Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 08-29-2005, 06:22 PM   #1
Mike1967
Member#: 87762
Default Couple of questions
(1) Is it necessary to remove the valve rocker assemblies in order to remove the Camshaft Caps ? Or can the Camshaft Caps be removed with the rocker assemblies intact ?
(2) I don't have the Camshaft Sprocket tools or the Crankshaft socket tools that the FSM calls out for timing belt removal. Question: Can I simply re-install these gears/sprockets with an impact wrench set on the low setting ? Or do I need to get a buddy and run a cheater bar ?
(NOTE: I recently did a timing belt install on this same car (w/o consulting the FSM....and I did not tighten to torque specifications. I simply reinstalled with my impact wrench. Could I have damaged something internally ? )
Mike1967 is offline   Reply With Quote
New to the World of Boost: Couple of Questions! FenKa856 Factory 2.5L Turbo Powertrain 12 05-15-2009 02:25 PM
('93-'01) couple of questions newgrandpa Impreza Forum 0 06-06-2001 06:56 AM
In-progress installation...couple of questions Overtime Car Audio, Video & Security 12 05-31-2001 12:43 AM
a couple of questions skeisenb Legacy Forum 7 03-20-2001 07:37 PM
Mark Tangemere, a couple of questions. Snoopy Mid Atlantic Impreza Club -- MAIC 2 10-10-2000 12:26 AM
