Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 08-29-2005, 03:38 PM   #1
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Default Hydra question (1st of many)
Is there a special version I need to buy or will the STi or WRX version work? I'm asking because I may buy a used system.
rjrutzky is offline   Reply With Quote
Old 08-29-2005, 03:41 PM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
STi has an electronic throttle, so you should buy a specific Hydra for your application.
supermarkus is offline   Reply With Quote
Old 08-29-2005, 03:57 PM   #3
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
oops, I meant to say I am using a ej207 v7. It has AVCS but not electronic throttle.
Old 08-29-2005, 05:31 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
You will need a WRX Hydra if have a WRX chassis and wiring harness regardless of your engine. All of the new Element Hydras are setup with AVCS for the WRX but some of the older ones are not.
You will only need an STI Hydra is you have a DBW STI engine and harness.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 08-29-2005, 05:41 PM   #5
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Thanks Phil. How can I tell if it's a new or old one. Can an old one be upgraded? I wish I could afford new, but oh well.
Thanks,
Phil
Old 08-29-2005, 06:11 PM   #6
Element Tuning
Member#: 54918
673 WHP Element
With the serial number I should be able to tell if it has AVCS and what flash version it is. It can be upgraded since it's only adding a few wires to the harness.
Thanks,
Phil
Old 08-29-2005, 07:03 PM   #7
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Thanks again. I'll get the serial number.
sti swap and hydra question rooobaru Other Engine Management 4 08-12-2008 08:12 AM
some gen hydra questions gthurin Other Engine Management 10 06-08-2007 09:53 AM
hydra question Paintballguy Other Engine Management 3 12-29-2006 04:52 PM
Hydra questions swordmaster Other Engine Management 15 08-08-2006 09:52 AM
Hydra Question. STiTuner Other Engine Management 2 11-28-2005 07:19 PM
