Old 08-29-2005, 09:41 PM   #1
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
Default PROBLEM w/New Turbo Upgrade
ok i had a turbo on before. i just installed a td04 turbo (wrx) now when i drive its fine but when i come to a stop the car stalls. i pulled a code from the scanner..... PO141- o2 heater malfunction. could that be the reason for my stalling?
farrell is offline   Reply With Quote
Old 08-29-2005, 11:55 PM   #2
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Well if the O2 heater isn't working that would throw your O2 sensor readings all off wack so yes that could certainly could cause stalling.
ai42 is offline   Reply With Quote
Old 08-30-2005, 12:44 PM   #3
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
well, put your old turbo back and see if it stalls... why would swapping just a turbo break an o2 heater ?
STi-Nismo Dood is offline   Reply With Quote
Old 08-30-2005, 01:53 PM   #4
farrell
Member#: 47746
2000 Impreza 2.5 RS
silverhorn
that would be easy, but the flanges are different. lots of cutting and welding involved!!!!! takes about 7 hrs to do the swap. and its not my shop to have ease of access!
Old 08-30-2005, 02:15 PM   #5
Unsung Boxer
Member#: 37196
You have an 02 sensor code, it is not likely caused BY the turbo. You could have damaged it while doing the swap.
Perhaps your EGTs are getting too hot and also causing the sensor to malfunction. Most likely the 02 sensor is bad.
Replace the sensor, clear the DTC and try again. I don't think swapping the turbo will do anything for you.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 08-30-2005, 10:04 PM   #6
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
-Jake
I agree. Farrell, have you ever messed around or used octane boosters or race fuel? That will kill an O2 sensor fast. Also check the wireing for the o2 sensor... there might be heat damage.
Rich L is offline   Reply With Quote
new turbo upgrade T-WRX21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-29-2010 02:07 AM
New turbo upgrade.. What do u think? majunche66 Member's Car Gallery 29 08-30-2007 07:02 PM
New problems with new turbo and AP... Bbasso AccessPort 13 03-23-2007 09:26 AM
new turbo upgrade wow raw323 Transmission (AT/MT) & Driveline 8 03-17-2007 04:58 PM
help me with the steps...new turbo upgrade rbmour Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-22-2005 04:51 PM
