Old 08-29-2005, 01:56 PM   #1
Dead Man Sliding
Member#: 94617
Default Complication with thin head gaskets?
It just struck me that using thing head gaskets on an ej would cause the intake manifold to improperly line up with the heads. Is this true?
Dead Man Sliding is offline   Reply With Quote
Old 08-29-2005, 02:02 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Nope, the difference is so small that it doesn't really matter. I've got thin head gaskets in my RS to raise the compression.
Old 08-29-2005, 02:38 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Not a problem, but since you have an EJ22 with pistons that clear the deck, you could potentially have valve clearance issues...
Old 08-29-2005, 02:52 PM   #4
G.Subramaniam
Member#: 64528
The thin head gaskets are 0.027 inch vs 0.042 inch for stock
The decrease of 0.015 mils is so small that if clearance were a problem, it would already show up in stock cars
G.Subramaniam is offline   Reply With Quote
Old 08-29-2005, 03:17 PM   #5
Dead Man Sliding
Member#: 94617
Actually I don't have a Subaru at all. =)
I'm just researching my next car. I hadn't really considered a 2.2l Impreza until about a week ago. Seems like a good base so far. It's on the short list with a handful of other four cylinder cars.
BTW...Thanks everyone for all the help so far.
Last edited by Dead Man Sliding; 08-29-2005 at 03:18 PM. Reason: quoted wrong guy!
Old 08-29-2005, 03:21 PM   #6
Dead Man Sliding
Member#: 94617
Oh wait.... then could the ej25 heads be used on an ej22 with thin head gaskets to get the lost compression back?
Are the ej25 heads taller? Would the lessen the possible interferance issues with thin gaskets on the ej22?
Old 08-29-2005, 05:15 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Sorry,
You were asking about 2.2l cam gears in your other thread. Anyays, look for a thread title "high compression Frankenstein" You are going the wrong way. Ej25 bottom end with Ej22 heads for higher compression. Ej25 heads have more combustion chamber volume than Ej22.
G. Subramian,
Be careful what you assume. Your engine is phase II, my remarks were meant towards a phase I engine. Maybe it isn't an issue on your engine. Unless you have measured it and done a clay test, I wouldn't go around telling people they can safely do this on their engine!!!
Old 08-29-2005, 05:57 PM   #8
chip4761
Member#: 55867
2005 Saabaru
AS
I'm pretty sure the phase I ej22's are non-interefence engines. Shouldn't that make a thinner head gasket more feasable?
chip4761 is offline   Reply With Quote
Old 08-29-2005, 06:16 PM   #9
John*G
Member#: 19562
95 coupe
red
Hello:
I have a phase I EJ2.2 with the Cometic thin gaskets, Delta cams and heads that have been milled 10 thousands with no problems.
Regards John
John*G is offline   Reply With Quote
Old 08-29-2005, 06:20 PM   #10
Dead Man Sliding
Member#: 94617
That's what I was reffering to by "lost compresion". Can a thinner headgasket make up for the sompression lost with the ej22/ej25 setup? And will it interfere?
Old 08-29-2005, 06:22 PM   #11
Dead Man Sliding
Member#: 94617
Originally Posted by John*G
Hello:
Regards John
Right on. How's that setup working for you? How does it pull?
Old 08-29-2005, 07:02 PM   #12
John*G
Member#: 19562
95 coupe
red
It is in a 93l wagon with light wt. bumper beams, carbon fiber hood, light wt battery, no AC, and most of the sound deadening stuff removed.
The engine has an intake, Borla headers and Stromung Exhaust from the headers back as well as a light weight flywheel, cams as noted above. The heads also have been PnP'd in the bowl and seat area and matched to the intake. The seats have been ground and narrowed to move the contact area with the valves to the very edge of the valve to increase low lift flow. I advanced the cams back to stock specs by using a off set key at the crank for the first head and repositioning the idler pully at the bottom for the second head. I would retard them back a bit if I had some engine management and could raise my red line.
This car has 4.11 gears.
It feels much faster than mysisters stock RS's in a straight line. No track times or dyno numbers though.
No comparison in the handling or braking.
I plan to get some engine management next, then some equal length headers.
When I'm tired of it I'll get a phase II 2.5 block, every thing should swap over except the flywheel.
I think most of the improvement in the car and best money spent was on handling and braking. I consider myself more of a chassis person anyway so I am biased in that regard.
Old 08-29-2005, 10:11 PM   #13
Dead Man Sliding
Member#: 94617
Thank you for the good info, john. I Might be hitting you up for details in the future. You think with a higher redline you can pull more out? There alot of hearsay about the intake manifold choking out high end, what is your experience? Does it get wheasy towards the top?
Old 08-30-2005, 11:25 AM   #14
John*G
Member#: 19562
95 coupe
red
I think the manifold on my 2.2 is adiquite. I havn't run over the stock redline yet. The torque begins to drop off up high but is the manifold the primary cause? If there is a bottle neck in the intake system it is probably at the valve or valve/camshaft timing. I also doubt my intake system is tuned to the exhaust and if the cam is only tuned to one of them I am lucky. I also have no idea what the 1.8 ECU is doing but Matt (above) says the 1.8 ECU has pretty good timing. There are a lot of variables.
But I am not relly building a race car anyway. If I really want to go faster I need some driving lessons.
WTB Mass Area Any subaru with blown head gaskets 0202Subwrx Private 'Wanted' Classifieds 0 04-01-2008 10:23 AM
O-Ringing with MLS head gaskets ? bugeyes Built Motor Discussion 5 12-01-2007 05:15 PM
98 forester with blown head gasket DCsubieSTI Complete Car Part-Out 2 11-01-2007 12:19 PM
O ringing heads with MLS head gaskets? bugeyes Built Motor Discussion 1 12-25-2006 09:47 PM
all you guys with blown head gaskets spdracr00 Legacy Forum 6 08-01-2005 12:14 PM
