39 PM
Subaru adjustable cam gears??!! Kyle Paton Technical Forum Archive 16 07-13-2000 12:52 AM
